Old 06-17-2009, 16:08   #106 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Check shorting in nokia 7210s..rm436_
1..Remove this coil mark in (1)..if u want to check the light ic N2301 is short....
2..Remove this coil mark in (2)..if u want to check blutooth & radio ic N6000 is short because this ic also got +b volt from battery....
3..Remove this coil mark in (3)..if u want to check ringer ic N2151 because ringer ic also got +b volt from battery...
4..Remove this coil mark in (4)..if u want to check the handfree ic N2000 because this ic also got +b volt from battery...
5..Remove N1001 mark in (5) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network...
6..Remove this coil mark in (6)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network...
7..Remove N3200 ic mark in (7) ...this is memory card driver ic .remove it to check shoting is gone or not....
at end remove betty and avilma ic to check shoting is gone or not........
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
..::digitized::..
The Following 13 Users Say Thank You to digitized For This Useful Post:
Old 06-19-2009, 18:31   #107 (permalink)
Crazy Poster
Member: 532666
Thanks Meter: 8
help with n81 8gb shorting.
i have the said mobile for repair the phone is working but its shorted
can someone help me with this.
thanks
Old 06-20-2009, 15:42   #108 (permalink)
Member: 587340
Thanks Meter: 3
u can try jaff box dearrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrr100%ok
Old 06-20-2009, 21:15   #109 (permalink)
Member: 525817
Thanks Meter: 21
complete pictures+exe upload here
http://nullstore.com/file/2482/nokia...ution-rar.html
The Following 2 Users Say Thank You to mirfanmian For This Useful Post:
Old 06-26-2009, 20:59   #110 (permalink)
Member: 909622
Thanks Meter: 8
I have a issue ,Nokia 6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue...Please assist..
What are the ways to overcome this issue so that i can input a new Imei into the phone with no issues.. pls explain...
Thank you in advance
Old 06-26-2009, 21:34   #111 (permalink)
Member: 909622
Thanks Meter: 8
I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue...
also the other problem is if i dont use it for few minutes phone is auto off.
Battery is Fine, what can be the possible reason and how it can be resolved.
pls explain...
Old 06-30-2009, 00:27   #112 (permalink)
Member: 609961
Thanks Meter: 2
Very nice sir.. thanks a lot
Old 06-30-2009, 07:14   #113 (permalink)
dvsbbdd's Avatar
Member: 703284
Sonork: 0
Thanks Meter: 66
The Following 7 Users Say Thank You to dvsbbdd For This Useful Post:
Old 06-30-2009, 07:49   #114 (permalink)
Member: 949989
I just wanna to remember that "ceramic capasitor" could make a problem of SHORTING...
Old 07-01-2009, 11:21   #115 (permalink)
Crazy Poster
Member: 1063175
Sonork: nite
Thanks Meter: 4
i got error in CMT flash write..... do any one have solution plz help me.... thanks in advance
Old 07-01-2009, 11:30   #116 (permalink)
Crazy Poster
Member: 1063175
Sonork: nite
Thanks Meter: 4
1ST BOOT : C0,07 [Rm-237] [2.0.8.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 25A00112D66D7E56ACB892A864C815CC9FA0E74B
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0
CMT FLID0 : 00898981-00000000, Int NU48F256
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__06.60.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:01
DATA_BLK_ERROR at: 0x00020000, 00
ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000280, Time: 00:04
Process Failed, Repowering Mobile, what is the problem plz help me.
Old 07-04-2009, 13:59   #117 (permalink)
Member: 1067321
nokia 6030 please.. help me!!!! thanks sir
The Following User Says Thank You to Nadokato For This Useful Post:
Old 07-08-2009, 12:29   #118 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
just great work, really great
Old 07-08-2009, 19:13   #119 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
5300 Amp 0.8 !!!
my 5300 water damage has been clean properly.
not short until i press power on button and amp show 0.8 .
i have change retu ic but when i press power on it still short.
i has touch my retu ic while holding power on switch and it got my finger burn..
what problem cause it hot???
any solution?
MANY-manY ThanKsss...
Old 07-28-2009, 10:00   #120 (permalink)
Member: 1083835
Hello sir,thankes for given soultion 6300 shorting
Page generated in 0.23056 seconds with 10 queries
