02-05-2008, 14:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Albania
Member: 444251 Status: Offline Thanks Meter: 17 | Problem with w490 unlock Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK |
02-05-2008, 15:04 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ manistar, Please tell us what cable you are using. During Prepare Smart TestPoint procedure you use Primary TestPoint only. or both TestPoints simultaneously? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-05-2008, 15:19 | #3 (permalink) |
Member: 444251 Status: Offline Thanks Meter: 17 | I am using smart test point that I have unlocked other phones with it. With green Tp smart moto knows like this Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK With the tb B(yellow) only like this Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 and then nothing : check cable and connect apropriate test point The firmware version is R452G_G_08.24.02R. iF I can`t unlock this unit I can flas it with scout with version R452G_G_08.13.05R? Couse the version of the phone is not supported at support. |
02-05-2008, 15:26 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ manistar, Have you tried to unlock it using both TPs at the same time, as written at the TP picture? In case if the handset will be flshed with lower firmware version, it will stay in boot mode. We recommend to use flash files with the same firmware version like the phone originally had or higher one. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-05-2008, 15:48 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ manistar, One of possible reasons for this error is faulty cable, secondary TestPoint doesn't work properly. Please tell us where have you purchased it. Cables manufactured by our team has Yellow and Black TestPoint connectors. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-05-2008, 16:08 | #7 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 421331 Status: Offline Thanks Meter: 30 | That' s right ...faulty cable, I tried to unlock this model but I just get the phone stay in flash mode ...I'm waiting for an original cable from gsm server it seems other cables doesn't work |
02-18-2008, 14:58 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ no1mobiles, http://forum.gsmhosting.com/vbb/show...8&postcount=20 Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
j132 unlock problem with d unlocker | oumar | Cruiser Suite | 1 | 05-23-2009 12:18 |
afSupport, have a problem with w490 after smart tp | flydog | Smart-Clip | 2 | 02-19-2009 12:37 |
Problem with w490 unlock | manistar | Smart-Clip | 0 | 02-05-2008 13:55 |
Problem with 6300 unlocking with new methode | Bloedman | UID - Box | 10 | 10-24-2007 08:24 |
problem with a65 unlock with test point. help me | Krafk | E-Gold Based Phones | 0 | 01-10-2005 13:32 |
