12-20-2007, 21:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | 5200 keypaid ic change but still same remembe i m using 6600 lcd ic thanks in advance |
12-21-2007, 03:38 | #3 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 465901 Status: Offline Thanks Meter: 45 | as you said sometime some keys are working sometime other are working after changing keypad ic. So your fault definately lies in the keypad ic and the 6600 lcd ic is the same as of the 5200 keyapad ic you can interchange them there is no doubt.As your post says , i think your fault must be in the keypad ic not in the RAp Try with the brand new ic not with used ic, hope you will sucseed Good Luck |
12-21-2007, 06:21 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | brth replace the ic with new one and rember to use good paste to change ic [like orignal amteck flux volume 10cc]some time when we change ic it works for few hours but after few hours problem come again....this fult is also come through bad paste whic uyou use to change ic..... godd luck.. |
12-21-2007, 13:21 | #6 (permalink) |
Freak Poster Join Date: May 2006
Member: 278058 Status: Offline Thanks Meter: 81 | That is right! I had same problem in 6680 once. Key 4 was working each time I used even brand new IC's but came back. After reheating OMAP problem was solved. You try reheating RAP. |
12-22-2007, 15:45 | #9 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | NOW I GIVE U A SIMPLE SUGGESTION TAKE OUT IC FROM WORKING SET LIKE NOKIA 6600,N70 .THEN MOUNT ON THE 5200 THEN U CAN CONFIRM IT HAS IC PROBLEM OR ITS PROCESSER PROBLEM.IF IT WORKS THEN MOUNT NEW IC TO REPAIR ON WHAT U ALREADY TAKE THE IC .IF U HAVE A GOOD SKILL THEN U CAN REPAIR BOTH SETS OTHERWISE INSTEAD OF ONE TAMPERED SET ,TWO SETS GOES DAMAGE.HOPE U WILL DO THIS..NOW I WILL WAIT FOR GOOD NEWS........ |
12-23-2007, 07:50 | #10 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | i change altleast six new ic's but now only 1 and 3 r not working as it work for some time then again it stop working and all keys r working with all ic's but after 10 to f15 menit 1 and 3 stop responding all other r working |
second imei changed but still same ?? infinity team r u there ?? | İboc@N | Infinity-Box | 2 | 07-17-2008 10:33 |
5200 Dead-flashing Ok-but Still In Dead | zone2 | HWK | 6 | 06-30-2008 10:31 |
Formatted N95 Big But Still Same Problem | shola5 | MC-Tool | 6 | 03-13-2008 10:02 |
L6 cemera hang then i flash but still same | aukonline | Smart-Clip | 3 | 07-11-2007 21:18 |
V525 blue screen and turns off. flashed but still same | crossings | Motorola P2k | 4 | 09-02-2004 09:36 |
