12-02-2006, 10:58 | #154 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 40
Member: 109036 Status: Offline Thanks Meter: 56 | this is why as he said... This procedure doesn't crack ver3.03... it install back the system files deleted by the installation process of 3.03 installer... you can use the soft in this procedure but just as good as using it as non-HWK installation... remember the question in the start of the installation??? the HWK and non-HWK question to tick on??? get it???? or want some screenshot??? |
12-04-2006, 03:50 | #155 (permalink) |
Junior Member Join Date: Aug 2006
Member: 341244 Status: Offline Thanks Meter: 3 | damabib sir you can unlock few ASIC 11?? using UFS?? can you share your idea sir?? thanks sir LHICK.. yes unlocking asic 11 is my problem.. especially 1112, 1110i, 2310.. HELP.. |
12-15-2006, 19:04 | #159 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | still waiting solution to nulock asic 11 with ufs i tried codes calculated with ufs_bbx but gives code error ?? with my 2310 any idea thx to share |
12-20-2006, 20:26 | #160 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Deep Blue G.S.M.
Member: 225229 Status: Offline Thanks Meter: 90 | For those who are still facing using difficulties to use UFS_Suite_Setup_v03.03: I just tried that and successfull to crack with HWK Killer. The way is: 1. Uninstall the previous version of UFS suite, also the driver of the box 2. Install UFS_Suite_Setup_v03.01 (Do not use HWK killer now) 3. Plug in the box and install the driver from where 3.01 installed "D:\Program Files\SarasSoft\UFS\UFS_USB_Driver" 4. Uninstall only the UFS suite (not the driver) 5. Backup your system files from windows directory(XP): "NTDETECT.COM", "ntldr" and "boot.ini" 6. Install UFS_Suite_Setup_v03.03 7. Execute "sarasbox" (U have got from the first post) 8. Restore your (3)system files 9. Execute HWKKiller21b and crack as usual All done Now enjoy your complete box!!! with thanks nishaon |
12-24-2006, 07:22 | #164 (permalink) | |
Member: 109036 Status: Offline Thanks Meter: 56 | Quote:
asic 11 code reading using ufs is working on 1st gen asic 11 dct4-plus... i.e. 1110 (rh-70), 1600 (rh-64) but won't work with newer asic 11. 1110i (1112 or rh-93) | |
how you can use UFS_Suite_Setup_v03.06.000 without hwk | DIGITAL BABU | Twisterflasher | 5 | 07-09-2014 14:42 |
Cao! mobileEx 3.3 (rev1.7_fixed) NK5030 can not FLASH! HWK you can use! | lxh-studio | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-27-2010 10:59 |
V-SPEC Update For 3/3 10/10 .Now you can RESET FBUS COUNTER | Javajohn | J.A.F. V-SPEC | 5 | 07-18-2008 20:44 |
SeKing 3.0.5.3 CID52 English now you can unlock withouth box | reactos | Sony Ericsson | 34 | 12-31-2007 06:34 |
SeKing 3.0.5.3 CID52 English now you can unlock withouth box | reactos | Sony Ericsson | 4 | 11-29-2007 22:29 |
