01-02-2008, 20:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | no more problem Sending boot...0xA001 failed i use infinty box and x60 cable and see the pic: br... Last edited by GSM_Support; 01-03-2008 at 08:04. |
The Following User Says Thank You to F@RUK S For This Useful Post: |
04-29-2008, 07:58 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please ensure that your cable is connected properly and the phone battery is fully charged. I presume that you need Smart-Clip original cable. Best Regards GSMServer team |
04-30-2008, 00:27 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006
Member: 268887 Status: Offline Thanks Meter: 91 | Quote:
Update is that now if I keep the power button pressed it says up to. Sending Boot ... OK Preparing.. OK And after that nothing happens. and I have to cancel the process and kill the smart moto application from task manager. | |
04-30-2008, 09:49 | #9 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Quote:
If you don't have you can buy some siemens (usb to com) data cable which usualy use profilic chip for com port, and you can adopt for motorola phones (rx,tx and gnd is needed only). | |
04-30-2008, 13:47 | #10 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Make it Easy! Profilic usb drivers, interface ftdi , you are making this way more complicated than it needs to be ! Do you unlock or flash a lot of Motorola ODM using many diffrent softwares ? If so, purchase a simple T191 comm cable and youre done. No more errors,timing errors, interface problems, conflicts etc etc. Keep it simple save your time ! Good Luck ! |
Sending boot...0xA003 failed | ..::: Naveed :::.. | Smart-Clip | 23 | 01-14-2009 08:11 |
W208 Sending boot...0xA007 failed | F@RUK S | Smart-Clip | 26 | 10-12-2008 13:41 |
F3 unlock error ... Sending boot...0xA007 failed | MohammedSharif | Smart-Clip | 6 | 12-22-2007 11:36 |
F3 and T250 same error Sending boot...0xA007 failed | Leshy | Smart-Clip | 1 | 12-22-2007 07:52 |
W375 unlock problem,,,,sending boot,,,,failed | steca | Smart-Clip | 14 | 05-26-2007 12:39 |
