Old 11-03-2008, 08:02   #1 (permalink)
Member: 747981
Thanks Meter: 44
7610 "Phine start-up failed.Contact the retailer"
Nokia 7610 "Phine start-up failed.Contact the retailer"
1=full erase
2=full flash
3=write good pm
4=unlock
5=format
FLASH OK BUT SET NOT OK .......................
PLSSSSSS HALP ME
Old 11-03-2008, 08:11   #2 (permalink)
Member: 601984
Thanks Meter: 445
Try To Do Format ur cell phone By Code or By Device
By Hand Formating Process Switch off Ur cellphone *+3+call attending Button +Power Hold After Show Screen Formating
Old 11-03-2008, 08:50   #3 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
dear a.asifali is right you just follow this
Old 11-03-2008, 08:57   #4 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 11-03-2008, 09:26   #5 (permalink)
Member: 810386
Format user area. For me works.
Old 11-03-2008, 09:41   #6 (permalink)
Member: 539091
switch off the phone press * 3 call buttons at the same time press power button dont realease the keys phone will be formated and the problem can be solved
Old 11-03-2008, 10:20   #7 (permalink)
Sony_computers's Avatar
Member: 570022
Thanks Meter: 67
Reboll Flash and Try again....................Full flashing
Old 11-04-2008, 14:28   #8 (permalink)
Registered User
Member: 419331
Thanks Meter: 101
dear just flash latest ver. try it
Old 11-04-2008, 14:34   #9 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
brother full erase and full flash the set
Old 11-04-2008, 15:05   #10 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
after flesh write pm file and then format yur phone after format go in uisetting do only inti sim lock if u do there full fectrysetting then phone will gos in connect retailer
Old 11-04-2008, 18:10   #11 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
Originally Posted by mahabubtel View Post
nokia 7610 "phine start-up failed.contact the retailer"
1=full erase
2=full flash
3=write good pm
4=unlock
5=format
flash ok but set not ok .......................
Plssssss halp me
change ffllaasshh uusseerr
Old 11-04-2008, 21:15   #12 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
1. flash with jaf
if same. change ur big flash IC (Fl0)
Old 11-05-2008, 02:56   #13 (permalink)
Member: 844798
Sonork: st.nic
Thanks Meter: 11
after program just format using hard reset.works for me............good luck...
Old 11-05-2008, 05:51   #14 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
Old 11-05-2008, 05:52   #15 (permalink)
Member: 662678
Thanks Meter: 2,539
use this jumper and flash
Nokia 6600 "Phone start-up failed. Contact the Retailer" GMX@cool WD2 & APE (Symbian Phones) 73 04-24-2013 12:00
Nokia 6670 "Phone start-up failed. Contact the Retailer" nathanlei888 Twisterflasher 10 04-26-2011 13:13
Nokia 7610 "Phine start-up failed.Contact the retailer" smarttech Nokia Hardware & Hardware Repair 7 11-05-2008 12:40
7610 "Phone start-up failed.contact the retailer" trungnvphilips Nokia Hardware & Hardware Repair 18 10-28-2007 21:30
3650 "phone start-up failed, contact the retailer" with griffin, how??? watch man Nokia Digital Core Technology 4 ( DCT-4 ) 6 03-04-2003 18:59
Page generated in 0.23847 seconds with 9 queries
