Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 11-30-2005, 14:59   #1 (permalink)
Member: 178984
v180 won't unlock HELP!
I have an older v180 that I was able to unlock fine using moto unlocker, but my dad just got a newer v180: Flash Version: R365_G_0B.D2.2ER
Flex Version: GSIV180M0CIN04NA16D_1FF Bootloader:07.B0 and I can't seem to unlock it with any software. I tried motounlocker, all the PDS editors I could find and I even tried chfaken, but no luck! Any ideas on what I can do? Thanks for the heads up.
Old 11-30-2005, 17:24   #2 (permalink)
Member: 79322
[QUOTE=canja]I have an older v180 that I was able to unlock fine using moto unlocker, but my dad just got a newer v180: Flash Version: R365_G_0B.D2.2ER
Flex Version: GSIV180M0CIN04NA16D_1FF Bootloader:07.B0 and I can't seem to unlock it with any software. I tried motounlocker, all the PDS editors I could find and I even tried chfaken, but no luck! Any ideas on what I can do? Thanks for the heads up.[/QUOT
Downgrade to R364 use chfaken or motorola unlocker 2005 to unlock then upgrade it back with a none locking R365 MP or reflash
Old 11-30-2005, 22:44   #3 (permalink)
Member: 178984
...know where I can get a unbranded R365 (that won't lock my phone backup)? Thanks.
Old 12-01-2005, 17:11   #4 (permalink)
Member: 79322
you can email me or pm me
Old 12-02-2005, 10:58   #5 (permalink)
gsmspecialist2's Avatar
Member: 66001
Thanks Meter: 16
downgrading is a dangerous because if you stop when flashing or if you put wrong flash file, phone will be dead. use smart clip 100% safe 100% efficient
good luck
Old 12-02-2005, 22:34   #6 (permalink)
Member: 178984
I don't have a smart clip
... I guess I will risk it since it's now "backup" phone. I just got a new v551. I will keep you posted!
Old 12-03-2005, 09:11   #7 (permalink)
Member: 97546
just insert a travel charger... and unlock whit SC, or software...
Old 12-05-2005, 19:53   #8 (permalink)
Member: 178984
I tried downgrading to r364 and running the motounlocker and it all went smoothly, but when i put in the sim card the phone still ask me for a subsidy code!
Any thoughts?
Old 12-05-2005, 21:10   #9 (permalink)
Member: 67927
Thanks Meter: 108
so it is not unlocked.
I had problems like this with v180/v220.
Turn on phone, plug smart-unlocker to phone, Press unlock, wait til it puts in the flash mode and let it do its stuff. After the flash mode is gone, phone should off so you need to turn on the phone manually right after phone turns off and let it work. Post the results.
Old 12-05-2005, 22:07   #10 (permalink)
Member: 178984
dest I don't have a smart-unlocker; i'm using a usb cable and motounlocker.exe software.... but I still can't unlock the phone!
Old 12-05-2005, 22:47   #11 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
mybe you can damage your moto if you test it in many craked soft
its' time to bay smart-clip and all wil fixed
[IMG] code is Off
5300b that won't unlock...unlocked with trick alayne Nokia Base Band 5 ( BB-5 ) 5 08-29-2008 04:23
P990 fully locked, during unlock, won't unlock. 07heaven Universalbox 12 05-02-2008 00:39
v180 not unlocking! gsmunlocked Smart-Clip 18 01-06-2006 13:40
v180 need unlock code soneill525 Motorola P2k 1 04-07-2005 21:19
M320 won't charge, Help ! raybrig Mitsubishi 0 10-18-2004 17:59
Page generated in 0.18270 seconds with 9 queries
