Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-30-2009, 18:49   #1 (permalink)
Member: 903552
Sonork: rasfatzel
Thanks Meter: 4
c905 keypad problem
i`ve got a s-e c905 and when i push on "6" key the phone ask me if i want to continue to play media in speaker? i hear c905 it`s a phone problem with keypad but with "c" key. i don`t open the phone because i think i can`t do anything if i don`t know where is the problem. can you help me with some picture please?
The Following 2 Users Say Thank You to rasfatzel For This Useful Post:
Old 06-02-2009, 14:52   #2 (permalink)
Member: 23372
Thanks Meter: 18
i think u have to try to change the flex
Old 06-04-2009, 06:42   #3 (permalink)
Member: 903552
Sonork: rasfatzel
Thanks Meter: 4
good idea but...
the phone has the same problem from new so i think not the flex it`s problem but i`ll try this one because i don`t have any other idea. thx
Old 07-13-2009, 08:39   #4 (permalink)
Member: 579426
Thanks Meter: 4
i have same problem
any body halp
Old 10-01-2009, 08:02   #5 (permalink)
Member: 122830
80% solution for the c905 keyboard
try to change down keyboard first because try try it b4 many is coz down keyboard spoil.....i got this problem before got many phone like this n i slove with change down keyboard or flex or center ribbon only
this problem sure no because montherboard problem.....try it all my buddies
Old 10-19-2009, 18:05   #6 (permalink)
Member: 125632
Thanks Meter: 233
same prob as peps above,,,,any1 fix this????
change keypad(bottom) or middle flex or top keypad????
any1 know please?
Old 11-20-2009, 14:55   #7 (permalink)
Member: 889182
Thanks Meter: 3
c905 key problem
i've repaired 1 which have similar problem. either it's the slider ribbon or the upper key board problem. sometimes it's the key switch on the upper side of the lcd ( the left and right side of speaker). check whether there water damage ).
The Following User Says Thank You to brynbryn For This Useful Post:
Old 12-02-2009, 13:36   #8 (permalink)
Member: 1174491
Fixed!!!
HEY EVERYONE I FIXED THE PROBLEM. I dont know if sony erricsson have planned this hidden button but!! in the lcd screen on the top theres two buttons right when the key pad is broken the right key will work as a touch button when you slide your finger ower it and there you go its fixed. if it dosent work the first time it will work the other
Old 05-18-2010, 10:48   #9 (permalink)
Member: 1060043
Hi I need help, Iīve s.e. C905 and key 4,6,0 , *, donīt work, I change flex, but same problem.
Old 05-22-2010, 11:07   #10 (permalink)
Member: 1143112
Hi!
I had the same problem with a c905 and there was broken ways at the buttons on the side. I manage to repair it by checking the schematics.
There could also be the flex from keypad to board or the upper keypad.
Old 05-22-2010, 23:36   #11 (permalink)
Member: 1259860
Thanks Meter: 7
thanks toanswer this problem
Old 09-08-2010, 19:28   #12 (permalink)
Member: 763676
Old 09-24-2010, 15:08   #13 (permalink)
Member: 65145
Sonork: skype: hristo_el1
Thanks Meter: 3
I solved the problem with mismach of keypad by remove of the buttons for camera and player.
Old 11-13-2010, 08:28   #14 (permalink)
Crazy Poster
Member: 1268421
Thanks Meter: 4
Cannot enter Menu button(center button)....on Upper keybord & some times 3,4,6,0 not woking..........
without down keypad connection Menu key is working......well.
i think..... its down keypad board problem..... right?
I tested............100%
Replace the DOWN (Number) Keypad Board.......... 100% ok
Old 08-02-2011, 09:12   #15 (permalink)
Member: 416620
Thanks Meter: 5
chike key pad resestns if short some keys not worke. thanks
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
C905 keypad problem mobileshop-andy Sony Ericsson Hardware Repair 5 11-13-2010 08:25
C905 strange problem R.I.P. Sony Ericsson Hardware Repair 6 08-09-2010 12:50
c905 speeker problem 100% solve ^^^RAVI SOOD^^^ Sony Ericsson Hardware Repair 3 11-05-2009 12:59
c905 charging problems - battery drains quickly wichi850262 Sony Ericsson Hardware Repair 1 08-28-2009 12:27
Page generated in 1.46679 seconds with 9 queries
