07-16-2013, 00:19 | #11536 (permalink) |
No Life Poster Join Date: May 2007 Location: barsoume
Member: 515559 Status: Offline Sonork: no Thanks Meter: 121 | Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM174); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 862601-01-******-7 Reading simlock info; Locked to: 000-00 code_cat_n: 03098614 enabled: no tries: 10 code_cat_ns: 28367037 enabled: no tries: 10 code_cat_sp: 04064962 enabled: no tries: 10 code_cat_c: 19087519 enabled: no tries: 10 code_cat_sim: 29835561 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:06 |
07-17-2013, 11:57 | #11537 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Spain Age: 40
Member: 180702 Status: Offline Sonork: 1586150 Thanks Meter: 48 | Alcatel OT 6010x Unlock Done FB Hi Alcatel OT 6010x unlock done read nck log Code: Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM745); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6577 Sw version: MAUI.11AMD.W12.22.SP.V15.F5.P3 Hw Version: JRDSH77_CU_JB_HW Reading phone info; IMEI: 869491-01-321596-8 Reading simlock info; UNLOCK CODE: 00002227 Time needed - 00:00:57 |
07-18-2013, 15:23 | #11538 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1648084 Status: Offline Thanks Meter: 11 | orange pasadena aka alcatel 918 read codes succes Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM20); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P18 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-225525-8 Reading simlock info; Locked to: 226-10 code_cat_n: 32398649 enabled: yes tries: 10 code_cat_ns: 38990830 enabled: no tries: 10 code_cat_sp: 36969337 enabled: no tries: 10 code_cat_c: 37431652 enabled: no tries: 10 code_cat_sim: 01851610 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:00:32 |
07-20-2013, 17:16 | #11539 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 38
Member: 882614 Status: Offline Sonork: 100.1608795 Thanks Meter: 141 | acer e310 unlock done Software engine version: 1.0.0.8742 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : May 13 2011 13:25:00 RELEASE DATE : Aug 4 2010 16:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6030 , CCI:ACER Unknown 1.300.08 IMEI : 00000000000000-0 BLUETOOTH ADDR : 01 00 00 00 00 00 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 04872861 SERVICE: 12345678 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESET ! Time needed - 00:01:30 |
07-21-2013, 07:49 | #11540 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2201 Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620030504536 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:10 BR |
07-22-2013, 16:14 | #11541 (permalink) |
Member: 1648084 Status: Offline Thanks Meter: 11 | vodafone 875 read codes ok Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget Serial (COM27); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W12.22.SP.V15.F5.P4 Hw Version: JRDSH75_CU_JB_HW Reading phone info; IMEI: 355963-05-184126-0 Reading simlock info; UNLOCK CODE: 17720701 Time needed - 00:01:24 |
07-23-2013, 13:50 | #11542 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock ZTE Momodesign Software engine version: 1.0.0.8682 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 17 2010 20:08:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : 3ITA_GB_P608D1V1.0.0B11-S IMEI : 00000000000000-0 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 3265 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 222 MNC: 99) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:50 BR |
07-24-2013, 08:59 | #11543 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-304 Provider ID: 304X-2[X=C,D,E,F,G,H]RGES1 IMEI: 356130042919758 Start code calculate... NCK:1125887589 NSCK: SPCK: PCK: Code calculate finished successfully! Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3526770251869900 Requesting codes ... Saved: LOCOSTO_04.31.32_29.06.2013_SP.bin CODES: RESET: 2550780002 MEPD_NW: 1448150310 (ENABLED) MEPD_NS: N/A MEPD_SP: N/A MEPD_SIM: N/A MEPD_C: N/A Done ! Time needed - 00:00:31 Product: OT-506 Provider ID: 506X-2[X=C,D]VRGB3 IMEI: 356078041959707 Start code calculate... NCK:4024522917 NSCK: SPCK:0412962237 PCK: Code calculate finished successfully |
07-25-2013, 13:16 | #11544 (permalink) |
No Life Poster Join Date: Nov 2003 Location: near you ...
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,386 | Zte kis pro ( orange zail ) unlock ZTE KIS PRO ( ORANGE ZAIL ) UNLOCK Soft and Pack : AMDO 1.0.0.8742 PACK5 : [ HOLD volume down + power bouton ] = FTM Software engine version: 1.0.0.8742 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : May 2 2013 14:32:00 RELEASE DATE : Nov 8 2012 03:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 3580460+++++++-x BLUETOOTH ADDR : D2 87 12 1D F3 30 FIRMWARE: OSP_ES_P752D20V1.0.0B11 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:45 BR,Douhal |
07-28-2013, 14:45 | #11545 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | ALCATEL ot-s211 unlock Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 35630601111111111 Requesting mepd info ... Saved: LOCOSTO_18.42.26_28.07.2013_SP.bin Direct unlock finished. 1 locks were cleared. Done ! Time needed - 00:00:30 Guljee |
07-30-2013, 13:06 | #11546 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | FIRST in the WORLD ZTE V793 unlock done in FURIOS... logs: Code: Searching phone; Phone detected (@oem209.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM74); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V42.F1 Hw Version: ZTENJ75CU_SZ_HW Reading phone info; IMEI: 353550-03-108604-1 Reading simlock info; Locked to: 515-03 code_cat_n: 12345678 enabled: yes tries: 3 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:02:42 |
The Following 3 Users Say Thank You to alex_030385 For This Useful Post: |
07-30-2013, 13:13 | #11547 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | ZTE V793 unlock done... Searching phone; Phone detected (@oem209.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM74); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V42.F1 Hw Version: ZTENJ75CU_SZ_HW Reading phone info; IMEI: 353550-03-108604-1 Reading simlock info; Locked to: 515-03 code_cat_n: 12345678 enabled: yes tries: 3 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:02:42 |
08-02-2013, 16:44 | #11548 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India Age: 43
Member: 169384 Status: Offline Thanks Meter: 110 | Zte t12 unlocked sucessfully... Searching phone; Phone detected (@oem74.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM126); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V3.F1 Hw Version: ZTENJ73_HW Reading phone info; IMEI: 86XXX-XX-XXXXXX-X Reading simlock info; Locked to: 505-01 code_cat_n: 12345678 enabled: yes tries: 9 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:01:34 |
08-04-2013, 09:50 | #11550 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | gw900 covert gw300 and unlock Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 01219200421658705 Codes: 6274775873088027 6274775873088027 6274775873088027 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:36 thanks fg team m try all boxes all boxes failed to flash but fg box is working perfect (y) |
