Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 12-01-2005, 09:30   #1 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Repair Dead Or Not Booting Ufs Here..
YOU NEED 3 PRODUCT TO REPAIR DEAD OR NOT BOOTING UFS ....
(1)MPROG FOR WRITING EEPROM
(2)UFS MAINTENANCE V20
(3)UPDATE AND FIXER
CONECT UFS AND ITS ASK YOU DRIVER IF NOT ASKING DRIVER SO
ITS SHOW YOU UNKNOWED DEVICE OR USB TO SERIAL
DEVICE...JUST FORCE HIM TO ACCEPT DRIVER IN MPROG DRIVER FOLDER.......BECUSE IT CAN
CONVERT IT TO FTDI...
NOW SEARCH IT IN MPROG NOW ITS SHOW YOU ONE PROGRAMED DEVICE FOUND=1
NOW WRITE EEPROM THAT I UPLOADED...
AFTER IT EXIT IN MPROG.......
NOW OPEN UPDATE & FIXER........
CONNECT IT AND ENTER YOUR ORIGINAL SERIAL....
TICK ON WRITE FIRMWARE AND WRITE EEPROM
AND CLICK ON FIX & UPDATE.....
IN FEW SECONDS....YOU DONE.......
REMOVE UFS CABLE AND INSERT IT AGAIN.......
DONE........UFS IS ALIVE.......
IF SERIAL NUMBER IS NOT COMING THEN USE UFS MAINTENANCE V20 TO BUILD SERIAL NUMBER.....
AND DO SAME PROCESS......
ALL OK TESTED 100%
POST RESULT IF YOU HAVE ANY PROBLEM........
FOR MPROG
http://www.ftdichip.com/
UFS_Maintenance_v20.zip
http://www.mytempdir.com/292162
UPDATE AND FIXER
http://www.mytempdir.com/290928
ufs_good.ept
http://www.mytempdir.com/292186
ALL STUFF AT
www.gsmchevli.com/support/Ufsrepair
The Following 115 Users Say Thank You to stanner_austin For This Useful Post:
Old 12-01-2005, 09:47   #2 (permalink)
SALIMUS's Avatar
Member: 54116
Thanks Meter: 218
GOOD THANKS MAN
great links and this will make happy all user who have probleme with ufs and ufs not upgraded
best regards
The Following User Says Thank You to SALIMUS For This Useful Post:
Old 12-01-2005, 12:26   #3 (permalink)
Minos GSM's Avatar
Member: 153926
Thanks Meter: 23
Stupied work really that s not a work of pro
The Following User Says Thank You to Minos GSM For This Useful Post:
Old 12-01-2005, 14:30   #4 (permalink)
ednacell's Avatar
Member: 76978
Thanks Meter: 15
Thanx for the files and the fix information good job....
Old 12-01-2005, 14:57   #5 (permalink)
naderhacker's Avatar
Member: 4365
Thanks Meter: 39
not working man erase error
Old 12-01-2005, 14:59   #6 (permalink)
Ashwani Gaur's Avatar
Member: 2822
Thanks Meter: 152
i think this is only tested soft if you have any Professional Soft than why dont you post it here(ofcourse without password).
Old 12-01-2005, 15:30   #7 (permalink)
sunnyc's Avatar
Member: 49495
Sonork: 100.9 & 100.12345
Thanks Meter: 1,026
ahh.. good work tested working 100%
thx..
sunnyc
The Following User Says Thank You to sunnyc For This Useful Post:
Old 12-01-2005, 16:13   #8 (permalink)
Member: 4365
Thanks Meter: 39
@sunnyc what is tested i try on 2 boxes not working man
ERROR erase
WBR
The Following User Says Thank You to naderhacker For This Useful Post:
Old 12-01-2005, 16:39   #9 (permalink)
Member: 45377
error erasing you must re-program your atmega by Hi-Lo system or MPlaB...UFS maintenance its only good for not corrupted hex on atmega....Mprog good only if box is detected or found the device if not still you have to pull out eeprom & re-program via external programmer.
Old 12-02-2005, 06:16   #10 (permalink)
trashed's Avatar
Member: 8303
Thanks Meter: 127
hi, i also experienced erase error before and unfortunately i dont have external programmer that time. i have repaired my box by downgrading its firmware to 2.5 using DCTx 1.29. try it and it might repair your box.
Old 12-02-2005, 07:56   #11 (permalink)
Member: 58021
@stanner austin!
thanks for the solution! it works for me!
Old 12-02-2005, 08:09   #12 (permalink)
Member: 49752
Thanks Meter: 6,085
@naderhacker
DID YOU READED STEPS FOR FORCING ACCEPT DRIVER IN PROG FORDER.?BECUSE IF YOUR BOX DAMAGE OR BOOT NOT IN ATMEGA ITS FOUND AS UNKNOWED DEVIC.....THEN UPDATE ITS DRIVER TO FTDI AND PROG WILL FIND IT.......THEN TRY MY SOLUTION BY STEP BY STEP.....
Old 12-02-2005, 08:13   #13 (permalink)
Member: 58021
yea...i agree with u!
stanner
Old 12-02-2005, 08:47   #14 (permalink)
Member: 83424
I have a dead tornado but i cannot force im to accept the drivers it recognized as generic usb and when i point the drivers its doesnt accept
says"cannot find information about this hardware"
Im working in XP with SP2
Pls help me
Regards
Old 12-02-2005, 08:53   #15 (permalink)
Minos GSM's Avatar
Member: 153926
Thanks Meter: 23
not work 10000000% tested by me
dont lost time Friends.
The Following 3 Users Say Thank You to Minos GSM For This Useful Post:
Repair Dead Or Not Booting Ufs Here.. Dooha_Bd Nokia Hardware & Hardware Repair 0 01-27-2010 09:35
Repair Dead Or Not Booting Ufs Here akram855 Nokia Hardware & Hardware Repair 1 12-05-2009 22:02
Dead or Not Dead Pkey after JAfsupport crack V106 or v108, v109 post here TDKI BB5KING for (BB5BOX) 3 12-07-2008 09:52
Repair Dead Or Not Booting Ufs Hear... stanner_austin GSM Mobile Links 0 12-01-2005 09:01
Page generated in 0.23580 seconds with 10 queries
