Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 11-26-2009, 21:15   #1 (permalink)
Member: 275643
Thanks Meter: 360
working cdma solution here
this topic i want to put her, and here we try that if any new solution come and solution is working, then after test on mobile i put it her, the profit of this section is that, so many new solutions come in this great forum, and all members want to know that they r right or fake so if solution checked by me or any moderator put it here, my try is that when new solution come, i put it here tested result in 24 hours, so this section is called tested solution cdma section.
The Following 23 Users Say Thank You to compue For This Useful Post:
Old 11-26-2009, 23:49   #2 (permalink)
Member: 275643
Thanks Meter: 360
first tested solution result-
haier 2076 v-buzz solution step by step-
open flash tool(driver,unlock bin and flash tool complete)- link is here-http://www.ziddu.com/download/751516...ution.rar.html
now connect haier 2076 with v3i cable without battery and press calling buttonfor sometime(in this process torch on)
open flash tool and click on config
now use browser option and in amss images select unlock bin file
now click on listen mode
flashing start after show 100%, set unlock
here is the link of unlocking pictures-http://www.ziddu.com/download/7465763/compue.rar.html
enjot easy unlock process, i did not did something new, all repeat but in a good manner in one place.
The Following 27 Users Say Thank You to compue For This Useful Post:
Old 11-27-2009, 10:13   #3 (permalink)
PUNEET5154's Avatar
Member: 1023528
Sonork: 100.1594367
Thanks Meter: 1,376
Nice sharing bro....
Old 11-27-2009, 16:19   #4 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
waoooooooooooooooooooooooooo this is complet post
The Following 3 Users Say Thank You to ranagaurav For This Useful Post:
Old 11-27-2009, 18:28   #5 (permalink)
Member: 275643
Thanks Meter: 360
now i'm giving here second full solution unlocking haier2030-
first u load the following link(usb driver, flasher tool and unlock bin)-http://www.ziddu.com/download/752375...ution.rar.html
ONE MORE LINK-http://www.sendspace.com/file/kf1lpj
open 2030 download tool
select browse option and choose bin file
click on erase efs, bak/restore NV
press start,
after flashing complete ur set is unlock.
enjoy easy unlocking.
The Following 13 Users Say Thank You to compue For This Useful Post:
Old 11-27-2009, 19:00   #6 (permalink)
Member: 275643
Thanks Meter: 360
dear all our members if u like this complete solutions, then u write here views, and i daily give here one complete solution to update this section, so if u want any cdma set unlock just open this page and get easy solution here. so share ur views.
The Following 8 Users Say Thank You to compue For This Useful Post:
Old 11-28-2009, 11:22   #7 (permalink)
Member: 275643
Thanks Meter: 360
now i'm watching there that solution of v-jazz not clear to all so here i give here full complete procedure to unlock huwei 5589, i tested it, and then i give here-
first u download the file-http://www.ziddu.com/download/753154...kfile.rar.html
first u put this file in memory card,
now put the virgin sim in set and press power button to put set on.
now dial ##497613 and press green button.
now a menu open it show hanset, system test, rf test, sd download and s/w version.
now select SD Download
now press ok and in lcd white display show and process start.
after 100% it show APP Dload Failed.
now remove battery from set, and put it again.
now turn on set and enjoy unlocking.
this is the first set which is unlocked without any data cable and i again want thanks to chikkan which done wonderfull job.
The Following 14 Users Say Thank You to compue For This Useful Post:
Old 11-28-2009, 11:27   #8 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 62
can you post here solution of usb divice not recocnized in lg sets during upgradation.
Old 11-28-2009, 11:32   #9 (permalink)
Member: 275643
Thanks Meter: 360
dear it charging jack problem, when a blink set come and we flash it via com, then we try to update we see that charging jack is bad so only solution use original cable ca101 and change original jack.
The Following User Says Thank You to compue For This Useful Post:
Old 11-28-2009, 11:46   #10 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 62
but why only few sets having this problem i change the connector and components but problem not solved.
The Following User Says Thank You to mayank bajaj For This Useful Post:
Old 11-28-2009, 12:22   #11 (permalink)
Member: 1152995
Thanks Meter: 51
AFTER WHITE LIGHT NO ONE HAVE SOLUTIONSSS
SOME PHONES HAVE WHITE LIGHT DURING SAME Pro.
Old 11-28-2009, 15:37   #12 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
This is the problem of rx, tx supply but it is controlled by the cpu and one just cant do much about it.
Old 11-29-2009, 10:52   #13 (permalink)
Member: 275643
Thanks Meter: 360
the set huawei 5589 which i unlocked total software and hardware version is follow-
PRL:10
ESN:90106706
SW:HWC5589MV03
HW:Ver.C
BREW:3.1.5.145
The Following 2 Users Say Thank You to compue For This Useful Post:
Old 11-29-2009, 12:33   #14 (permalink)
Member: 275643
Thanks Meter: 360
sicne some queries are coming that some handset of v-jazz 5589 show white display after unlocking, if there are different hardware version then it may be happens, i upload the version which i unlock, this may be useful for all members and if anybody want try to unlock then this may help, also since solution come late and maximum set unlock very few sets to be unlock, if more set come, and version may different i 'll upload in future.
Old 11-29-2009, 19:32   #15 (permalink)
Member: 942210
Sonork: 1511
Thanks Meter: 91
haier c1000 conn. with et-box com port 2 & download the dumpflash file so restore nv 99% & fail
help me plzzzzzz
The Following User Says Thank You to parth gupta For This Useful Post:
[IMG] code is Off
All GSM & CDMA Mobile Hardware and Software Solution Here bunty2008 GSM Mobile Links 5 05-16-2018 11:24
Nokia N95 / 8gb Headset Not working, Tested Solution here basilbaby Nokia Hardware & Hardware Repair 9 07-02-2009 20:12
use second hand uem on working pcbs solution here meo786pk Nokia Hardware & Hardware Repair 0 10-04-2007 05:43
Page generated in 0.26864 seconds with 10 queries
