04-30-2006, 19:19 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 265296 Status: Offline Thanks Meter: 0 | Nokia 3660 Ext Antenna Connector I have located my problem of the nokia 3660 phone. It is missing External Antenna Connector and therefore it does not find range at all. My guestion is that can I find that piece of connector from the electronic parts shop? Can someone identify that connector properly so I can continue to find a shop that sells those Ext Ant Connectors. That same Ext Ant Connector is in nokia 3550 phone (looks same though ;P). Reference picture is here (Picture is from this forum). http://forum.gsmhosting.com/vbb/atta...8&d=1143396171 Look at the left top and you will see that piece... (EXT ANT Connector) Any help would be supportive, Thanks. -KW |
04-30-2006, 20:45 | #2 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Pakistan, Karachi Age: 42
Member: 246429 Status: Offline Thanks Meter: 20 | Quote:
Try to directly jumper from upper bus to lower bus, it will be ok . Then post me result. iam waiting | |
04-30-2006, 21:15 | #3 (permalink) |
Member: 265296 Status: Offline Thanks Meter: 0 | Hi Thanks for you answer. I have to gather some tools to make that direct solder point. It is a national holiday here, so I am able to contiune on tuesday. I will tell what happened regards, -kw |
04-30-2006, 21:43 | #4 (permalink) |
Member: 265296 Status: Offline Thanks Meter: 0 | More info about the connector and circuit board Hi, I posted some helpful ( I hope) information about the connector and the circuit board. Could you please be more specific where I should add those solder points. Please see the picture, where I have pointed out how the antenna connector is placed to the board. thanks -KW |
help: need 6310i ext antenna pad solution | Thams | Nokia Hardware & Hardware Repair | 2 | 11-18-2007 17:26 |
Nokia 6310(i) Dismantled EXT.Antenna PAd >>SOLUTION!<< | CyberoptiK | Nokia Hardware & Hardware Repair | 1 | 11-18-2007 17:06 |
6310i ext. antenna repair with pictures please | Ddavez | Nokia Hardware & Hardware Repair | 2 | 05-26-2006 14:17 |
Motorola P280 External Antenna Connector | mford | Motorola P2k | 0 | 04-05-2002 03:28 |
3310 no network tried changing PA and ext ant connector...please help | sidharthaharish | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2002 13:34 |
