Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 05-11-2020, 04:55   #1 (permalink)
newfoundghori's Avatar
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
redmi note 5 flashing. [SOLVED]
hi,
team pls how to flash this using firm,ware from support,
i already download the file from support
but theres noting happen when i click flash.
problem of my phone mi account
android 9 muiu 11
i download downgrade fimware from support
Old 05-11-2020, 05:31   #2 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
Reading GPT[4]Ok
Phone Information.....
Model : Redmi Note 5
Brand : xiaomi
Android Ver : 9
Miui Ver : V11
Manufacturer : Xiaomi
Device : whyred
Mod_device : whyred_global
Display ID : PKQ1.180904.001
Security Patch : 2019-11-05
Kernel ID : 2019-11-05
Fingerprint : xiaomi/whyred/whyred:9/PKQ1.180904.001/V11.0.3.0.PEIMIXM:user/release-keys
ro_product_hardware :
sys_hardware_version :
Reading GPT[4]Ok
Operation : MiAccount
Remove MiAccount[Erase Method]
Processing...
Backing up Partition for safety...Ok
Scanning Patching address...
> Patching address detected [PATCHED]
> Patching address detected [PATCHED]Done!!
Total Items patched : 3
Successfully patched address..Ok
All Done
Elapsed Time : 00:00:30
Old 05-11-2020, 12:24   #3 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Android 9 Not supported for disable mi account,
You need to downgrade it to Android 8,
After Patch Mi Account by EDL, Enable ADB and Connect USB cable,
Do not Connect Wifi or Mobile Data
From the top right of the exe Select Connection: ADB, and Disable Mi Account by ADB
Best Regards | Hydra Team
Old 05-11-2020, 14:41   #4 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Originally Posted by newfoundghori View Post
hi,
android 9 muiu 11
Good, in the hydra tool support you have some guides in pdf, which tells or explains how to downgrade the xiaomi or how to unlock the bootloader of that xiaomi model you are asking, once the bootloader is unlocked, it is the most effective method to remove semi-permanent the micloud account is through the TWRP, any questions you have do not hesitate to write again in this same thread, thank you very much.
The Following User Says Thank You to Franky_36 For This Useful Post:
Old 05-12-2020, 04:42   #5 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
Originally Posted by Hydra Tool View Post
Hello,
i mean boss how to flash using hydra and firmware from support
i need to downgrade it to remove account.
Old 05-12-2020, 10:53   #6 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
hi sir theres no option on raw xml custom and write patch on build 67 qualcom tool
Old 05-12-2020, 15:01   #7 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, if you can, you also have to update all modules and all base updates, you are not aware of all hydra tool updates.
Once updated both modules and update base as well as extra files, we enter the qualcomm module, flash tool section and we have two options:
1. Auto Scan Raw / Patch XML (we look for the firmware folder that we want to flash and it automatically looks for us or finds the rawprogram.xml and the patch.xml).
1.
2. Manual Select Raw / Patch XML (you must manually select the raw and patch.xml).
2.
The Following 2 Users Say Thank You to Franky_36 For This Useful Post:
Old 05-13-2020, 07:35   #8 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
this the file hthat i download from support
unlock bootloder firmware file.
whyred_images_V9.5.22.0.OEICNFA_20180626.0000.00_8 .1_cn_49a8c2738f
whe i extract there is no xml file.
Old 05-13-2020, 09:08   #9 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, here I leave you the link to download, any problem or question that arises, write again, thank you very much.
https://www.androidfilehost.com/?fid...26312261807051
Old 05-15-2020, 12:31   #10 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
thank u so much flash done..
Fastboot Flashing...
-storsec(storsec.mbn) Ok
-storsecbak(storsec.mbn) Ok
-rpm(rpm.mbn) Ok
-rpmbak(rpm.mbn) Ok
-hyp(hyp.mbn) Ok
-hypbak(hyp.mbn) Ok
-pmic(pmic.elf) Ok
-pmicbak(pmic.elf) Ok
-cmnlib(cmnlib.mbn) Ok
-cmnlibbak(cmnlib.mbn) Ok
-cmnlib64(cmnlib64.mbn) Ok
-cmnlib64bak(cmnlib64.mbn) Ok
-abl(abl.elf) Ok
-ablbak(abl.elf) Ok
-devcfgbak(devcfg.mbn) Ok
-devcfg(devcfg.mbn) Ok
-tz(tz.mbn) Ok
-tzbak(tz.mbn) Ok
-mdtpsecapp(mdtpsecapp.mbn) Ok
-mdtpsecappbak(mdtpsecapp.mbn) Ok
-keymaster(keymaster.mbn) Ok
-keymasterbak(keymaster.mbn) Ok
-bluetooth(BTFM.bin) Ok
-xbl(xbl.elf) Ok
-xblbak(xbl.elf) Ok
-misc(misc.img) Ok
-dsp(dspso.bin) Ok
-mdtp(mdtp.img) Ok
-splash(splash.img) Ok
-persist(persist.img) Skipped
-modem(NON-HLOS.bin) Ok
-boot(boot.img) Ok
-recovery(recovery.img) Ok
-cache(cache.img) Ok
-system(system.img) Ok
-vendor(vendor.img) Ok
-cust(cust.img) Ok
-userdata(userdata.img) Ok
All Done
Elapsed Time : 00:04:45
The Following User Says Thank You to newfoundghori For This Useful Post:
Page generated in 0.18162 seconds with 8 queries
