10-03-2014, 12:36 | #12047 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | great team with great work unlock zet1 Software engine version: 1.0.0.9014 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 7 2012 10:21:00 RELEASE DATE : Dec 30 2011 06:00:00 FIRMWARE INFO : VDF_ES_WP750V1.0.0B06-S IMEI : 35732704264907-5 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 396BD8F6BDF78A526C16A4700E7406D2.bin ERASING; WRITING; READING; AFTER BACKUP: 1EB08C4805830430E597333B12BC6E75.bin UNLOCKED; RESET ! Log file saved to: LOG_3_10_2014_04_30_20.txt Time needed - 00:00:17 |
10-03-2014, 15:17 | #12048 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | OT5020N succesfull flashed OT5020N from metro pcs was dead for unknown reason and get back to life with this amazing tool Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (MediaTek USB Port) Preparing to start flash mode; Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 145c54fa47880c731adc91b3f6deddd9 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM19; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, 05] HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xB2C51058 0x25A008AA [SIZE=0xE9300000] IMEI1 [OTP 0001]: 013912-00-285078-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x4AF4C000 SIZE: 0x9E3B4000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:03:34 the firmware is in the website thanks furious team |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
10-03-2014, 18:22 | #12049 (permalink) | ||||
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | unlock meo 11 wed sucess: 1 - first one: Quote:
BR | ||||
10-04-2014, 14:50 | #12050 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | vodafone 785 direct unlock done Code: Searching phone; Phone detected (@oem189.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM24); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P4 Hw Version: JRDHZ72_WE_VF_JB3_HSPA_HW Reading phone info; IMEI: 355250-06-011820-7 Reading simlock info; Locked to: 234-15 code_cat_n: 28297969 enabled: yes tries: 0 code_cat_ns: 36211317 enabled: no tries: 10 code_cat_sp: 35093137 enabled: no tries: 10 code_cat_c: 35349723 enabled: no tries: 10 code_cat_sim: 27213334 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:46 |
10-05-2014, 09:11 | #12051 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Singapore Age: 37
Member: 888712 Status: Offline Thanks Meter: 308 | HUAWEI Y220 UNLOCK DONE BY FURIOUS GOLD Using library Brom_DLL_v7.1413.5 Connecting; Be sure you unlock the phone scrren; BRAND: HUAWEI MODEL: Y220-U00 ANDROID: v2.3.6 CPU: MT6572 IMEI: 866601018984391 Trying to get root access; Done; Reading simlock data; Done; Locked to: 525-03 code_cat_n: 02520690 enabled: yes tries: 255 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 11112222 enabled: no tries: 255 code_cat_c: 33334444 enabled: no tries: 255 code_cat_sim: 55556666 enabled: no tries: 255 code_cat_ns_sp: 77778888 enabled: no tries: 255 code_cat_sim_c: 99990000 enabled: no tries: 255 Cleaning; Calculating; Reconnecting; Trying to get root access; Done; Unlocking; Done; Phone unlocked; Remove battery and cable; Time needed - 00:00:44 |
The Following 2 Users Say Thank You to mrrobin For This Useful Post: |
10-06-2014, 15:02 | #12053 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Workshop Age: 48
Member: 179394 Status: Offline Thanks Meter: 19 | ZTE A711G unlock done Code: Software engine version: 1.0.0.6570 Connect phone powered on ! Start auth ! SW Ver: ER-BY-VELCOM-P108B1(G)V1.0.0B05 Imei: 354979021527913 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 6A C4 08 21 02 B0 06 01 9B 08 Flash ID(o): 00EC:257E Saved: ZTE_354979021527913_ER-BY-VELCOM-P108B1(G)V1.0.0B05_12.25.22_06.10.2014_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:00:54 after write prepaired by .:hack3r2k:. flash file: A711_ER-BY-VELCOM-P108B1(G)V1.0.0B05_UNLOCK.bin phone restarted after entering PIN and finaly after write A711_ER-BY-VELCOM-P108B1(G)V1.0.0B05_UNLOCK2.bin phone unlocked and work perfectly! thanks to .:hack3r2k:. for the work! FuriouS THE BEST! |
10-06-2014, 17:13 | #12054 (permalink) |
Freak Poster Join Date: Jun 2007 Location: United Kingdom
Member: 533083 Status: Offline Thanks Meter: 76 | MOCHE SCRIPT 64 UNLOCK FURIOUS Gold Use Nspro or any For Using Comport and use LG Gs102 cable. Connect Poweroff phone and click read code and press power button..thats it..Thanks to furious gold team. |
10-07-2014, 06:51 | #12055 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Alcatel 5020a unlock done selecting 5020 Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (MediaTek PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM31 Connecting; Downloading DA; Initializing; Rid: 01a42d38b3ec987fb372994f217208f2 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port) TRYING TO OPEN COM51; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA2018604 0x47A098A4 [SIZE=0xE7600000] IMEI1 [OTP 0001]: 013511-00-816122-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020A-2BVDAU1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9C6B4000 |
10-07-2014, 11:17 | #12056 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | ZTE Z992 unlock ok Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : May 10 2013 15:02:00 RELEASE DATE : Nov 8 2012 03:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 86481801485xxx BLUETOOTH ADDR : ED A3 EC 1D F3 30 DONE; BOOT VERSION: 76XXU-2540-USNSKOLYM READING MEMORY... RAM_DUMP.bin SAVED; UPLOAD IT SOMEWHERE AND SEND US THE LINK; RESET ! Log file saved to: LOG_7_10_2014_11_24_49.txt Time needed - 00:04:45 Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : May 10 2013 15:02:00 RELEASE DATE : Nov 8 2012 03:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 86481801485xx BLUETOOTH ADDR : ED A3 EC 1D F3 30 FIRMWARE: ATT_US_P752A15V1.0.0B17 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; PERFORMING EXTENDED UNLOCK; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_7_10_2014_11_30_34.txt Time needed - 00:00:29 Now I read it after unlock and cecked Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : May 10 2013 15:02:00 RELEASE DATE : Nov 8 2012 03:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 86481801485XXXXX BLUETOOTH ADDR : ED A3 EC 1D F3 30 DONE; BOOT VERSION: 76XXU-2540-USNSKOLYM READING MEMORY... RAM_DUMP.bin SAVED; UPLOAD IT SOMEWHERE AND SEND US THE LINK; RESET ! Log file saved to: LOG_7_10_2014_12_04_40.txt Time needed - 00:04:51 |
10-07-2014, 12:06 | #12057 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Vodafone smart 4 888n unlock done: Software engine version: 1.0.0.9014 Searching phone ... MODEL : QCOM SERIES 42 COMPILED DATE : Jun 10 2014 11:08:00 RELEASE DATE : Apr 14 2014 00:00:00 FIRMWARE INFO : GW_T3_180338_03 IMEI : 35973105044685-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 03596985B00206E4B14AD2A8CA8B1F0F.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! BR |
10-07-2014, 20:01 | #12058 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 248313 Status: Offline Sonork: 100.1609349 Thanks Meter: 4 | vodafone smart 4G coolpad 8860u unlock ok Software engine version: 1.0.0.9012 Searching phone ... MODEL : QCOM SERIES 37 COMPILED DATE : Nov 26 2013 16:10:00 RELEASE DATE : Nov 26 2013 16:10:00 FIRMWARE INFO : GWL000_03_03_006 IMEI : 86070702028226-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 1640D9148E67EB38E2486ED734A196BE.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_7_10_2014_19_31_41.txt Time needed - 00:00:53 |
10-07-2014, 21:56 | #12059 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Samsung i897 unlock done FG Samsung Module v1.0.2.8 ~ AT&T I897 ~ ~ READ CODES ~ Start at 15:49:25 Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone; ok Reading info; ok Checking root; ok (NOT ROOTED) BRAND: SAMSUNG MODEL: SAMSUNG-SGH-I897 SGH-I897 IMEI: 35186304******* HWID: SMDKC110-48 VERSION: ANDROID 2.2 BUILD FROYO I897UCKB1 I897UCKB1 I897ATTJF6 (PDA/CSC) FIRMWARE: SGH-I897-USER I897UCKB1 HARDWARE: REV0.4 KERNEL: 2.6.32.9 (gcc 4.4.1) PHONE SN: 00000000000 CPU TYPE: S5PC110 ARMv7 Please wait, running TEMPROOT[2]; ok Searching for phone; ok Checking root; ok (ROOTED) Reading data; ok Backups\SAMSUNG\I897\SAMSUNG-SGH-I897_351863044770994_SIMLOCK_2014_10_07_15_51_18.f gb Saving backup; ok Searching simlock block; ok Detecting security type; ok Checking server 1; ok Connecting to server; ok Asking server for access; ok Sending data to server; ok Calculating [by server] please wait; ok FREEZE CODE: 94264075 (Insert not accepted simcard press call and type the code) NET CODE: #7465625*638*58296282# SP CODE: #7465625*77*00000000# SIM CODE: #7465625*782*00000000# CP CODE: #7465625*27*00000000# Disconnecting from server; ok |
The Following User Says Thank You to Dwight07 For This Useful Post: |
