04-17-2018, 16:50 | #14536 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Dominican Republic Age: 35
Member: 1078865 Status: Offline Sonork: 100.1626549 Thanks Meter: 83 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM188)) Preparing to start flash mode; Preparing to open COM188 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: fd9ee4ed688f81951a54cd7d53d44e33 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem98.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM53; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xA45A0342 0x879437D8 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 015106-00-003939-4 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5099A-2CRGDO1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 4254975181363551 enabled: yes tries: 10 code_cat_ns: 4254975181363551 enabled: no tries: 0 code_cat_sp: 4254975181363551 enabled: no tries: 0 code_cat_c: 4254975181363551 enabled: no tries: 0 code_cat_sim: 4254975181363551 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_17_04_2018_11_44_43.txt |
04-18-2018, 02:59 | #14537 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | vodafone 840 unlock Hi. SIM_LOCK REMOVED DONE Press and hold midel botton and connect usb cable to phone screen will be pink colore then go to device manager find masse storage under usb controler and install this driver U120_V715 from support then press scan port you will see port nember in soft then do job dont' check any things Here is log Searching phone ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35675503053027-2 READING; SP_SAVED_TO: SP_35675503053027_DA6_06.17.17_18.04.2018_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 214-01 MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! DONE ! RESET ! Time needed - 00:03:48 |
04-18-2018, 19:39 | #14538 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | unlock zte a512 done with furious and pack 5, put phone on ftm mode and done Software engine version: 1.0.0.10659 Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Dec 26 2017 15:32:00 RELEASE DATE : May 27 2016 05:00:00 FIRMWARE INFO : MPSS.JO.1.2.c2-00081-8937_GENNS_PACK-1 IMEI : 86107003245xxx-0 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: PT_VDF_P817E52V1.0.0B29 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\d\Desktop\1\QCOM_SMART_TOOL_v1.0.0.10659\ 86107003245xxx_18_04_2018_18_30_27.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM13 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D5 Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM17)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_18_04_2018_18_37_13.txt Time needed - 00:06:49 |
04-18-2018, 21:39 | #14539 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | OT-5049Z Phone unlocked; done by OTSmart_v1.0.0.2759_PRO_Edition Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM29)) Preparing to start flash mode; Preparing to open COM29 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: e98c07f7cc7d68f5a43b0a2847569716 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem97.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xB2B20742 0x8F946AFC [SIZE=0x748800000] IMEI1 [OTP 0001]: 014940-00-278871-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:27:58 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:28:02 Log file saved to: LOG_18_04_2018_15_33_52.txt |
The Following User Says Thank You to shainelus For This Useful Post: |
04-19-2018, 14:41 | #14540 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | frp alcatel 5049z Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ef72ded3bec48d8e16f2cbcb7f0cd147 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem64.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM37; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xFF8D0742 0xA56494F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014xxx-00-xxxxxx-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_19_04_2018_09_38_29.txt |
04-19-2018, 15:26 | #14541 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ef72ded3bec48d8e16f2cbcb7f0cd147 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem64.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM37; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xFF8D0742 0xA56494F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014940-00-xxxxxx-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) Buteforce took 00:10:29 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:42:11 Log file saved to: LOG_19_04_2018_10_25_37.txt |
04-19-2018, 22:27 | #14542 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5049W UNLOCK DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM94)) Preparing to start flash mode; Preparing to open COM94 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: d94ab104e7ad231e4800391342237d7d Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem88.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM95; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xD8880742 0x99548DAA [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-074191-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) Buteforce took 00:01:22 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:21:24 Log file saved to: LOG_19_04_2018_05_24_20.txt |
04-20-2018, 10:57 | #14543 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | VODAFONE VFD 600 FRP UNLOCK DONE Software engine version: 1.0.0.10622 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : May 19 2016 08:35:00 RELEASE DATE : Feb 1 2016 00:00:00 FIRMWARE INFO : MPSS.JO.1.1.c1-00028-8909_GEN_PACK-1 IMEI : 355XXXXXXXXXXX BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: ZA_MR1_VDF_P809V50V1.0.0B02 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\furious box\pack 5\QCOM_SMART_TOOL_v1.0.0.10622_Z_Edition\355595074 30147_20_04_2018_11_53_10.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM480 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_20_04_2018_11_55_21.txt Time needed - 00:02:14 |
04-20-2018, 10:57 | #14544 (permalink) |
04-20-2018, 13:21 | #14545 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Mobicel 4U Read & Write Flash Done [Full Supported] By Great FG Box ;) Reading Flash Log:- Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: c4f2d461bb79ee0fb24c9b30b63ce34c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0xC1320705 0x17C3776A [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xBA000000 SIZE: 0x116F80000 Getting partitions info; Reading info; Partitions info: [0x00080000-0x00300000]-[proinfo] [0x00380000-0x00500000]-[nvram] [0x00880000-0x00A00000]-[protect1] [0x01280000-0x00A00000]-[protect2] [0x01C80000-0x00040000]-[seccfg] [0x01CC0000-0x00060000]-[lk] [0x01D20000-0x01000000]-[boot] [0x02D20000-0x01000000]-[recovery] [0x03D20000-0x00080000]-[para] [0x03DA0000-0x00800000]-[logo] [0x045A0000-0x00A00000]-[expdb] [0x04FA0000-0x02000000]-[nvdata] [0x06FA0000-0x02060000]-[metadata] [0x09000000-0x00200000]-[oemkeystore] [0x09200000-0x00600000]-[secro] [0x09800000-0x00800000]-[keystore] [0x0A000000-0xA0000000]-[system] [0xAA000000-0x10000000]-[cache] [0xBA000000-0x116F80000]-[userdata] [0x1D0F80000-0x01000000]-[flashinfo] Reading full dump; Contents saved to : C:\Users\Dream\Desktop\MEMORY_DUMP_Mobicel 4U_c4f2d461bb79ee0fb24c9b30b63ce34c.osp Time needed - 01:05:30 Log file saved to: LOG_20_04_2018_11_45_57.txt Write Flash Log Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: c4f2d461bb79ee0fb24c9b30b63ce34c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0xC1320705 0x17C3776A [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xBA000000 SIZE: 0x116F80000 Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; Preparing to write FULL_DUMP_PART1; Writing FULL_DUMP_PART1; Preparing to write FULL_DUMP_PART2; Writing FULL_DUMP_PART2; Preparing to write FULL_DUMP_PART3; Writing FULL_DUMP_PART3; Preparing to write FULL_DUMP_PART4; Writing FULL_DUMP_PART4; Preparing to write FULL_DUMP_PART5; Writing FULL_DUMP_PART5; Preparing to write FULL_DUMP_PART6; Writing FULL_DUMP_PART6; Preparing to write FULL_DUMP_PART7; Writing FULL_DUMP_PART7; Preparing to write FULL_DUMP_PART8; Writing FULL_DUMP_PART8; Preparing to write FULL_DUMP_PART9; Writing FULL_DUMP_PART9; Preparing to write FULL_DUMP_PART11; Writing FULL_DUMP_PART11; Preparing to write FULL_DUMP_PART12; Writing FULL_DUMP_PART12; Success; Time needed - 00:12:31 Log file saved to: LOG_20_04_2018_12_02_24.txt Last edited by ..::GMSR::..; 04-20-2018 at 13:27. |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
04-20-2018, 16:03 | #14546 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Mobicel ICE FRP Reset & Firmware Reading Done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: d743dbf5f958e2e1c878627e9d3566e7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6572 [CA00, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x111F0705 0xDB932520 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x7E040000 SIZE: 0x1536C0000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_20_04_2018_14_12_41.txt Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: d743dbf5f958e2e1c878627e9d3566e7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6572 [CA00, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x111F0705 0xDB932520 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x7E040000 SIZE: 0x1536C0000 Getting partitions info; Reading info; Partitions info: [0x00000000-0x01400000]-[PRELOADER] [0x01400000-0x00080000]-[MBR] [0x01480000-0x00080000]-[EBR1] [0x01500000-0x00300000]-[PRO_INFO] [0x01800000-0x00500000]-[NVRAM] [0x01D00000-0x00A00000]-[PROTECT_F] [0x02700000-0x00A00000]-[PROTECT_S] [0x03100000-0x00020000]-[SECCFG] [0x03120000-0x00060000]-[UBOOT] [0x03180000-0x00600000]-[BOOTIMG] [0x03780000-0x00600000]-[RECOVERY] [0x03D80000-0x00040000]-[SEC_RO] [0x03DC0000-0x00080000]-[MISC] [0x03E40000-0x00100000]-[FRP] [0x03F40000-0x00300000]-[LOGO] [0x04240000-0x00A00000]-[EXPDB] [0x04C40000-0x6A400000]-[ANDROID] [0x6F040000-0x0F000000]-[CACHE] [0x7E040000-0x1536C0000]-[USRDATA] [0xFFFF00A8-0x01500000]-[BMTPOOL] Reading full dump; Contents saved to : C:\Users\Dream\Desktop\Mobicel ICE\MEMORY_DUMP_Mobicel_ICE_d743dbf5f958e2e1c87862 7e9d3566e7.osp Time needed - 01:27:59 Log file saved to: LOG_20_04_2018_15_41_45.txt |
04-20-2018, 19:03 | #14547 (permalink) |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Zte f230 unlock done Hi Zte F230 unlock done Software engine version: 1.0.0.10659 Searching phone ... MODEL : QCOM SERIES 2 [KYRZ] COMPILED DATE : Jun 22 2007 10:42:00 RELEASE DATE : Jun 20 2007 12:00:00 FIRMWARE INFO : F230 3.1 IMEI : 35561601005494-2 BLUETOOTH ADDR : 40 9A 14 EB 15 00 MEMORY ID : 00EC:0078 MEMORY NAME : samsung_k91g08 MEMORY INFO : 0200:0020:132D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; PHONE CODE: 7875 READING; ERASING; WRITING; UNLOCK CODE: 9217938910058999 ENTER USING: *983*865625# RESET ! Log file saved to: LOG_20_04_2018_17_53_20.txt Time needed - 00:00:49 Use this driver from support WCDMA GPRS GSM Dual Mode Mobile |
04-23-2018, 19:05 | #14549 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | ALCATEL 5049Z metro pcs unlock done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM26)) Preparing to start flash mode; Preparing to open COM26 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2b9d85ac76d6881d6ff7c8af080f7978 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem71.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x37640742 0xD19446F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014940-00-230888-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:08:03 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:08:07 Log file saved to: LOG_23_04_2018_13_48_16.txt |
04-24-2018, 16:16 | #14550 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Huawei id removed sucessfully HUAWEI ID REMOVED SUCESSFULLY BKL-AL 20 HONOR V10 FURIOUS GOLD>>>FLYCAPTAIN HUAWEI MODULE V2.0.00173>>>PACK 7 (HISILICON) -ON THE PHONE --ACTIVATE MANUFATURING MODE *EMERGENCY CALL>>>TYPE *#*#2846579#*#* *CLICK BACKGROUND SETTING>>>USB PORT>>>MANUFACTURING MODE -THEN CONNECT THE USB CABLE(TYPE C) -CHECK FOR DRIVERS INSTALLED DOWNLOAD DRIVERS FROM http://sigmakey.com/nfs/content/6104...con_DRIVER.zip AFTER INSTALLING OPEN FLYCAPTAIN MODULE SELECT AUTODETECT COM PORTS CLICK REMOVE HUAWEI ID DONE ************************************************** ********* LOG BELOW ************************************************** ********* 2018-03-24 15:57:31.912 Autodetect started! 2018-03-24 15:57:32.668 Found COM port: COM136 2018-03-24 15:57:33.713 Erasing Huawei ID... 2018-03-24 15:57:33.746 Connecting to server... 2018-03-24 15:57:35.015 Connected! 2018-03-24 15:57:35.015 Read data from server... 2018-03-24 15:57:37.617 Read data from server success! 2018-03-24 15:57:37.617 Open COM port COM136 (Android Adapter PCUI (COM136))... 2018-03-24 15:57:54.782 CP State: ready 2018-03-24 15:57:54.791 Read phone basic info... 2018-03-24 15:57:55.225 Read phone secure info... 2018-03-24 15:58:04.066 Read secure info... 2018-03-24 15:58:06.158 Read secure info success! 2018-03-24 15:58:06.158 Read basic info... 2018-03-24 15:58:09.228 Read basic info success! 2018-03-24 15:58:09.228 Read from server... 2018-03-24 15:58:10.591 Read from server success! 2018-03-24 15:58:11.526 Erase Huawei ID success! Done ************************************************** ********************* |
