10-06-2016, 12:35 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Bulgaria,Veliko Tarnovo
Member: 131788 Status: Offline Thanks Meter: 69 | Alcatel OT-8050D PIXI 4 6 Flashing Failed sing library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 287d331b66292bff63c33df8d1cf2f8b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0xCE640030 0x53C2B92F [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 8050D-2BALWE1 USRDATA INFO: 0xB9800000 SIZE: 0x19400000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:30 Log file saved to: LOG_6_10_2016_14_29_18.txt What must i do to flash this phone? |
10-06-2016, 13:05 | #3 (permalink) |
Member: 131788 Status: Offline Thanks Meter: 69 | Phone is working and there are nothing wrong, i must change language pack. With factory flasher Sugar_MTP device flashing and update sucesfull, but only version upgrade, there cannot change language pack. |
10-07-2016, 07:38 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,572 | Quote:
Check if enough free space on the hdd where the sw runs. If still same contact me over skype to take a look Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-19-2016, 14:23 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Europe Age: 39
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | Also have some problem, need change language: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM65)) Preparing to start flash mode; Preparing to open COM65 Connecting; Downloading DA; Initializing; Rid: 06c6fed1531bf319832f34abf217aa82 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem113.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM67; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0x80A10030 0x07C2CB2C [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 8050D-2AALWE1 USRDATA INFO: 0xB9800000 SIZE: 0x19400000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:17 Log file saved to: LOG_19_10_2016_16_21_37.txt |
The Following User Says Thank You to stylius For This Useful Post: |
