11-06-2003, 21:51 | #106 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | Ok, I'm going to give it to with spoons then ! If you had done a simple search on this site for "Fbus cable" you would have found the following link to a 3310 schematic for F-bus cable right here ! Furthermore I can tell you that the red wire is normally the Mbus wire, so dont use that, cut it off. Use only the 3 others. The black is normally ground. The other too for TX and RX you will have to swicth them if it does not work in first try. You are trying to make a F-bus cable, why you write nonsense like "isolate fbus pins or remove them" From here you are on your own, can't give you more help now, it should be crytal clear from my point of view. Regards |
11-06-2003, 22:17 | #107 (permalink) |
Junior Member Join Date: Oct 2003 Location: Belgium
Member: 42333 Status: Offline Thanks Meter: 0 | @GSM Coolhawk Thx for the help..but I've seen all these topics.. still error 1 after switching wires..like you said I'll go further on my own. Will post result when I'll get there.. grz |
11-06-2003, 22:21 | #108 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @MATTI Have you remembered to connect the charger to the phone !!! This is nessesary you know, and also in this thread. Regards |
04-22-2004, 18:07 | #110 (permalink) | |
Junior Member Join Date: Mar 2004 Location: Finland-Tampere Age: 53
Member: 56990 Status: Offline Thanks Meter: 0 | Quote:
The password for those zip-files is www.ed2k.com.ph Yours, Rauli :-) | |
05-28-2004, 17:36 | #111 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | i got one 5510 i get ERROR03: EXT_UI DSP/NAND/AIC FAILED i flashed at least 5 times with both flashes available for DSP InitData_R060.a00 and also InitData_R061.a00... still same error... WBR Syed |
09-16-2004, 22:01 | #112 (permalink) |
Junior Member Join Date: Sep 2004 Age: 51
Member: 82343 Status: Offline Thanks Meter: 0 | Error03: Ext_ui Dsp/nand/aic Failed ERROR03: EXT_UI DSP/NAND/AIC FAILED I receive this after flashing my 5510. Any ideas anyone? Using format of 20 seconds for NAND, default settings for everything else. After hours of making a FBUS cable, I still cannot use this phone. |
11-18-2013, 22:53 | #113 (permalink) |
No Life Poster Join Date: Jun 2003 Location: ENGLAND Age: 53
Member: 30709 Status: Offline Thanks Meter: 45 | Yes I know it's been a long time since this thread was last replied to but we have a 5510 with the 5 sec booting issue and would require the software. Does anyone have it out there? Lying in a dusty folder collection, would appreciate it. Regards. |
nokia 1300 when insert sim turn off after flash | Amar Man | Nokia Hardware & Hardware Repair | 1 | 10-25-2009 16:18 |
G5600 not powers on with sim while without sim powers on :( need help | the_frightener | LG | 1 | 03-20-2005 06:18 |
c55 when insert sim shuite off | demodamota | Siemens Hardware Repair Area | 1 | 01-11-2004 17:33 |
To all members making 5510 power on -insert sim-power off problem working 100% | KISHOMETO | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-16-2003 03:18 |
