11-08-2001, 15:08 | #1 (permalink) |
Insane Poster Join Date: Oct 2001 Location: the netherlands
Member: 6950 Status: Offline Thanks Meter: 4 | 3210 not charging |
The Following User Says Thank You to platte For This Useful Post: |
11-08-2001, 20:32 | #3 (permalink) |
No Life Poster Join Date: Dec 2000 Location: UK
Member: 2868 Status: Offline Thanks Meter: 514 | Hi mate<br />The small SMT component between both contacts for the battery is a varistor. First check the conectors if they are brocken (a crack apears between the conector and the bord). If they are OK then change the varistor.<br />Best regards<br />Daniel |
The Following User Says Thank You to Freestyler2000 For This Useful Post: |
11-08-2001, 23:17 | #4 (permalink) |
Junior Member Join Date: Jul 2001 Location: UK
Member: 5180 Status: Offline Thanks Meter: 0 | The phone also will not charge if there is a software problem i.e. contact service. Try a charged battery from another phone to test for this and/or flash the phone. |
11-28-2001, 07:05 | #5 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Philippines
Member: 4215 Status: Offline Thanks Meter: 1 | Hi Mate. I have the same problem with my 3210. I got this problem when I used the 8210 charger on my cell. I have checked all the possible damaged components (F100, R101, L100.., C146, etc..) including the varistor but I still get the same problem; no charging indicator even I use other charger. What could be the other solution for this? <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> |
01-17-2002, 20:37 | #6 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | Even i got the same problem on my 3210 v03.00 . When i insert charger the battery icon on the right will start blinking . If i remove batt. and leave charger on it will make a beep every 2 seconds and the screen will have a line in the middle . I didnt check my mobile to c whats wrong with it , i just charge my batt. with my mum's mobile . The problem of the mobile started when i changed batt. , i think it was my fault but 'cause i touched the connectors of the batteries . i think i shorted something . |
01-18-2002, 10:56 | #7 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | I have same problem on a 3210 after upgrade from 5.26 to 6.00 with logs (about a week after). says "charger not connected". NetMonitor test 20 shows charging status as:<br />TmpFa which i see as battery NTC mesaurements failed, what does this mean?<br />tried different charger, battery and charging block with same outcome <img src="frown.gif" border="0"> <br />tia |
01-18-2002, 11:25 | #8 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | Dave : propably you have a bad soldered contacts of battery, or varistor is defective. other: check fuse, is it on keyboard side down. Measure with multimeter for shorcircuit of charger connector. If there is a shortcircuit, termistor is defect, is it near fuse. If nothing helps, charging IC may be wrong. Is a small BGA near CCONT<br />T. <FONT COLOR="#ffff00" SIZE="1">[ 19 January 2002 19:45: Message edited by: ARS ]</font> |
01-19-2002, 18:02 | #9 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Mumbai [India]
Member: 3503 Status: Offline Thanks Meter: 2 | Hi Ars,<br />Thanks just repaired one 3210 not charging problem in my 3210<br />It was varistor faulty i replaced with good phone<br />where can i get this varistor, because i have to put back in my good phone.<br />Regards.<br /> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
01-21-2002, 01:22 | #12 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | I got the same problem with my 3210 . When i insert a charger and switch to Netmonitor(20) the C will start displaying numbers . So i guess that it is finding the charger , but it is not charging ! . Any1 knows why ? pls help im tired of switching batteries into another 3210 . Thanks |
01-22-2002, 01:09 | #13 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | [quote]Originally posted by ARS:<br /><strong>Dave : propably you have a bad soldered contacts of battery, or varistor is defective.<br />T.</strong><hr></blockquote> <br />hey, many many thanks <img src="smile.gif" border="0"> ive never messed with the hardware side before but when you said solder contacts and checked. sure enough theyd broken! quick solder phone works fine, thank you again <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
01-25-2002, 22:33 | #14 (permalink) |
Junior Member Join Date: Dec 2001 Location: poland
Member: 7771 Status: Offline Thanks Meter: 0 | Hi i got the some problem with my 3210.If you have netmonitor in test 20 when is "BTemp"-second line for up -when is not T+ but T- <br />in phone "unter dem battery" 2 metal sticks not connecting .<br />sorry for my english and that germany language.sorry |
3210 not charging displayed | Vicky | Nokia Hardware & Hardware Repair | 42 | 11-03-2008 11:20 |
3210 not charging with car-charge | fiZ | Nokia Hardware & Hardware Repair | 4 | 10-18-2002 14:52 |
Nokia 3210 Not Charging | Bemsas | Nokia Hardware & Hardware Repair | 1 | 11-03-2001 20:04 |
3210 not charging! | aspog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 07-06-2001 08:45 |
3210 not charging | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-06-2001 21:41 |
