09-14-2007, 06:19 | #33 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | 6280 Most of problem flex cable.1st change that.in very rarely some case somebody downgrade that vertion some times thats also give problem,many forum members already told that some water damaged boards small ic located near to camera also give that problem.if not solve with that u must rehot your board full thats also not solve your proplem is little major do with service manual.thank u. |
The Following User Says Thank You to cgsm For This Useful Post: |
01-08-2008, 14:29 | #35 (permalink) |
Freak Poster Join Date: May 2007 Location: france
Member: 511668 Status: Offline Sonork: 100.1604959 Thanks Meter: 8 | Change top keybord - This solution my problem! top keybord Change problem solvd |
The Following User Says Thank You to tamilnilan For This Useful Post: |
01-10-2008, 17:52 | #36 (permalink) |
Freak Poster Join Date: Jun 2003 Location: tunisia - sousse Age: 46
Member: 32529 Status: Offline Thanks Meter: 23 | so solution i have 6688 with same problem when i take a photo hang and say capture failed but camera work fine i have changed flex camera ic of camera top keybord i flashed it but no solution ..... any one have idea ????? |
The Following User Says Thank You to malek45 For This Useful Post: |
01-21-2008, 21:34 | #38 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | No always artles repair......flash oké, flex oké,camera oké,front board oké,2 regulator /1,8V plus 2.8V /oké, VDD 4v oké /camera interface pin 1. /.....UEM-PPM rehot.......other solution?? |
01-22-2008, 04:31 | #39 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Beside U Age: 37
Member: 647414 Status: Offline Thanks Meter: 127 | hello all frenz.... try do dis solution.... 1000000% was work....try it bro trust me........... WinD |
The Following 10 Users Say Thank You to WinD_VteC For This Useful Post: |
02-04-2008, 06:40 | #43 (permalink) |
Junior Member Join Date: Jan 2007
Member: 426898 Status: Offline Thanks Meter: 2 | 6288 not working solution I tried already from 6288 operation failed remove and jumper exactly in the image not working solution..is there any possible other ways. kindly post. Thanks. codec8, cagayan de oro philippines. " the gold city " |
The Following User Says Thank You to codec8 For This Useful Post: |
02-04-2008, 08:04 | #44 (permalink) |
Junior Member Join Date: Sep 2005 Age: 44
Member: 180830 Status: Offline Thanks Meter: 6 | Here's an experience I want to share with you guys with regards to 6280/6288 phones. The original problem of the phone was that it's display get's scrambled when you slide it up or down, or sometimes it turns white. Well of course I assumed that it was FLEX problem, so I replaced it with an original flex. Well it worked really fine on the display aspect, but when you try to use camera, it displays nothing but the strange thing is when you press the capture button on the side of the phone you can hear the capture sound and the really strange thing is when you take a look at the gallery, you can actually see a new picture, the one that you took without really knowing you have taken a picture. So what I did is to try to replace the FLEX again, original flex still, but the problem is still there. I tried to borrow a working phone with a working display and of course with working camera, I took it's flex and placed it on the phone that I'm working with but the same problem still existed. I decided to upgrade the phone version, but the problem became worst and when you click on the camera it now says "Operation Failed" and the worst thing even is that the phone now hangs and then restart. I tried to research on this forum and other forums they say replace N1060, I have tried to replace it with a part that came from a working one but the problem is not solved. I am now running desperate for the solution because my customer is already on his way to my place, but then I remembered that I have never replaced yet the LCD, so I again borrowed a working phone and tried to ise it's LCD on the phone that I am working with and voila, it worked.......... So when you come across 6280/6288 with camera problem, or display problem, here's what you gonna do: 1. Try to replace FLEX, if possible an original one. (Test it, if everything works, fine. If not,) 2. Try to replace the LCD. (Test it, if everything works, fine. If not, replace FLEX and LCD at the same time, because there are times that the FLEX is damaged and also with the LCD. If it does not work still,) 3. You can try to flash the phone and making use of your new FLEX and LCD. Test it, if there is still a problem with the CAMERA. You can try to replace the N1060 earlier mentioned on this thread. If it doesn't work still, then there is a bigger problem with your phone. Long story huh. But I hope I have given you an insight.......... |
The Following 6 Users Say Thank You to Ping_Sol For This Useful Post: |
6070 camera opreation failed | laddimobile | Nokia Hardware & Hardware Repair | 1 | 05-29-2009 07:49 |
6280 camera video fail operation | yus_ys | Nokia Base Band 5 ( BB-5 ) | 8 | 03-08-2008 10:03 |
6280 Camera Operation Failed!!! | khem | Nokia Base Band 5 ( BB-5 ) | 3 | 07-17-2007 07:46 |
6280 camera operation fail | kelvinlim | Nokia Hardware & Hardware Repair | 6 | 07-10-2007 19:33 |
nokia 6280 camera opreting failed | danish_teli | Nokia Hardware & Hardware Repair | 11 | 06-04-2007 12:52 |
