03-24-2012, 16:33 | #10531 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | zte R250 unlock done > NCK: 878780554953 > SPCK: 161315564385 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. > IMEI: 860234010613143 > NCK: 648318864060 > SPCK: 989624874492 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. thanks furious team |
03-25-2012, 12:23 | #10532 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Product: OT-306 Provider ID: 306X-2[X=E]BGKZ1 IMEI: 356080043259367 Start code calculate... NCK:3003964023 NSCK: SPCK: PCK: Code calculate finished successfully! |
03-25-2012, 14:56 | #10533 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633040650262 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:24 |
03-26-2012, 06:02 | #10534 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 359391026279059 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:19 |
03-26-2012, 06:39 | #10535 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | acer s100 unlocking done......... Software engine version: 1.0.0.7740 Searching phone ... MODEL : QCOM SERIES 16 COMPILED DATE : Oct 6 2010 16:43:00 RELEASE DATE : Mar 29 2010 13:00:00 FIRMWARE INFO : 8650B-SDCAOLYM-4075 IMEI : 353XXXXXXXXXX-X BLUETOOTH ADDR : 00 16 D4 51 83 6C LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 82793756 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESET ! Time needed : |
03-26-2012, 13:37 | #10536 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | T 156 unlock done Software engine version: 1.0.0.6438 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037149963 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081037149963_P1.2PU03V01.01_15.50.56_26. 03.2012_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
03-26-2012, 14:36 | #10537 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | gw300 unlock Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35573703012237600 Codes: 8481426538202156 8481426538202156 4302015266917064 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:30 |
03-26-2012, 14:39 | #10538 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Press power on shortly ... Starting communication ... BootRom v04.11 Sending certificate ... Sending preloader ... Sending EBOLA ViruS ! Phone infected. RSA Defeated ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Trying baud rate change ... Baud rate changed ok ! FLASH 1 ID: 0001:227E 0A01 MODE: E100/E105/E157/E158/E159/E160/E161 E200/E205/E220/E230/E252/E256/E257 E259/E260/E265/C61/C62 MCU ID: 30244359C21502E0 ALGO TYPE: 01 OTP IMEI: 359831000307756 PROVIDER: E205X-2ARGFR1 FW INFO: 67CBAA0105 CODES: NCK: 7552456351 RESET: 4169298833 Operation completed. Phone reseted ! Time needed - 00:00:08 |
03-26-2012, 14:40 | #10539 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | vodafone 720 unlock Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00EC:0078 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:11 Software engine version: 1.0.0.7736 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 15 2009 23:23:00 RELEASE DATE : Jun 24 2009 19:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B03-S IMEI : 35674003068895-7 BLUETOOTH ADDR : 18 80 FC 12 25 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) |
03-26-2012, 14:40 | #10540 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 7510 unlock Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35879203002088-7 READING; SP_SAVED_TO: SP_35879203002088_DA6_19.44.14_13.03.2012_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 208-01 MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:02:21 |
03-26-2012, 15:27 | #10541 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In your Mind Age: 41
Member: 252220 Status: Offline Sonork: 100.1606995 Thanks Meter: 195 | unlock lg c900 Software engine version: 1.0.0.7704 Searching phone ... MODEL : C900 COMPILED DATE : Oct 2 2010 11:55:00 RELEASE DATE : Sep 23 2010 22:00:00 FIRMWARE INFO : LG-C900_V10d_Final1-OCT-02-2010-2250-7004 IMEI : 01xxxxxxxxxxxxx53743-3 BLUETOOTH ADDR : 75 B8 3E D3 17 5C ENTERING DOWNLOAD MODE; ENTERED; LOADING DATA; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; SEC DATA 1 WRITTEN; UNLOCKED ! Time needed - 00:01:02 |
03-28-2012, 09:11 | #10542 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6438 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DB 38 84 99 62 09 84 05 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:51 |
03-28-2012, 12:06 | #10543 (permalink) |
Freak Poster Join Date: Mar 2012 Location: SL3 KING
Member: 1728148 Status: Offline Sonork: 100.1646786 Thanks Meter: 188 | Ot-800 successfull unlock Make your handset power off, plug in the UART cable! Product: OT-800 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 351544039921616 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\800 X-2GVRGB1 Read security information successfully! Start code calculate... Product: OT-800 IMEI: 351544039921616 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\800 X-2GVRGB1 NCK:1699445841 NSCK: SPCK:1644292215 PCK: Code calculate finished successfully! |
03-29-2012, 08:08 | #10544 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | ZTE F100 UNLOCK DONE ! Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 12 2010 21:04:00 RELEASE DATE : Jun 24 2010 21:00:00 FIRMWARE INFO : ORG_MD_P607C4V1.0.0B06-S IMEI : 35804703226511-7 BLUETOOTH ADDR : 34 9B 73 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:49 |
03-29-2012, 19:04 | #10545 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Searching phone ... Phone detected ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35663104767941-2 READING; SP_SAVED_TO: SP_35663104767941_E77_09.32.56_29.03.2012_HUAWEI.b in ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:47 |
