11-11-2007, 06:53 | #4 (permalink) |
Product Supporter Join Date: Oct 2007 Age: 39
Member: 609952 Status: Offline Sonork: 100.1574492 Thanks Meter: 154 | RE SOILD THE CPU AND RESET THE FACTORY SETTING IT,S WORK 100 % FOR CONTACT I.C.Q NO-------- 486600516 [email protected] [email protected] |
11-12-2007, 08:11 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | clean the charging connector,above connector u will find 2 small ic's heat the right side ic slowly .i have solved the problem 2 days back |
11-17-2007, 09:11 | #8 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | Vishal123123 ' problem. 1. i believe, this is a simple hardware repair and not other inform. 2. you need to do some checking before cleaning and soldering . solution. 1. check if, you turn off your mobile phone speaker or low. 2. check if, your mobile phone speaker is not broken. 3. check if, your mobile phone casing is not properly closed. 4. check if, your speaker interface isin contact with board. 5. check the speaker with a meter reader. if ok. 6. check and clean all golden fingers or golden areas around the speaker of mobile phone. 7. try another headset . 8. try checking headset wire,if broken. 9. since, you have done resoldering and reheating application on your mobile phone. you have a serious check to make around events carried out. if all is done.post me your result. bestman |
Headset icon appear on display / Headset not work solution here.. | capri | Nokia Hardware & Hardware Repair | 39 | 03-16-2011 14:47 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
6085 headset ways help | rhimark | Nokia Base Band 5 ( BB-5 ) | 2 | 02-11-2009 13:38 |
Trying to initiate Headset Connection with Headset | massaquah | Bluetooth-Software | 1 | 05-28-2005 14:33 |
