Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 02-02-2020, 12:50   #1 (permalink)
Member: 2946079
unlocking p10 bootloader: phone not found
Hello, I bought credits for unlocking bootloader of my Huawei p10 plus and installed the drivers and hcu client.
Then I connected the phone to my pc and put it in manufacture mode.
When I click "Read phone info", I get the error message "phone not found!"
Read phone info
2020-01-31 18:27:14.451 Autodetect COM port and phone type start!
2020-01-31 18:27:14.464 Compatible COM ports not found!
2020-01-31 18:27:14.473 ERROR!
Phone not found !
Old 02-02-2020, 12:53   #2 (permalink)
Member: 1591394
Thanks Meter: 552
u installed drivers corectly ?
check device menager
Old 02-02-2020, 13:10   #3 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
what about phone ?
build number .
The Following User Says Thank You to solgeo For This Useful Post:
Old 02-02-2020, 13:14   #4 (permalink)
Member: 1591394
Thanks Meter: 552
u can see he cant detect phone, probably drivers are not installed
Old 02-02-2020, 13:27   #5 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
yes just needed install HiSuite
and turn on Manufacture mode
but ... warning!
HCU or Dc-Unlocker not read bootloade new patch ( 8 android)
Old 02-03-2020, 09:18   #6 (permalink)
Member: 2946079
I have installed the drivers and also HiSuite but Hisuite does not find the phone as well. When phone is in MTP mode, my computer detects the phone correctly and I can access the files and in device manager is no error (only hisuite and HCU client don't find it).
Old 02-03-2020, 09:30   #7 (permalink)
Member: 2946079
Originally Posted by solgeo View Post
what about phone ?
build number .
Build-No.: VKY-L09C432B185
Android 7.0
Old 02-03-2020, 09:46   #8 (permalink)
Member: 1591394
Thanks Meter: 552
bro check if u have in manufacturer mode pcui and dbadapter in device menager com ports
Old 02-03-2020, 10:15   #9 (permalink)
Member: 2946079
In manufacturer mode I only find "VKY-L09" under other devices in the device manager (and with exclamation mark)
Under Com ports I find nothing new...
Old 02-03-2020, 11:30   #10 (permalink)
Member: 1591394
Thanks Meter: 552
So phone is not in manufacturer mode, unplug cable use code dial for menu and select manufacturer mode, pług cable
Old 02-03-2020, 11:39   #11 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
Android 7.0
Its old patch very good
Qualcomm and HiSilicon: *#*#2846579#*#*
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode
Needed install and open port
Old 02-03-2020, 12:37   #12 (permalink)
Member: 2946079
ProjectMenu
1 Background setting
2 USB ports setting
yes, I did this already and the manufacture mode is definitely activated (only then the device manager shows VKY-L09 under other devices. When it is in MTP Mode, it shows the phone under portable devices)
What do you mean by
Old 02-03-2020, 14:11   #13 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
Old 02-03-2020, 14:21   #14 (permalink)
Member: 2946079
I also tried it on the computer of my wife and it shows the same problem...
Old 02-03-2020, 15:03   #15 (permalink)
Member: 2023196
Thanks Meter: 1,892
Right click on your device in device manage, select uninstall, reconnect to pc, put it in manufacture mode, it should reinstall drivers automatically if hisuite is installed. I suspect other drivers were installed or there is something wrong with manufacture mode insertion on mobile itself.
The Following User Says Thank You to Namelocked For This Useful Post:
Page generated in 0.21449 seconds with 8 queries
