12-23-2002, 01:36 | #1 (permalink) |
Insane Poster Join Date: Sep 2002 Location: South Africa
Member: 15928 Status: Offline Thanks Meter: 0 | Removing cobba....ccont? I was just wondering? If I remove the cobba or ccont.... must I reball it before replacing it? or must I reball it only if some balls are damaged? I was just wondering because I dont have the reballing tools and I dont want to make any mistakes with this IC's. Thanks! Regards AFR |
12-23-2002, 06:04 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: Removing cobba....ccont? AFR, when you will remove non-glue BGA chips if you put enough flux, and use "right" air and temp. then all bga tin balls will stay in that PCB! in some case, that two ball join together, you just need to put 0.5mm tin ball for it ! Willy Quote:
12-23-2002, 15:30 | #7 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Watch Man, I used Hakko 850, air on 3, heater on 3.5 it around 280 C! you have to try on your hot air, aas long as that flux not "smoke"! Willy Quote:
Step by Step-how To remove & replace COBBA / CCONT very useful to beginner... | silveraxe | Nokia Hardware & Hardware Repair | 8 | 07-03-2007 18:24 |
how to remove CCont Cobba and UEM | gsm.phone | Nokia Hardware & Hardware Repair | 6 | 01-29-2005 21:12 |
cobba and ccont | fiZ | Nokia Hardware & Hardware Repair | 4 | 01-14-2003 19:02 |
cobba, ccont, hagar nokias!!! | sergioems | Nokia Hardware & Hardware Repair | 3 | 09-20-2002 17:10 |
pa for ericsson and cobba-hagar-ccont | powerman | Main Sales Section | 0 | 09-03-2002 09:25 |
