11-30-2002, 04:28 | #61 (permalink) | |
Junior Member Join Date: Nov 2002 Location: luzon Age: 59
Member: 17870 Status: Offline Thanks Meter: 0 | Quote:
Thanks too you all!!! | |
11-30-2002, 07:01 | #62 (permalink) |
Freak Poster Join Date: Nov 1999
Member: 683 Status: Offline Thanks Meter: 0 | cable for 5510 ui ext Hi all, Here is how to make the prog to work. Get an fbus cable like the one you use for logomanager. Take off the screw and interchange the rx and tx wires. Run the software. You will see in the message box "Flash DSP progress report". Switch the phone on and wait for "EXT UI ready" message. Select initdisk and initdata files. Click step-2 and wait to finished flashing (approx 12minutes). Click Default settings. Click step-3. Best regards |
11-30-2002, 09:17 | #63 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | @remle but the phone will auto shut off in 5 secs so what will i do?? should i click immediately the step 2 upon boot up of the phone?? what if the phone shuts off while the software is being run?? Thanks for the reply.. BR, Epic |
12-01-2002, 04:33 | #66 (permalink) |
Junior Member Join Date: Oct 2002 Age: 46
Member: 16758 Status: Offline Thanks Meter: 0 | This is the 100% Working Solution MBUS/FBUS switching 3310 Old chinese data cable modify the cable by 1 3 -> Head of the Phone 2 4 2 - Blue Wire 3 - Black Wire 4 - White Wire Run the software Connect a charger to the phone and follow the procedures of the software. Thanks to TAP GSM |
12-02-2002, 08:50 | #67 (permalink) | |
No Life Poster Join Date: May 2001 Location: Manila, Philippines Age: 53
Member: 4408 Status: Offline Thanks Meter: 5 | Quote:
After Step 1 (selecting ini & data file) Phone must be Off. - Now Connect Charger (Fast charger is advisable) - Don't Power On the Phone (phone will boot and only battery bar indicator will appear) - Then proceed clicking the Step 2 Button (11 min and 30secs approximately) - Step 3 | |
12-11-2002, 22:30 | #70 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Nokia Age: 44
Member: 11395 Status: Offline Thanks Meter: 3 | Hi, I have an autoswitching M/Fbus, if I cut the MBUS wire, will it be Fbus that works? Or how can modify the cable to work? I have same problem as remle, the phone works 5 seconds then off.. @ ed2k_2 I tried what you posted, but always ERROR01.. Help please.. Last edited by fadi79; 12-11-2002 at 22:41. |
12-14-2002, 08:10 | #73 (permalink) |
Junior Member Join Date: Mar 2002 Location: philippines Age: 58
Member: 9860 Status: Offline Thanks Meter: 0 | Downloaded Flash EXT_UI BoardV2.0 need help I'm new guys, need help! Already downloaded Flash EXT_UI Board V2.0 but there says in the installation package includes Extui_flash.cab, Set-up.exe etc.. but none found or im wrong! Please anyone correct me or just needed the file with those things! Thanx! Merry Christmas in advance to all! |
nokia 1300 when insert sim turn off after flash | Amar Man | Nokia Hardware & Hardware Repair | 1 | 10-25-2009 16:18 |
G5600 not powers on with sim while without sim powers on :( need help | the_frightener | LG | 1 | 03-20-2005 06:18 |
c55 when insert sim shuite off | demodamota | Siemens Hardware Repair Area | 1 | 01-11-2004 17:33 |
To all members making 5510 power on -insert sim-power off problem working 100% | KISHOMETO | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-16-2003 03:18 |
