02-02-2022, 11:54 | #91 (permalink) |
Freak Poster Join Date: Mar 2018
Member: 2824019 Status: Offline Thanks Meter: 83 | Selected model: OPPO CPH2001 (Oppo F15) Operation: Wipe Partitions Software version: 2.11 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xCCF6374D, 0x4D17A22C, 0x50D4A260, 0x53454D32 Get Chip ID... [MT6771] Get SOC ID... [AC81A0F827DF72F6B741B147AAB1DD551DB453B5BDAB5FB4B2 B24FAE0305A2B9] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM5V7001DM-B621 (1200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM5V7001DM-B621 UFS_FWVER : 1200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6771 Board Platform : MT6771 Build ID : QP1A.190711.020 Build Date : Thu Dec 10 21:11:45 CST 2020 Display ID : QP1A.190711.020 release-keys Security Patch : 2020-12-05 Version SDK : 29 Version Release : 10 Version Codename : REL Format "nvdata" partition... OK Format "nvram" partition... OK Format Partitions done! Selected model: OPPO CPH2001 (Oppo F15) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xCCF6374D, 0x4D17A22C, 0x50D4A260, 0x53454D32 Get Chip ID... [MT6771] Get SOC ID... [AC81A0F827DF72F6B741B147AAB1DD551DB453B5BDAB5FB4B2 B24FAE0305A2B9] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM5V7001DM-B621 (1200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM5V7001DM-B621 UFS_FWVER : 1200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6771 Board Platform : MT6771 Build ID : QP1A.190711.020 Build Date : Thu Dec 10 21:11:45 CST 2020 Display ID : QP1A.190711.020 release-keys Security Patch : 2020-12-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 86xxxxxxxxxxxxx IMEI 2: 86xxxxxxxxxxxxx Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
02-06-2022, 07:57 | #92 (permalink) |
Freak Poster Join Date: Sep 2019 Location: sarbandar Age: 29
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM95 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.22000.1] Device found at COM96 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x52ADDB48, 0x9616F20F, 0x88ABCAAC, 0x47210B8E Get Chip ID... [MT6765] Get SOC ID... [935C80F9C5913C60F34BDECFA6354A7D6E5CA0FB6539BB1F43 90B91CA3B39943] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100515836334D4200A6E3E426B7F3 Load EMI config from database [DB VER: 192 DB DATE: 01-21-2022] OK [1] Trying EMI [9C47C7D7, C27E8331, CCFE52E9, 24F30B91, C26ECB0F, 3044B25D, D25991E9, 947DFBD0] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100515836334D4200A6E3E426B7F3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read partition "nvram"... error(8), skip Read partition "nvdata"... error(2), skip Load NVDATA file error! |
02-06-2022, 07:58 | #93 (permalink) |
02-06-2022, 13:34 | #94 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Erase FRP Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0632A3EC, 0xFE28BD81, 0xA1BDC681, 0x7ECD7B8E Get Chip ID... [MT6765] Get SOC ID... [BC8FDFF95222BEA696D73D7DB062BD56A60D48EE882AA04A89 900E7822880B2D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203ADED07B9B62F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4203ADED07B9B62F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107F Product Name : S96116AA1 Product Device : a10s Product Board : S96116RA1 Board Platform : MT6765 Build ID : RP1A.200720.012 Build Date : Thu Aug 5 14:52:42 +07 2021 Display ID : RP1A.200720.012.A107FXXU8CUH1 Security Patch : 2021-07-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A107FXXU8CUH1 Read partition "frp"... OK Read partition "persistent"... OK Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Samsung_SM-A107F%20(Galaxy%20A10s)/FRP_BACKUP_(2022-2-6_4-31-54)/"directory Format "frp" partition... OK Format "persistent" partition... OK Writting FRP data... OK Erase FRP done! |
02-06-2022, 13:37 | #95 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0632A3EC, 0xFE28BD81, 0xA1BDC681, 0x7ECD7B8E Get Chip ID... [MT6765] Get SOC ID... [BC8FDFF95222BEA696D73D7DB062BD56A60D48EE882AA04A89 900E7822880B2D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203ADED07B9B62F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4203ADED07B9B62F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107F Product Name : S96116AA1 Product Device : a10s Product Board : S96116RA1 Board Platform : MT6765 Build ID : RP1A.200720.012 Build Date : Thu Aug 5 14:52:42 +07 2021 Display ID : RP1A.200720.012.A107FXXU8CUH1 Security Patch : 2021-07-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A107FXXU8CUH1 Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 35341811****** IMEI 2: 35341911****** Repairing IMEI... IMEI 1: 8657100****** IMEI 2: 8657100****** Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Patch CERT Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0632A3EC, 0xFE28BD81, 0xA1BDC681, 0x7ECD7B8E Get Chip ID... [MT6765] Get SOC ID... [BC8FDFF95222BEA696D73D7DB062BD56A60D48EE882AA04A89 900E7822880B2D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203ADED07B9B62F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4203ADED07B9B62F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107F Product Name : S96116AA1 Product Device : a10s Product Board : S96116RA1 Board Platform : MT6765 Build ID : RP1A.200720.012 Build Date : Thu Aug 5 14:52:42 +07 2021 Display ID : RP1A.200720.012.A107FXXU8CUH1 Security Patch : 2021-07-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A107FXXU8CUH1 Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Patch CERT [NVDATA]... OK Patch CERT [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! If your phone after repair keeps rebooting - use wipe data option. |
02-06-2022, 13:38 | #96 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x52ADDB48, 0x9616F20F, 0x88ABCAAC, 0x47210B8E Get Chip ID... [MT6765] Get SOC ID... [935C80F9C5913C60F34BDECFA6354A7D6E5CA0FB6539BB1F43 90B91CA3B39943] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100515836334D4200A6E3E426B7F3 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100515836334D4200A6E3E426B7F3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107F Product Name : a10sxx Product Device : a10s Product Board : S96116CA1 Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Tue Mar 9 10:31:35 KST 2021 Display ID : QP1A.190711.020.A107FXXS8BUC1 Security Patch : 2021-03-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : A107FXXS8BUC1 Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 111111111111119 IMEI 2: 111111111111119 Repairing IMEI... IMEI 1: 8657100******* IMEI 2: 8657100******* Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! |
02-07-2022, 14:24 | #97 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | hi i have oppo 2239 a54 after repair phone unlocking bootloader and phone say "Corrupted image (boot / recovery) prevents the system from booting normally" i want a solution please help |
02-10-2022, 09:17 | #98 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021)) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... canceled Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021)) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... canceled Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021)) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA601B303, 0x121B677B, 0x38642BD2, 0x7517BD1F Get Chip ID... [MT6768] Get SOC ID... [E50A88CDFC0F7722A5B2249C3267FFE1EE1F45BAB31B362150 4189114BA32AC2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03105AC969A701 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03105AC969A701 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : biloba Product Name : biloba_global Product Device : biloba Product Board : biloba Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Wed Nov 3 10:40:34 CST 2021 Display ID : RP1A.200720.011 Security Patch : 2021-10-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.8.0.RCUMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 86*********** IMEI 2: 86*********** Repairing IMEI... IMEI 1: 865********* IMEI 2: 865********* Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021)) Operation: Patch CERT Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA601B303, 0x121B677B, 0x38642BD2, 0x7517BD1F Get Chip ID... [MT6768] Get SOC ID... [E50A88CDFC0F7722A5B2249C3267FFE1EE1F45BAB31B362150 4189114BA32AC2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03105AC969A701 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03105AC969A701 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : biloba Product Name : biloba_global Product Device : biloba Product Board : biloba Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Wed Nov 3 10:40:34 CST 2021 Display ID : RP1A.200720.011 Security Patch : 2021-10-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.8.0.RCUMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Format "parameter" partition... OK Unlock bootloader... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! If your phone after repair keeps rebooting - use wipe data option. |
02-11-2022, 07:25 | #99 (permalink) |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Oppo CPH2119 Oppo F17 Pro after repair imei my mobile bricked (the current image(boot/recovery)have been distroyed and can not boot) plz gide me how can we do it ok ? |
02-11-2022, 07:26 | #100 (permalink) |
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Oppo F17 Pro distroyed image file Oppo CPH2119 Oppo F17 Pro after repair imei my mobile bricked (the current image(boot/recovery)have been distroyed and can not boot) plz gide me how can we do it ok ? |
02-11-2022, 20:16 | #101 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | hey hi please reflash your phone with ofp file device will be start normally and don't be worry imei is changed after flash read imei and see whats imei show you |
The Following User Says Thank You to validvalizadeh For This Useful Post: |
02-12-2022, 08:55 | #102 (permalink) |
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | wipe&FRP Selected model: Nokia TA-1334 (Nokia G10) Operation: Erase FRP Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM75 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM75 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8AD96BFF, 0x11EA47B8, 0x72243C6D, 0xC6821193 Get Chip ID... [MT6765] Get SOC ID... [860C2096345C0B0145D9D8203259E097F2197845D0F065B1C7 D2E69616268DD9] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x880103534C443132385574971AB1288B Load EMI config from database [DB VER: 192 DB DATE: 01-21-2022] OK [1] Trying EMI [BF21799C, 935A942F, CB03FF37, E46B4943] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x880103534C443132385574971AB1288B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x1CCF000000 (115.23Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Nokia_TA-1334%20(Nokia%20G10)/FRP_BACKUP_(2022-2-11_23-47-56)/"directory Format "frp" partition... OK Writting FRP data... OK Erase FRP done! nokia G20 |
02-12-2022, 11:29 | #103 (permalink) |
Freak Poster Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 93 | Oppo A7x Reset OPPO ID done Selected model: OPPO PBBM00 (Oppo A7x) Operation: Reset Realme/OPPO ID Software version: 2.11 This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM39 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5D809167, 0x6CE4A258, 0x60AC03A9, 0xB40E2122 Get Chip ID... [MT6771] Get SOC ID... [3A268157550A5C72ABD6BD097DFC30DF47825BB60E72B8454A 57B099CB6C5AEA] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445636444D4202EC98C496853B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445636444D4202EC98C496853B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Manufacturer : OPPO Product Board : oppo6771_18011 Board Platform : MT6771 Build ID : PPR1.180610.011 Build Date : Tue Jan 12 19:32:15 CST 2021 Security Patch : 2021-01-05 Version SDK : 28 Version Release : 9 Version Codename : REL Backup partitions: Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Read Write Counter[WC]... 1033143 OK Backup RPMB... OK Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/OPPO_PBBM00%20(Oppo%20A7x)/REALME_RESET_BACKUP_(2022-2-12_12-0-23)/"directory Format "userdata" partition... OK Reset stage 1... Ok Account Name: ********* UserId: ********* DeviceId: 86******* Reset stage 2... OK Reset stage 3... OK Reset Realme account done! |
02-13-2022, 11:21 | #104 (permalink) |
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Selected model: Alcatel 5033G (Alcatel 1) Operation: Read Codes Software version: 2.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x778DAAE2, 0xDE70EBF5, 0x04EB1C0F, 0xA466F030 Get Chip ID... [MT6739] Get SOC ID... [985E3FF9E5F1E05F3BCCADFFE954C1669730AD1D5DC82621C0 19189867898FD2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100464536324D42038D5607BEA6B7 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100464536324D42038D5607BEA6B7 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0040000000 (1.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : TCL Product Manufacturer : TCL Product Model : 5033G Product Name : 5033G Product Device : U3A_PLUS_4G Product Board : MT6739 Board Platform : MT6739 Build ID : O11019 Build Date : Mon Aug 2 18:05:31 CST 2021 Display ID : Nougat Security Patch : 2021-08-05 Version SDK : 27 Version Release : 8.1.0 Version Codename : REL Firmware Version : v7L81-0 Read security partition from phone... OK Load security file error! not working unlocking nework locked |
02-14-2022, 19:04 | #105 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | Realme C3(RMX2027) IMEI Repair Done Selected model: Realme RMX2027 (Realme C3) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MTK USB Port,usb2ser.sys,3.0.1504.0] Device found at COM96 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB776341D, 0xC1F9712E, 0xB0106820, 0x6A7F9080 Get Chip ID... [MT6768] Get SOC ID... [485EB7790784E672B1C18576A1D8714CB497FD0B627EF44D50 49893268044555] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A684339615033015164BA8BC623 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A684339615033015164BA8BC623 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6769 Board Platform : MT6768 Build ID : QP1A.190711.020 Build Date : Thu Jun 10 22:23:15 CST 2021 Display ID : QP1A.190711.020 release-keys Security Patch : 2021-06-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 862752041396535 IMEI 2: 862752041396527 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
