10-03-2005, 22:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | 5100 power on by itself when battrey is inserted... got this 5100 which had the power switch literally removed due to use and found it running around in the casing when i opened it up. thought it was an piece of cake... just soldered it back and as soon as battrey has been inserted it powered on by itself. Used another switch just in case and it still did the same. Now i had such a problem with a 6600 and someone mentioned that there maybe a problem with a UEM track that goes directly from the resistors under the switch. Is it the same here? thanks for any help al |
10-04-2005, 08:30 | #2 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Thessaloniki,Hellas Age: 44
Member: 33547 Status: Offline Thanks Meter: 17 | I suggest to change the power switch with a new one and also check the capacitors-resistors near the power switch. Always works for me |
X820 turns off and on again by itself when calling | L0lAj | Samsung Flashers, Software, Firmware. | 0 | 08-30-2007 16:12 |
motorola c975 powers on automatically when battery is inserted | djjoy | Motorola Hardware Repair | 0 | 05-02-2007 10:33 |
6600 powering on by itself when battrey is inserted.... switch has no effect at all | Burnt Cobba | Nokia Hardware & Hardware Repair | 4 | 04-11-2005 19:51 |
8310 powers up when battrey is inserted and wont power off normally | Burnt Cobba | Nokia Hardware & Hardware Repair | 6 | 07-28-2003 20:45 |
GD90 when battrey is inserted starts charging | Burnt Cobba | Panasonic | 5 | 07-02-2003 00:10 |
