Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-02-2001, 06:47   #1 (permalink)
Member: 4215
Red face 3210 not charging!
Help! My phone won't charge. battery is ok. I tried the charger in other fone and is working fine. Dunno what happened, What could be the problem.
Old 07-02-2001, 07:57   #2 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
Post
Can you give me more detai??
1. No Charging displayed on LCD
2. No respons from phone
Or else??
rgds
Old 07-02-2001, 14:41   #3 (permalink)
Member: 4215
Post
yeah, no charging display on the LCD. any help would be appreciated. thanks for the replay bbband.
Old 07-02-2001, 15:51   #4 (permalink)
Member: 4675
Thanks Meter: 7
Post
check the battery connector, solder it well... this will work
Old 07-02-2001, 19:58   #5 (permalink)
Member: 2628
Post
If it does not work check the cond by the carger connectior on ur phone!!
Old 07-02-2001, 21:38   #6 (permalink)
Member: 5006
Thanks Meter: 2
Post
I can give you the connector that will make it work for £10. Let me know. You simply take the old one out and put the new one in. This is a common problem. No soldering required.
Old 07-02-2001, 23:26   #7 (permalink)
Member: 3718
Thanks Meter: 3
Post
SORRY BUT A NEW BLOCK CONECTOR AT THE BASE OF THE PHONE WILL NOT SOLVE THE PROBLEM (BY THE WAY THAT PRICE SHOULD BE LESS THAN A FIVER).
AS ONE PERSON HAS SAID SOLDERING WELL WILL CURE BUT NORMALLY IT IS THE LARGER OF THE TWO DIODES BETWEEN THE BATTERY CONECTORS THAT NEED REPLACING.
Old 07-03-2001, 02:36   #8 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
Post
Hi Aspog....
It is Hardware Problem, you can Check it by using Service Manual. There are some types of Charging Problem, and yours include one of it. You can Download it at
gsmfree.rulez.at
Note : Any Siemens Service Manual????
Rgds
Old 07-05-2001, 19:39   #9 (permalink)
rothmanns's Avatar
Member: 1544
Post
my charging problem is this.... if i plug in a charger... it doesnt say anything... .. nothing happens to the phone??? where is the problem there....
Old 07-06-2001, 06:23   #10 (permalink)
MDR
Member: 1272
Thanks Meter: 3
Post
change chargin pin
Old 07-06-2001, 08:45   #11 (permalink)
ARS
Member: 2721
Thanks Meter: 23
Post
Measure resistance on charging pins. I have this problem too, and i have a short circuit on charger contacts. A protection resistor (not fuse) make this short circuit. Chceck with service manual, you will find it.
3210 not charging displayed Vicky Nokia Hardware & Hardware Repair 42 11-03-2008 11:20
3210 not charging with car-charge fiZ Nokia Hardware & Hardware Repair 4 10-18-2002 14:52
3210 not charging platte Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 22 02-06-2002 22:40
Nokia 3210 Not Charging Bemsas Nokia Hardware & Hardware Repair 1 11-03-2001 20:04
3210 not charging ambot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-06-2001 21:41
Page generated in 0.18736 seconds with 9 queries
