06-17-2009, 16:08 | #106 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | 1..Remove this coil mark in (1)..if u want to check the light ic N2301 is short.... 2..Remove this coil mark in (2)..if u want to check blutooth & radio ic N6000 is short because this ic also got +b volt from battery.... 3..Remove this coil mark in (3)..if u want to check ringer ic N2151 because ringer ic also got +b volt from battery... 4..Remove this coil mark in (4)..if u want to check the handfree ic N2000 because this ic also got +b volt from battery... 5..Remove N1001 mark in (5) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network... 6..Remove this coil mark in (6)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network... 7..Remove N3200 ic mark in (7) ...this is memory card driver ic .remove it to check shoting is gone or not.... at end remove betty and avilma ic to check shoting is gone or not........ all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... ..::digitized::.. |
The Following 13 Users Say Thank You to digitized For This Useful Post: |
06-26-2009, 20:59 | #110 (permalink) |
Junior Member Join Date: Nov 2008
Member: 909622 Status: Offline Sonork: [email protected] Thanks Meter: 8 | I have a issue ,Nokia 6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue...Please assist.. What are the ways to overcome this issue so that i can input a new Imei into the phone with no issues.. pls explain... Thank you in advance |
06-26-2009, 21:34 | #111 (permalink) |
Member: 909622 Status: Offline Sonork: [email protected] Thanks Meter: 8 | I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue... also the other problem is if i dont use it for few minutes phone is auto off. Battery is Fine, what can be the possible reason and how it can be resolved. pls explain... Thank you in advance |
07-01-2009, 11:30 | #116 (permalink) |
Crazy Poster Join Date: Jun 2009
Member: 1063175 Status: Offline Sonork: nite Thanks Meter: 4 | 1ST BOOT : C0,07 [Rm-237] [2.0.8.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 25A00112D66D7E56ACB892A864C815CC9FA0E74B RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0 CMT FLID0 : 00898981-00000000, Int NU48F256 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__06.60.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:01 DATA_BLK_ERROR at: 0x00020000, 00 ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000280, Time: 00:04 Process Failed, Repowering Mobile, what is the problem plz help me. |
07-08-2009, 19:13 | #119 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Crytal Cloning
Member: 841015 Status: Offline Sonork: 100.180803 Thanks Meter: 63 | 5300 Amp 0.8 !!! my 5300 water damage has been clean properly. not short until i press power on button and amp show 0.8 . i have change retu ic but when i press power on it still short. i has touch my retu ic while holding power on switch and it got my finger burn.. what problem cause it hot??? any solution? MANY-manY ThanKsss... |
