Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Mobile Links
GSM Mobile Links Useful Links related to GSM, Cell Phones and Unlocking Programs and Sites.
Old 12-26-2016, 23:32   #1 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Arrow MOBOSsoft - Mobile service center management software
Hej guys,
years ago we developed software for service center and hopefuly you will find it usefull.
It has a lot of nice features like...
  • multilingual (you can add your language easily) - your translation is welcome if you send it to us!
  • multiple users
  • mobile phones pictures
  • brand logos
  • different editable statuses with color selection
  • editable services
  • clients
  • printing service reports with barcode
  • spare phones option
  • address book
  • personal notes
  • stolen/lost/found free quick check
and much more...
Works with almost all Windows OS versions.
Prerequisite is installed Microsoft Crystal reports (link can be found with installer).
CHECK VIDEO https://www.youtube.com/watch?v=JvhAYTjOfFM
It is FREE!
You can download it from >>> DOWNLOAD <<<
Feedback welcome
The Following 16 Users Say Thank You to GoGy For This Useful Post:
Old 12-28-2016, 08:51   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Dear Gogy, we start to use your SW in testing phase.
Here is BG translation.
Can i ask you to make a more lines ( +3 or +4 even and with small size ) at bottom ( under Client sign ) just to fill some important info about common conditions ?
WBR, DebeliaMark, BG
The Following User Says Thank You to debeliamark For This Useful Post:
Old 12-28-2016, 13:47   #3 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Hi, thank you for the feedback and sent translation.
I hope you followed main instruction how to create language file (saving to UTF-8) as described on website Mobos - Multilingual support
Your translation is uploaded on MOBOS website and available for other users for download.
Can you check if disclaimer in settings is what you need? This is usually printed at the bottom (about 2-3 lines) of the printed/preview page when you print the service record.
Old 12-28-2016, 16:34   #4 (permalink)
Member: 4627
Thanks Meter: 1,034
Yes - exactly - disclaimer section must be a little bigger on 2 copies per page just to store all needed info for customer in printed paper.
Translation is worked well:
Tnx for SW again.
Old 12-28-2016, 21:26   #5 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 13
Hi, thank you for the software, i am having some troubles with it, actually it is two errors.
N°1 - when i launch the software, and try to install the pictures, as it asks me when startup at first time, i get this error in picture.
N°2 - when i load this database i get this error whenever i try to do something
and if possible, to add the amount of money collected during a month for all the operations done, and adding to the accounts the price of the spare parts if used.
Thank you in advance
Old 12-28-2016, 21:39   #6 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Thanks for the feedback to both of you.
@debeliamark, great for working language. Regarding more space for Disclaimer text, we will see and change it once we collect more ideas.
@bifout, application was developed years ago and everything worked fine. We were not using it for few years at all and it seems that it came up with new error.
Please try to close application and start again. This should help to avoid problems with locking the database.
Which OS are you using? This might help hopefully.
The Following User Says Thank You to GoGy For This Useful Post:
Old 12-28-2016, 21:56   #7 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 13
I am using windows 7 pro X64, and if i restart the app it works fine but if i download the pictures of the phones, it did it again and lock the db in every other operation, may be the problem comes from my computer, i will try in others tomorrow and let you know
The Following User Says Thank You to bifout For This Useful Post:
Old 12-29-2016, 00:00   #8 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
I have managed to reproduce the problem. It is not your computer problem, but it seems that import script has problem. First I thought it is Windows 10 because we tested up to 8 I think at the time of last testing.
I will check for this in next days and inform you here. I believe it will be only needed to correct remote file for download (I hope), but need to check in details.
Old 12-29-2016, 15:13   #9 (permalink)
IBMOBILES's Avatar
Member: 56157
Sonork: 100.1573682
Thanks Meter: 171
software is really good and sample
can please add invoice option after repair donec
The Following User Says Thank You to IBMOBILES For This Useful Post:
Old 12-29-2016, 21:09   #10 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
@bifout, if we decide for updating, we will add also better statistics
@IBMOBILES, we will collect ideas for now and see what to do with this in future. Thanks for posting.
We planned much more with this software earlier but we stopped using it. Now we need to see if people will use it. I believe you agree that there is no sense to update it if only 10 or 50 users are using it.
Do you agree?
Old 12-30-2016, 11:07   #11 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
2 Changes Need To Made ....
In 1 Receipt Multiple Handset Add Option To Avoid Paper Waste If Handset From Same Customer.
User Full Name Fix Surname Show 1st. .... Like I Input John Anderson ...But When Print Show Anderson John.
User Name Must Be Auto Show In Scrolls Only Password Need To Enter To Login Will Be Better Typing Again N Again Username Is Headache.
The Following User Says Thank You to hitech care For This Useful Post:
Old 12-30-2016, 11:16   #12 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
@hitech_care, thanks for the feedback.
Regarding one paper with multiple items, this could also be an option.
Name Surname or Surname Name is more or less market dependent and could be made the same as for currency option to put before price or after price. This could be also nice feature.
Old 12-30-2016, 14:30   #13 (permalink)
IBMOBILES's Avatar
Member: 56157
Sonork: 100.1573682
Thanks Meter: 171
I suggest 1) monthly report for each customer for all repair , 2) multi entry for each order in case OF same customer bring more then 1 phone
Old 12-31-2016, 09:00   #14 (permalink)
GoGy's Avatar
Member: 69725
Thanks Meter: 36
Will contact you here once this get closer to upgrade to define better statistics.
Old 01-01-2017, 09:01   #15 (permalink)
kavithamobiles's Avatar
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
how can we register in this software
The Following User Says Thank You to kavithamobiles For This Useful Post:
Page generated in 0.22708 seconds with 9 queries
