Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Mobile Links
GSM Mobile Links Useful Links related to GSM, Cell Phones and Unlocking Programs and Sites.
Old 02-13-2017, 10:32   #61 (permalink)
Member: 145248
Thanks Meter: 27
I need to add one annotation on every printed record...
it's about time of acceptance for finished job...
Old 02-13-2017, 13:44   #62 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
If I understand correctly, you want to write acceptance date on printed record when client accept device?
When this happen, you usually change record status to finished or closed which means that you now have the acceptance date in the software. If you want to put the date also on printed service record, you can write it manually on existing one or printed new record and sign or put a stamp on it. This way you have dates on printed and non printed record.
Is this what you meant?
Old 02-13-2017, 15:04   #63 (permalink)
Member: 1569900
Thanks Meter: 129
Hi can we use this this software for two or more computer and sync data for 2 or more work place in same time?
Old 02-13-2017, 18:13   #64 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Hi magdavuza,
you can use this software on as many computers as you want, but in this moment software don't have sync options.
The Following User Says Thank You to GoGy For This Useful Post:
Old 02-25-2017, 12:53   #65 (permalink)
Member: 715524
Hi Gogy,
First sorry for late attention.
I have tried as your instructions.
But unable to log with same user name and pw,when crested on first time during installing Mobos.
Showing "Login failed,Invalid data"
Old 02-28-2017, 15:13   #66 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Sorry, I didn't get notification to my phone for new reply.
Can you try uninstall and then delete folder where MOBOS is installed.
After this, create new MOBOS installation.
Please provide feedback if you managed this.
Old 03-01-2017, 06:54   #67 (permalink)
Member: 715524
Hi Gogy,
First very sorry to disturbing again and again.
Yes,i have uninstalled and delete as you said.also i have used
user/pw as mobos.but no any luck
Old 03-01-2017, 09:12   #68 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
No problem. We will try to solve. Can you find database file inside mobos folder and change permissions for this user?
I am currently writting from mobile and dont have exact path but it should be something like mobospath/db/something.db
Do you have a chance to test on different computer like at home or friend?
Old 03-01-2017, 23:03   #69 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
This is the link where you should have database file if you didn't change anything
C:\Program Files (x86)\Mobos\baza
Database file is baza.db
Old 03-02-2017, 06:30   #70 (permalink)
Member: 715524
Hello Gogy,
Yes,can find that file,what i have to do for it..have to send it to you?
Actually i have test with my 2nd PC,but result same as with this pc
(unable to log with user id and pw,when create installing process)
Old 03-02-2017, 08:29   #71 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Can we try some remote assistant? Please send me PM for details.
Old 07-22-2017, 19:00   #72 (permalink)
Member: 861563
Thanks Meter: 9
"lookups limit EXCEEDED"
Can this problem be solved?
Old 08-15-2017, 15:22   #73 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Hi, yes we have made a limit to not abuse the system. By some contribution we can increase the limit. Please send an email with your service center details.
Best regards
Old 10-30-2017, 09:50   #74 (permalink)
Member: 85529
Thanks Meter: 5
Hi GoGy, tomorrow i launch mobo application and i don't see any repair registration i have lose all repair registration... You can help me to recover it please?
Thanks in advance.
Old 10-30-2017, 09:56   #75 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Thanks in advance.
Hi, this is weird. I think this could be related to your computer or something, because if DB file exists in folder you should see all records inserted in MOBOSsoftware. It should not happen to not see your records.
Also, you can check your antivirus software if it moved some files to quarantine or if it deleted the file(s).
Page generated in 0.22831 seconds with 9 queries
