Old 05-05-2007, 06:47   #16 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
hello on line member
could any one tell me the link to get free motorola rsd lite ver 3.6or below.thanks in advance.
Old 05-05-2007, 09:33   #17 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@ sarojrkl - Has youur 2600 had any contact with liquid, Check for liquid damage. You can try changing the bottom connector.
What program do you use? try and run a energy management calibration. This test basically tests everything to do with charging (BSI, VBAT etc etc)
If problem is still there...Then its going to be UEM fault...
@zultopo - It looks like you have 2 faults. Is there any liquid damage at all.
Have you tried changing domesheet. If you have, then the fault with # button will be the filter.
The charging fault, can be fuse, bottom connector etc. What have you changed on the charging problem.?
@ H4ck - Did you upgrade the firmware version yourself, or did a local service centre do it?
If you did it yourself, then theres nothing Nokia stores can do, becasuse you did it yourself. If a local service centre done it, take it back and moan to them, ask if they can do a software downgrade.
Old 05-05-2007, 09:52   #18 (permalink)
Member: 222373
Thanks Meter: 9
Talking
Originally Posted by MSG View Post
@ Vilas - What are you trying to tune, RX / TX? What phone? Also what program?
I'm guessing you're trying to tune TX, and when you click 'next' it comes up with that error. Try tuning the bottom coffecient level 'base'
@ Vilas 'Catastophic Failiour' could mean there is a problem with your computer hardware. Maybe there is a comflict somewhere. Are you trying upgrade phone software or downgrade phone software.
Hi,
thanks for your reply
but I am not trying to tune, RX / TX, I dont know any thing about tunings what my L-3 center does but i got my phone repaired (dead to on) after tuning and they peply the reson "Tuning out of specs" for my dead handset.
if you have any .pdf on tunnings pl send me on [email protected]
and 'Catastophic Failiour' is not tobe a prob with my comp because I can flash another same model with out any prob so it should be a prob with phone, what it would be.
& 1 more Q
what do you mean by "MCU Did not boot" error given by phoenix while flashing.
Thanks & Regards
Vilas
Old 05-05-2007, 10:03   #19 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@ Vilas -MCU boot is problem with Flash IC, try reflowing flash IC, if not, then change the Flash IC.
Old 05-05-2007, 12:14   #20 (permalink)
Member: 185776
Thanks Meter: 73
6070 menu button only not working.any circuit?
Old 05-05-2007, 12:26   #21 (permalink)
Member: 59025
hi,
i have nokia 7710 which shows nokia when switched on and after few sec the screen goes blank as wel as the handset goes off...
help....
Old 05-05-2007, 16:18   #22 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@Cell - Have you tried changing filter....try reflow UPP
@Broken - have u tried flashing the phone ?
Old 05-05-2007, 16:45   #23 (permalink)
Member: 403881
Thanks Meter: 80
if 000 000 shows in place of service provider than whats the problem (3310)
Old 05-05-2007, 16:58   #24 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@sarojrkl, do you mean like network code ?
usually 000 000 means the phone is a prototype board.
Old 05-07-2007, 09:42   #25 (permalink)
MSG
Member: 132117
Thanks Meter: 3
bump up to the top .
Old 05-07-2007, 17:08   #26 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
Hi! brokenbinil!U follow my picture sure 100% can solve Ur 7710 problem.
Old 05-07-2007, 21:31   #27 (permalink)
Member: 484738
simple flash does it !
Originally Posted by Brokenbinil View Post
hi,
help....
don't worry too much .all you need to do is a simple flash .i had the same problem with my nokia 6280 .i flashed it at repairman and now it is working better .it cost me about 10 dollars (120 moroccan dirhames)
Old 05-08-2007, 12:29   #28 (permalink)
Member: 390858
Thanks Meter: 29
3510i randomly switching off
please may you help because i have a 3510i which i have flashed before but the problem is that it randomly switches off.i also have the same problem with a 3310 please help.
Old 05-16-2007, 10:00   #29 (permalink)
Member: 175366
Thanks Meter: 3
Thumbs up Nokia 5200 Mic Problem
I have 5200 that cannot talk from the mic,what shall i do .
Old 05-16-2007, 10:56   #30 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@chiefonline - your 3510i, is the imei still valid, press *#06# can you still see the imei?
@goldace2003 - what have you done to the phone ? Have you tried changing the mic, or d-cover ?
for morocan users post your box problem here div_859 FuriousGold 2 06-04-2009 07:52
Post your software problems here .::Unlocker.:: Sony Ericsson 67 04-03-2006 16:21
Page generated in 0.24203 seconds with 10 queries
