10-04-2009, 09:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 5800d-1 RM-356 v30.0.011 NOT ABLE TO UNLOCK:(- READED INFO Code: Version Info: MCU SW version: V ICPR72_09w20.5 16-06-09 RM-356 (c) Nokia HW version: 1102 RFIC version: 17141715 DSP version: ICPR72_09w19_1 APE SW Core version: V 30.0.011 APE Variant version: V 30.0.011V 30.0.011 30.0.011.441.02 APE Test version: eno_version Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Content Pack version: v 30.0.011_002_U441 07-08-09 H3G_UK RM356 Product Info: Production serial number: MTI365236 Product code: 0591106 Basic production code: 0584488 Long production SN: 0 Serial Numbers: IMEI plain: 356910038004750 IMEI spare to net: 3A 65 19 00 83 00 74 05 IMEI SV to net: 33 65 19 00 83 00 74 45 F3 Other Info: Model : Nokia 5800 XpressMusic (Classic Phone) BSI: 0,0 KOhm Imei: 356910038004750 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F BLOCK 3: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Code: Imei: 356910038004750 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F BLOCK 3: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Error: Security block invalid or PM corrupted ! CAN WE UNLOCK THIS VERSION WITH MX-KEY?? WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
10-05-2009, 05:19 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | I can be unlocked but is about an hour of work to unlock it and must be done with an exact sequence. BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
10-05-2009, 07:42 | #7 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | No,Dont downgrade it anymore.If u downgrade with lower verson than phone imei will become 123..... Than without new rpl it wont be recover.5800d v30. n 31. hase different security.Only Dm3 n genie Universal can unlock this verson now. |
10-12-2009, 00:15 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Belive me you can unlock with mx-key too.. just you must know the route. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
10-17-2009, 16:48 | #10 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You need a full PM back-up and an RPL from the phone. Downgrade it to V21.0.25 product code 0573738 use the function rebuild simlock from PM and select the PM back-up unlock the phone (save the unlocking code calculated) flash with erase file 5800_Erase_256MB_kashi4gul with skip ape enabled Flash with firmware E71 v300 product code 0559569 with "skip APE" enabled only COR and PPM Write back the PM 308 and 120 back-up Full flash again the mobile with the original firmware APE included Write back the RPL sx4 auth write back FULL PM no 308 no 120 start the phone Input the unlocking code via keyboard or via fbus. BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
10-18-2009, 08:20 | #11 (permalink) | |
Freak Poster Join Date: May 2005 Location: Sweden Age: 56
Member: 148930 Status: Offline Thanks Meter: 33 | i beleive it is more than 1 hours jobb Hi mate; I will give it a try and will let you know. In meanwhile, I hope MX-Key team will find out and implement their own solution. thanx Quote:
10-24-2009, 09:47 | #12 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 44
Member: 68597 Status: Offline Thanks Meter: 6 | Imei: 353205037814157 Version: SIMLOCK SERVER Provider: Bouygues Telecom , Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2082000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20820F, DATA=20820F BLOCK 2: 1=LOCKED (MCC+MNC): 20820F, DATA=20820F Backup already exist. Using device: J.A.F, FW ver: 01.B1 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[nkrpl.biz] ...OK, Login ... Sending NCK code ... Trying NCK lock 7 ... VER 21....025 UNLOCK NOT OK, PSL HELP |
10-24-2009, 09:48 | #13 (permalink) |
03-04-2010, 12:23 | #14 (permalink) | |
No Life Poster Join Date: May 2009
Member: 1028392 Status: Offline Thanks Meter: 87 | Quote:
5800d-1 V30.0.011 Thanks | |
NOKIA 5800d RM-356 V 30.0.011 NOT ABLE TO UNLOCK:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-05-2009 10:38 |
NOKIA 5800d-1 RM-356 v30.0.011 NOT ABLE TO UNLOCK:(- | sahil2000ind | MT-BOX | 2 | 10-04-2009 20:24 |
5800d-1 , rm 356 dead after format infinity box | soylular | Infinity-Box | 8 | 03-13-2009 00:48 |
