03-30-2012, 10:53 | #10546 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E3 35 00 90 9B 06 13 04 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:01 |
03-31-2012, 08:36 | #10547 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 3A 85 96 15 06 97 0B Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:56 |
03-31-2012, 09:14 | #10548 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 359391026029165 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:17 |
03-31-2012, 14:30 | #10549 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | T156 Ufone unlock done Software engine version: 1.0.0.6447 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081039937761 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081039937761_P1.2PU03V01.01_13.23.42_31. 03.2012_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 |
04-01-2012, 05:54 | #10550 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.7736 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Nov 14 2011 15:25:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : UCE_UZ_P622F2V1.0.0B03-S IMEI : 86500800390577-2 BLUETOOTH ADDR : 51 56 DF B2 1A 68 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: B979573C5919B0A62543DA5BAF2C7DB2.bin ERASING; WRITING; READING; AFTER BACKUP: 1BB1A13222B19A127C04D2C712C15BBD.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
04-01-2012, 22:12 | #10551 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | alcatel ot-813 flash done! Code: Make your handset power off, plug in the UART cable! Product: OT-813 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 356336040423525 Provider ID: 813X-2CRGES3 Security information version: ½£å“ 6qJ Downloading bootloader now... Downloading flash image now... Formatting file system now... Proceeding post process now... Flash full handset image successfully! |
04-02-2012, 10:16 | #10552 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.7873 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Feb 6 2012 04:02:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86160300075367-2 BLUETOOTH ADDR : 02 BA BD 4B D2 9C TAG_ID:QCNDef7 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:45 |
04-02-2012, 11:04 | #10553 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Connect phone powered on ! Start auth ! SW Ver: ER-UZ-BEELINE-P108A28(S)V1.0.0B02 Imei: 357925039191520 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 38 C5 98 46 07 08 0A Flash ID(0): 00C2:22C4 Saved: ZTE_357925039191520_ER-UZ-BEELINE-P108A28(S)V1.0.0B02_15.02.07_02.04.2012_PARTIAL.bi n Unlocked ! Remove battery and put back ! Time needed - 00:01:19 |
04-02-2012, 11:21 | #10554 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 39 C5 95 01 05 85 04 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:08 |
04-02-2012, 14:17 | #10555 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Make your handset power off, plug in the UART cable! Product: OT-306 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 356080043466988 Provider ID: 306X-2BBGKZ1 Security information version: XI96CW14 Downloading flash image now... Formatting file system now... Proceeding post process now... Flash full handset image successfully! Make your handset power off, plug in the UART cable! Product: OT-306 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Start to rebuild security region... IMEI: 356080043466988 Security file: c:\Program Files\FuriouS-Gold\Pack8\Alcatel\Security\BackupSecurityFile\306 X-2BBGKZ1 Rebuild security region successfully! |
04-02-2012, 17:36 | #10556 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Argentina
Member: 269030 Status: Offline Thanks Meter: 35 | new version ZTE T720 unlocked thanks to .:hack3r2k:. MODEL : QCOM SERIES 14 COMPILED DATE : Jun 13 2011 10:46:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : ZTE-U N720_H3_Z3_SP_TSDCD213B IMEI : 35357704201993-5 BLUETOOTH ADDR : EF 58 FC C7 64 C8 TAG_ID:r3 UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; UNLOCKED ! Time needed - 00:00:05 Really good support, thanks |
04-03-2012, 03:57 | #10557 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Software engine version: 1.0.0.7740 Searching phone ... MODEL : TOSHIBA TG01 ENTERING DOWNLOAD MODE; ENTERED; BOOTLOADER VER: 8650B--SDCA ALLOCATING BUFFERS; PREPARING TO DUMP SENSITIVE DATA; DECODING DATA; SAVED TG01S.bin; IMEI : 35923902019558-3 BLUETOOTH ADDR : 19 4D EA 18 23 00 NETWORK: 99054421 NETWORK SUBSET: 00621387 SERVICE PROV.: 09024795 CORPORATE: 72234200 SIM/USIM: 89342001 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. USUALLY NETWORK OR SIM/USIM ARE THE ENABLED LOCKS ! IN WORST CASE TRY ALL ;-) ONE WILL SURELY WORK ! RESETTING; Time needed - 00:00:45 |
04-04-2012, 11:49 | #10558 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Software engine version: 1.0.0.7880 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 8 2011 19:45:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : ATT_AM_P671B40V1.0.0B09-S IMEI : 35661304419459-5 BLUETOOTH ADDR : 5D 66 E4 50 4B 34 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 0D0A2225DBA14CB738A8889040C1E0E9.bin ERASING; WRITING; READING; AFTER BACKUP: 425922645A7FEB6B5CA4AE552F6B79AE.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
04-05-2012, 13:32 | #10559 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | lg tu720 unlock Software engine version: 1.0.0.7740 Searching phone ... MODEL : TU720 COMPILED DATE : Oct 25 2007 03:08:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : TU720-MSM4090201C-V10e-OCT-24-2007-RW-CA IMEI : 35798501000689-9 BLUETOOTH ADDR : 25 08 00 75 1E 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:10 |
04-05-2012, 22:09 | #10560 (permalink) |
Banned Join Date: Jun 2009
Member: 1054543 Status: Offline Thanks Meter: 0 | ZTE staradict new security unlock done with furiousoftware engine version: 1.0.0.7882 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Feb 13 2012 02:05:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86853400072939-1 BLUETOOTH ADDR : 37 DB A0 B2 1A 68 TAG_ID:P743FB051z DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:56 |
