07-24-2006, 22:18 | #46 (permalink) |
Junior Member Join Date: Jul 2006
Member: 317812 Status: Offline Thanks Meter: 0 | Microsoft Dongle OK I found the thread for this http://forum.gsmhosting.com/vbb/show...hlight=widcomm but it turns out there's no audio profile for the dongle. I'm using a different dongle now, but the license error keeps popping up. Sorry but can anyone tell me what to do?? It's getting so frustrating trying to find this information. Someone needs to mention the license.dat file needs to be in the driver folder and then patched... Anyone have any trouble pairing the mouse and keyboard? Last edited by mutazn; 07-25-2006 at 02:50. |
07-27-2006, 02:00 | #47 (permalink) |
Junior Member Join Date: Apr 2006
Member: 261621 Status: Offline Thanks Meter: 0 | Here is my problem: I removed 5.1.0.1100 and went to install 5.1.0.1700. Won't install. Says it cannot upgrade the Widcomm BlueTooth Stack. What folder is the Widcomm BlueTooth stack located in?? I guess I need to remove it to install. Can't install the previous version now either. Comes up with same error. Now, my BlueTooth does not work at all because I can't install any version due to the above mentioned error.. Any help??? TIA Bill |
07-31-2006, 09:27 | #49 (permalink) | |
Junior Member Join Date: Apr 2006 Location: Jamaica
Member: 253412 Status: Offline Thanks Meter: 0 | Quote:
08-02-2006, 23:21 | #50 (permalink) |
Insane Poster Join Date: May 2004 Location: où les rues n'ont pas de noms
Member: 66920 Status: Offline Thanks Meter: 3 | Bluetooth USB dongle Driver and Guides Bluetooth USB dongle Driver and Guides The archive indicated below contains three alternative Bluetooth drivers: - Bluesoleil VoIP Edition 2.1.3.0 - Toshiba Bluetooth 2.0 Driver 4.00.35 - WIDComm BTW 5.1.0.1700 The necessary Apirin against headaches is also included, such as - installation and troubleshooting guides plus a few tips & tricks - WIDComm BTW Driver Patcher 2.00 - WIDComm BTW License Patcher 1.7 Make sure to read the .doc, .pdf and .txt files before you begin with the setup procedure! They answer more questions than you would ever dare to ask, and also contain plenty of links to even more resources. Bluetooth USB dongle hardware drivers: - (sorry already outdated -- they are quick ...) - Toi, toi, toi for your installation, Qui Peccavit le Maître du Désastre Last edited by Maître Désastre; 08-03-2006 at 00:35. |
08-04-2006, 02:03 | #51 (permalink) |
Junior Member Join Date: Jun 2006
Member: 302465 Status: Offline Thanks Meter: 0 | I'm having the same problem with 1700 that I had with 1100. Whenever I switch between user accounts on the same machine, I have to manually "Stop the Bluetooth Device" (from the context menu on the BT tray icon) then restart it. Aside from that, it works fine, both in XP Pro (before) and Vista Beta 2 (now). The same user account problem occurs in both operating systems. |
08-14-2006, 13:02 | #54 (permalink) |
Junior Member Join Date: Aug 2006
Member: 330967 Status: Offline Thanks Meter: 0 | cant download from the host.. too many connections from my country if anyone is kind and would like to help me pls email the software @ [email protected] thank u |
08-14-2006, 23:54 | #55 (permalink) | |
Junior Member Join Date: May 2006
Member: 284528 Status: Offline Thanks Meter: 0 | Quote:
08-18-2006, 10:47 | #57 (permalink) | |
Member: 333308 Status: Offline Thanks Meter: 0 | Quote:
08-20-2006, 17:26 | #58 (permalink) |
Member: 334566 Status: Offline Thanks Meter: 0 | I am new the forum and have been attempting to get my MAc Book Pro Windows side to use the Widcomm drivers. I have downloaded this version and added the mod inf, I even added the VID/PID for my internal Apple Bluetooth device. However, after every install and un-install and re-install I can never get the drivers to recognize this device. I am hopeful some may be able to shed some light on the issue and release me from this nightmare. TIA Pete |
08-21-2006, 02:11 | #60 (permalink) |
Member: 334566 Status: Offline Thanks Meter: 0 | I did but I would not be 100% I did it correctly. I opened it set the device to match my internal BTW device and clicked save. Rebooted again and no luck. Is there a special way to run the license patcher? I could not find very detailed intructions throughout the forums. Pete |
Widcomm.Bluetooth.Software.Drivers.5.1.0.1700.rc1b .with.FW.Up | illusion0 | Bluetooth-Software | 21 | 09-10-2010 09:56 |
Widcomm.Bluetooth.Software.Drivers.5.1.0.1700.Fina l.Release | illusion0 | Bluetooth-Software | 42 | 12-21-2009 19:37 |
BTW 5.1.0.1700 problem | Lolitka | Bluetooth-Software | 0 | 09-11-2006 15:44 |
Widcomm 5.1.0.1700a | adisor19 | Bluetooth-Software | 15 | 07-30-2006 15:47 |
Problem Serial Port in Widcomm 5.1.0.1100 | Nuker5 | Bluetooth-Software | 3 | 07-04-2006 12:45 |
