Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-07-2008, 16:49   #1 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
U600 black screen (no lcd no flex problem )
Hello
I got few U600 with no display just black screen, thoug touchpad lights up.
The lcd and the flex works all fine with another pcb.
The phone can also make and receive calls , but just no display and no lights.
Did somebody had solved this problem ?
Thanks
Max_B
The Following User Says Thank You to Max_B For This Useful Post:
Old 01-17-2008, 15:40   #2 (permalink)
Member: 346519
Thanks Meter: 3
U600 Black Display
Hello I Have The Same Problem.
Black Display But When U Let Go Of Power Button The Phone Turns Off. If You Press * And # Together With On/off Button It Powers On And You Can Hear The Start Up Tone But Still No Display!!!
Tried Board In Working Phone But Same Problem, Flex And Screen Are Ok.
Old 01-18-2008, 06:21   #3 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
software problem/charging ic short..also charging jack not sure but in most other sets cases tested
The Following User Says Thank You to adnanali For This Useful Post:
Old 01-25-2008, 18:07   #4 (permalink)
Member: 184568
Thanks Meter: 39
Wink
Originally Posted by Max_B View Post
Hello
Thanks
Max_B
I have the same problem on 5 U600
I have the schema component but not to test
Did you try a flash?
Old 01-27-2008, 15:50   #5 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
There's no need to flash neither reset , already done
All that works is to blindly fluxing and heating the pcb , take care of glued ics
I did this since don't know where it's from.
Max_B
Old 01-30-2008, 01:31   #6 (permalink)
Member: 373639
Question u600 black lcd
how did u repair it the u600 black lcd
Old 01-31-2008, 13:42   #7 (permalink)
Crazy Poster
Member: 323234
Thanks Meter: 4
How did you reseted U600? Which device did jou use? I reseted my U600 with UST and the screen is still black
It is necassary to heat the pcb?
How did you repair yours U600
Old 02-01-2008, 00:36   #8 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Max_B
Sure there is one IC to resolder even one small compoenent, but since I don't know what is this,
I heat the whole pcb, and it's fine
Max_B
Old 02-01-2008, 16:11   #9 (permalink)
Member: 184568
Thanks Meter: 39
see what he is talking about. But I try this method, but after 2 days it's back again in panne.le component that is left of a player sim.
Old 02-02-2008, 22:16   #10 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Look if you find which component matters , I'll be thankful.
In fact there's not about heating the whole board to get it fixed,
But heating all the board to help the appropriate part to make contact again.
Max_B
Old 02-07-2008, 16:10   #11 (permalink)
Member: 289307
Thanks Meter: 44
Old 02-14-2008, 23:26   #12 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
I have six one in this case and i am looking for the solution.
I repared one with Ns pro, i make a full reset, you enter in SERVICE after having select the model U600.
You make NVM full reset, custom reset, wap reset...... but not the latest one (Build defaut NVM). After this, you make lonely a "BUILD DEFAUT NVM" and You repeat and repeat this operation many times and it will screen "charging", after this, you must let the phone connected at the ns-pro and you switch on the phone.
You make*2767*3855# two or three times and when the phone restart you disconnect the u600 from the ns pro.
If it is ok, then make a fullflash.
Post the result, it can take twenty minutes to screen correctly.
bye
Old 02-23-2008, 02:07   #13 (permalink)
Member: 713681
hello i have the same problem my screen is black, can someone plz say how i open my phone?
Old 03-12-2008, 16:40   #14 (permalink)
TOZE's Avatar
Member: 54945
Thanks Meter: 22
same problem on 3fone
power with star lcd is ok and freeze after 3 s
Old 03-13-2008, 11:52   #15 (permalink)
Member: 724538
the same problem dark screen and nothing more. I can call and recive calling but lcd is still black;/ and it is not flex;/
U700 black screen (no lcd no flex problem ) Marco López Samsung Hardware Repair 10 11-19-2011 12:09
u600 black screen dodoneli Samsung Hardware Repair 12 09-17-2010 02:34
U600 fragile screen or lcd Funkehed Samsung Hardware Repair 0 11-17-2009 09:15
6630 no lcd no keypad lights Fast Unlocking Nokia Hardware & Hardware Repair 3 06-29-2006 09:55
6100 - no lcd, no leds lantares Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-07-2004 15:22
Page generated in 0.27195 seconds with 10 queries
