Old 06-29-2006, 20:16   #1 (permalink)
Member: 293371
Thanks Meter: 8
Red face 7610 startup problem
i have nokia 7610 .its on but startup or contac realte message show i was full flash it but not response any body help me
Old 06-29-2006, 20:37   #2 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
solution already on fourm search before posting question ok
solution first format user area ur prob will b solve.
Old 06-29-2006, 20:47   #3 (permalink)
Member: 68487
Thanks Meter: 15
big ic flash user area it is prob change
br
Old 06-29-2006, 22:14   #4 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
i think u can format the mobile bu using *+3+green buttem and power switch
Old 06-30-2006, 04:27   #5 (permalink)
Registered User
Member: 133028
Thanks Meter: 5
just reboil the two flash ic
10000000000000% done
Old 06-30-2006, 14:56   #6 (permalink)
sahassan82's Avatar
Member: 116955
Sonork: 100.1604268
Thanks Meter: 992
my 7610 says phone start up failed contact retailer. any one suggestion with out flashing.......
Old 11-26-2008, 19:48   #7 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
heat 2 flash ic........after doing manual format
Old 11-26-2008, 21:41   #8 (permalink)
megdy's Avatar
Member: 628115
Thanks Meter: 113
Hard format
Press and hold GREEN + 3 +#
if still have same case try reflash
Old 11-26-2008, 21:42   #9 (permalink)
megdy's Avatar
Member: 628115
Thanks Meter: 113
if u try many solution not done
Replace Flash IC User Area
nokia 7610 startup failed contact the retailer nishatmohd Nokia Hardware & Hardware Repair 11 10-04-2011 16:48
7610 startup field jaleelkuttikkar Nokia Hardware & Hardware Repair 4 11-06-2008 20:07
7610 startup failed vicky kumar Nokia Hardware & Hardware Repair 19 05-17-2008 08:21
7610 startup failed vipul manchanda Nokia Hardware & Hardware Repair 8 08-19-2006 04:48
7610 Startup Code? Devil_H@ck WD2 & APE (Symbian Phones) 7 03-01-2005 22:47
Page generated in 0.17049 seconds with 9 queries
