11-21-2004, 21:06 | #3 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | @gbada pls do search u will find slotion for this problem and chang fuse if nothing try to reflash if nothing reheat charging ic if nothing chang charging ic ******************Azam**************** |
11-22-2004, 05:11 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Location: GermanY
Member: 38922 Status: Offline Thanks Meter: 35 | Its a known Problem. First of all, flash a new Update with e.g twister, it will 8ß& ok, if not , check the Mechanic parts how azad writed down (above) GreetZ |
11-22-2004, 05:17 | #6 (permalink) |
Freak Poster Join Date: Aug 2004 Location: The great pakistan
Member: 79823 Status: Offline Thanks Meter: 26 | for haven sake ppl,this is a very commen problem of nokia fones,what is not charging?fone says not charging?or fone does not show any thing? in both cases it's hardware problem,FLASH FONE,is not the sulotion for evry thing, check fuse if ok then remove the cap located behinde the irda space or change it, Daanish |
11-22-2004, 05:26 | #7 (permalink) | |
Member: 38922 Status: Offline Thanks Meter: 35 | Quote:
Dear daan, i dont how you can so sure about it.. Please check your knowledge about the DCT3 - 2100 (NAM-2) BUGs. First of all, always Flash. Why should he waste the time with opening the fon, if that ain't a hardware problem..?? This is a Screenshot of Twister, look what Saras says: If is after Flash not ok, then he can start with checking hardware parts. Respect | |
2100 not charging help | bibhu | Nokia Hardware & Hardware Repair | 3 | 05-03-2005 15:14 |
2100 not charging | veli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-25-2005 21:35 |
2100 not charge after flash | abdoulaye | UFS2 + UFS3-Tornadoflasher | 1 | 11-26-2004 17:08 |
nokia 2100 not charging ???????// | moobile mafia | Nokia Hardware & Hardware Repair | 8 | 10-09-2004 11:27 |
2100 not charging after flash | fgl30 | UFS2 + UFS3-Tornadoflasher | 25 | 09-07-2004 15:45 |
