10-30-2008, 14:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 39
Member: 18577 Status: Offline Thanks Meter: 4 | L6 Dead, Keypad light turns on for 5 sec. I've been trying to fix L6, which upon being powered on brings up keypad backlight for 5 seconds and then again goes off. Tried almost all the flash files from the download section, fixed the boot loader, pds, IMEI, still all in vain. Can't understand what the problem could be. Here is the log.. SmartMoto 3.17 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 8.D0 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... ST - M30L0R8000B0 Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: xxxxxxxxxxxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE xxxxxxxxxxxxxxx.mbk" Login request... OK Writing flash section 4 of 4... 100% (11.5 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (19.6 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (60.3 Kb/sec) Flash completed! Applying IMEI patch, please wait (up to 2 minutes!)... OK IMEI patch successfull, set new IMEI with the "Write" button Writing new IMEI xxxxxxxxxxxxxxx... OK Turning phone off... OK As it can be seen from the log, I did the following : 1. PDS Repair 2. Write Full Flash including boot area 3. Repari IMEI This usually works for almost all the phones. Strange it ain't working for this one. I've all reasons to belive this maybe a hardware problem, but can't square on the fault. Any ideas? Thnx Ayush P.S. - With some flash files, the keypad light blinked for 20 seconds. I replaced the flash but still the same. |
10-30-2008, 14:31 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ayush, As can be seen from the log file, everything suppose to be ok. In case if the problem still remains the same, more likely that the set has some hardware malfunction. Check the PCB of the phone it could have some short circuits or damaged components. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-30-2008, 18:27 | #3 (permalink) |
Member: 18577 Status: Offline Thanks Meter: 4 | Thnx for the reply there Mr.Tinkertrain, I would be grateful if you can throw some light on a few queries of mine. 1. Why exactly Motorola phones face this problem of keyboard light coming up when powered on and the phone doesn't get started. 2. If Flash IC is exchanged between two similar phones, then IMEI is also exchanged, so if IMEI is repaired and PDS is also fixed, the phone should theoretically work properly? 3. If there's a Hardware Problem, where can I square it? Finally, your Hardware is worth appraisal and works like a dream. Can say it's to some extent value for money. But your download servers ain't responsive as I've seen with other manufacturers. IMHO, you should tweak it as a part of better service. Wish you and your team all the best and way to go! Hope my phone gets fixed. Your input would be valuable. wbr Ayush |
10-31-2008, 08:37 | #4 (permalink) | ||
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ayush, Quote:
Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | ||
L6 Dead, Keypad light blinks for 5seconds when turned on. | Ayush | Motorola P2k | 0 | 10-30-2008 14:32 |
L6 just keypad lights on for a moments | irfaN_vu | Smart-Clip | 10 | 07-16-2008 21:38 |
3100 - if you put battery in all lights turn on! | sandrock2005 | Nokia Hardware & Hardware Repair | 7 | 01-24-2006 20:42 |
8360 unlocked but looses 2g reception for 5 secs | btyazoo | SonyEricsson (USB-Smart) | 3 | 11-02-2005 15:46 |
3310 lights turns on/off randomly | kojote | Nokia Hardware & Hardware Repair | 13 | 07-02-2004 12:54 |
