10-06-2008, 04:13 | #76 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | |
The Following User Says Thank You to topnoyze For This Useful Post: |
10-06-2008, 06:44 | #77 (permalink) |
Insane Poster Join Date: May 2006 Location: sarawak
Member: 281387 Status: Offline Thanks Meter: 17 | just want to update this thread...coz i have 6288 camera operation failed...tried replacing 3 flex ribbons and a brand new LCD but still thesame..i tried also doing the jumper trick and replacing that i.c. near the camera still not working...just want to know if any new solutions for this? if u got new solution pls share... i really need this phone to work again..... Try replacing (manual) keybad Board good luck ... |
The Following User Says Thank You to the best clr For This Useful Post: |
10-14-2009, 18:46 | #85 (permalink) |
Insane Poster Join Date: Feb 2007 Location: Pakistan
Member: 449479 Status: Offline Thanks Meter: 19 | 6280/88 camra solutions Hi bros, mostly i chekd that 70% of camera opration faild, hang with mix text n hang after capture is solved with changing a gud flex cable. 20% is camera ic fault n 10% is other gudluck |
11-04-2009, 04:53 | #89 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | First Check the cameras front and back if the cameras are not fixed properly fix these change flex or do this [IMG][/IMG] |
The Following User Says Thank You to mobilecitycbk For This Useful Post: |
6070 camera opreation failed | laddimobile | Nokia Hardware & Hardware Repair | 1 | 05-29-2009 07:49 |
6280 camera video fail operation | yus_ys | Nokia Base Band 5 ( BB-5 ) | 8 | 03-08-2008 10:03 |
6280 Camera Operation Failed!!! | khem | Nokia Base Band 5 ( BB-5 ) | 3 | 07-17-2007 07:46 |
6280 camera operation fail | kelvinlim | Nokia Hardware & Hardware Repair | 6 | 07-10-2007 19:33 |
nokia 6280 camera opreting failed | danish_teli | Nokia Hardware & Hardware Repair | 11 | 06-04-2007 12:52 |
