03-27-2005, 21:35 | #9 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ro Age: 43
Member: 126197 Status: Offline Thanks Meter: 26 | details! tell exactly what happend when you put in the charger ! ! ! 1:nothing happend 2:not charging displayed imediatly 3:charging appears but battery remain empty choose one so I can help ! |
10-24-2005, 14:36 | #12 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190138 Status: Offline Thanks Meter: 0 | chack ur bat and resold ur battery terminels and chack the fuse and charing coil too . put a jumper from " r22 " to small resistor near by cobba ic . and then chack ur set . If fault is not removed then give heat charging ic with paste. If fault'll not remove then change ur charging ic . Thanks |
11-08-2005, 10:36 | #13 (permalink) |
Insane Poster Join Date: Aug 2005 Location: philippines Age: 48
Member: 169368 Status: Offline Thanks Meter: 3 | thanks for all your help, i cleaned charging pin and pcb and the unit is working fine. but i would like diagram of the diagram u are talking about mr afzal. i am just a begginer and it will be very helpful to me, also the fuse for the charging coil. thank you for all your help. |
11-08-2005, 10:39 | #14 (permalink) |
Member: 169368 Status: Offline Thanks Meter: 3 | by the way the problem i had was when i put in the charger it charges for a while then, the message was "not charging". this so that if others have problems, this might help them. tnx |
3210 not charging displayed | Vicky | Nokia Hardware & Hardware Repair | 42 | 11-03-2008 11:20 |
3210 not charging with car-charge | fiZ | Nokia Hardware & Hardware Repair | 4 | 10-18-2002 14:52 |
3210 not charging | platte | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 22 | 02-06-2002 22:40 |
3210 not charging! | aspog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 07-06-2001 08:45 |
3210 not charging | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-06-2001 21:41 |
