Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-23-2010, 18:01   #1 (permalink)
Member: 273834
Thanks Meter: 68
5130 cs help
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6
Box Serial Number: C00019DF
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19
Initializing security card...
Card Serial Number: D2000466
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.04v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.75v PASSED
VBAT Voltage 0.58v PASSED
VBAT Voltage 4.81v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.88v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
MCU Version V 06.94
MCU Date 21-07-09
Product RM-495
Manufacturer (c) Nokia
IMEI 356053032218686
Mastercode 7261344023
IMEI Spare 3A65500323126808
IMEI SV 3365500323126848F2000000
PPM V 06.94, 21-07-09, RM-495, (c) Nokia , EL
CNT Content: el_blu, V 06.94, 21-07-09, RM-495, (c) Nokia ,
PSN IBW592924
Product Code 0572176
Module Code 0204024
Basic Product Code 0567773
PSD 0000000000000000
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 2000
RFIC 06540601
DSP ICPR72_09w04
LCD SEIKO
BT 2222-143C
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Bypassing SX4...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 07E001134A0A7E56BC560C7C258A364E9A896CBF
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Testing TX2 Line...
Prepare phone failed with message -> TX2 Test Failed! Check cable or yellow TX2 Adapter!
Failed to Write PM -> Failed to Boot / Prepare Phone
MCU Version V 06.94
MCU Date 21-07-09
Product RM-495
PSN IBW592924
Module Code 0204024
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 2000
RFIC 06540601
DSP ICPR72_09w04
LCD SEIKO
BT 2222-143C
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Bypassing SX4...
Booting RAP...
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR
Prepare phone failed with message -> Not found required CMT Algorithm
Selftests to proceed: 29
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_LCD_TEST
Passed ST_LPRF_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_RADIO_TEST
Passed ST_BACKLIGHT_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_HOOKINT_TEST
Passed ST_TAHVOINT_TEST
Passed ST_BTEMP_TEST
Passed ST_IIC_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_SLEEPCLK_FREQ_TEST
Failed ST_CDSP_SLEEPCLOCK_FREQ_TEST
Failed ST_CDSP_RF_BB_IF_TEST
Failed ST_CDSP_RF_SUPPLY_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Failed ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 29, Tests passed: 23, Tests not passed: 6
Old 02-23-2010, 18:07   #2 (permalink)
Hell-GSM's Avatar
Member: 112131
Sonork: 1582257
Thanks Meter: 80
@TALIAT
What is the problem??? Check the phone with a SIM CARD.. And post here what happens when your turn it on!!!
Best Regards!!!
Old 02-23-2010, 21:32   #3 (permalink)
Member: 273834
Thanks Meter: 68
I AM SO SORRY THIS THE PHONE LOG
MCU Version V 06.65
MCU Date 01-04-09
Product RM-495
IMEI 355212037178607
Mastercode 3232132160
IMEI Spare 3A55120273716800
IMEI SV 3355120273716830F2000000
PPM V 06.65, 01-04-09, RM-495, (c) Nokia , SSA
CNT Content: ssa_c_blu, V 06.65, 01-04-09, RM-495, (c) Nokia ,
PSN IMN063284
Module Code 0204024
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 2000
RFIC 06540601
DSP ICPR72_09w03
LCD SHARP
BT 2222-143C
Failed to read info -> Failed to read SP info
Failed ST_KEYBOARD_STUCK_TEST
Passed ST_LCD_TEST
Failed ST_SIM_LOCK_TEST
Passed ST_IIC_TEST
Selftests done, Tests total: 29, Tests passed: 21, Tests not passed: 8
Old 02-23-2010, 22:33   #4 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
can you read the PM and post the file here?
Alex
Old 02-24-2010, 00:08   #5 (permalink)
Hell-GSM's Avatar
Member: 112131
Sonork: 1582257
Thanks Meter: 80
Failed ST_KEYBOARD_STUCK_TEST this means that the FBUS Cable is pressing one of the keys of the phones.. (happens a lot to me...) nothing to worry about....
Failed ST_SIM_LOCK_TEST Repair try to unlock again (rpl method), repair SD ( just to be sure.)....
Post the PM file and let moulnisky do his magic!!!!!
BestRegards!!!!!!
5130 cs who solve my problem plz help me? neeraj1st MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-22-2010 15:31
5130 CS ( Failed ST_SECURITY_TEST ) need help moulenisky [ Solved ] alkhaleejmobile Cyclonebox 8 01-03-2010 20:12
5130 cs lost 20+20+30 credits dapinderjit Universalbox 3 12-12-2009 17:58
How solusion 5130 cs memo2x MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 10-31-2009 15:58
5130 cs Babyunlocker Cyclonebox 5 10-24-2009 07:43
Page generated in 0.19155 seconds with 9 queries
