09-04-2009, 05:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Problems in reading infos of BB5 Rap3gv3 phones Go in the folder C:\Program Files\Cyclone Box\Loaders\BB5\FPIF32BIT and remove these 3 loaders (just move them in a folder outside cyclone like documents as sample) h3_sam_nand_format.fg h3_sam_nand_gbbm.fg h3_sam_nand_hdd.fg then retry BR Alex |
The Following 33 Users Say Thank You to moulnisky For This Useful Post: |
09-04-2009, 05:41 | #2 (permalink) |
Freak Poster Join Date: Aug 2008 Location: PhiIippines
Member: 847117 Status: Offline Thanks Meter: 71 | then after removing these FILES,, do we have to PUT it BACK after the work is DONE? |
The Following User Says Thank You to xannix_7575 For This Useful Post: |
09-04-2009, 11:04 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | tried with n95 standard and it made a little difference.now the unit can be detected in info process but sometimes it still fails.i guess the best solution is to use TMA for this problem.btw im already using the new ufc v2... |
09-04-2009, 11:15 | #7 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | If you use the ufc V2 plug a nokia charger (a 5.7V is better as it has inside a 7805 to give you 5V exact on the Vbatt) in the ac12 socket.. will help you a lot about the power problem BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
09-04-2009, 17:56 | #8 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: iCloud ID Removed Service
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | Quote:
br LIEREN | |
The Following User Says Thank You to LIEREN For This Useful Post: |
09-13-2009, 21:50 | #10 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | just wait your phone in local mode and after 2 or 3 second you can read information with out probleme, if realy you can't, you have a bad sl information. Best Regards, JAVA Good. |
09-16-2009, 09:21 | #11 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 212683 Status: Offline Thanks Meter: 115 | Quote:
09-17-2009, 05:38 | #12 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | after deleting these files still give error when doing check flashing bus in N73 Quote:
always same error also with TMA evo and cyclone yellow adapter | |
09-17-2009, 07:24 | #13 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG Box VPP disabled they are still there BR Alex | |
09-17-2009, 15:16 | #14 (permalink) | |
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | Quote:
problem saloved thanx alot | |
09-17-2009, 16:51 | #15 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You are wellcome Anyway not been your fault.. the same loaders are installed again by the last Bulkupdate .. been checking my computer and I had to delete them again BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
Infos about BB5 Unlocked phone | xerraco | BB5KING | 0 | 11-13-2008 02:19 |
Problem Reading Info of N6133 - (Problem Solved Oct-06-2008) | kasamiko | AdvanceUFS | 3 | 10-06-2008 10:21 |
Problem in reading infos/codes in OT156 (OH1C) | mourad_t | ThunderStorm Box | 1 | 06-01-2005 09:24 |
