09-20-2008, 09:00 | #437 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 711274 Status: Offline Thanks Meter: 7 | You work wrong. Update the Drives get lasted version and Mprog too, get Firmaware and Flash with Mprog - FT Update Ok -. For programer Ic ATmega128 use Pony Prog. The Firmwares in Hex format. |
10-01-2008, 22:19 | #440 (permalink) |
Member: 711274 Status: Offline Thanks Meter: 7 | When MPRog or UFS Utility show "ERROR READING" the EEPROM dont work change. When show "ERROR ERASING" EEPROM dont work change. When the PC show "Unknown Device" the EEPROM wrong connected, sometimes when show "Unknown Device", beacause FT dont started the chip wait on RESET State, connect 10k Pull Down resistor over EECS. When change FT232BM to FT232BL connect 10K Pull Down resistor over EESK. To force Start Up FT dont connect RSOUT# with 1.5k Pull Up resistor to D+, change this configuration connect D+ to 1.5k Pull Up resistor to 3.3v or connect to VSB 5v but add zener diode 3.3v in D+ channel. |
10-11-2008, 09:42 | #443 (permalink) |
Junior Member Join Date: Jun 2006
Member: 301948 Status: Offline Thanks Meter: 3 | http://img206.imageshack.us/my.php?i...roblem2ve8.jpg http://img206.imageshack.us/img206/4...problemgz3.jpg Last edited by gezgin27; 10-11-2008 at 09:51. |
10-11-2008, 19:58 | #444 (permalink) |
Freak Poster Join Date: Dec 2007 Location: INDORE (INDIA) Age: 36
Member: 661499 Status: Offline Thanks Meter: 76 | -- UFSx Device: UFS3 SarasSoft, USB S/N: ----- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : ------ -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ERROR : 0002 -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : ------ -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ERROR : 0002 PLS HELP HWKUFS MICRO IS NOT LOGIG ERROR: 1 SHOW ITS URGENT [email protected] |
10-11-2008, 20:00 | #445 (permalink) |
10-13-2008, 07:39 | #446 (permalink) |
Member: 711274 Status: Offline Thanks Meter: 7 | You need video change for EEPROM? Only change the memory to ST or AT 93c46. You can find the memory in the pcb? Search the ic over package characteristic SOT 8 SMD and remplace this. Previus change see the reference of the ic for checking if is the correct. If you do not know how desoldering the EEPROM please find any document describing in his content about SMD Soldering and Desoldering componentīs. |
10-30-2008, 11:38 | #450 (permalink) | |
Junior Member Join Date: Jul 2008
Member: 816563 Status: Offline Thanks Meter: 1 | Quote:
I tried to register ufs seiral no using UPDATE AND FIXER,But unable to do it,and the UFS MAINTENANCE V20 does not install on computer o run(tell me how to use UFS MAINTENANCE V20) .what can I do to register serial no pls?advise as early as possible | |
Repair Dead Or Not Booting Ufs Here.. | Dooha_Bd | Nokia Hardware & Hardware Repair | 0 | 01-27-2010 09:35 |
Repair Dead Or Not Booting Ufs Here | akram855 | Nokia Hardware & Hardware Repair | 1 | 12-05-2009 22:02 |
Dead or Not Dead Pkey after JAfsupport crack V106 or v108, v109 post here | TDKI | BB5KING for (BB5BOX) | 3 | 12-07-2008 09:52 |
Repair Dead Or Not Booting Ufs Hear... | stanner_austin | GSM Mobile Links | 0 | 12-01-2005 09:01 |
