07-10-2014, 14:55 | #11897 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Alcatel one touch ot5020t (t-mobile)unlock done with pack6 Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (MTK USB Port) Preparing to start flash mode; Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 5387d67e772561e8967a642f2d80dd73 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port) TRYING TO OPEN COM51; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, 05] HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xD43D1058 0x49B0E598 [SIZE=0xE9300000] IMEI1 [OTP 0001]: 013778-00-838687-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020T-2ATBUS1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9E3B4000 Searching data; Locked to: 310-16 code_cat_n: 30923019 enabled: yes tries: 3 code_cat_ns: 36768095 enabled: no tries: 10 code_cat_sp: 22991240 enabled: no tries: 10 code_cat_c: 02656639 enabled: no tries: 10 code_cat_sim: 04933400 enabled: no tries: 10 code_cat_ns_sp: 28578231 enabled: no tries: 5 code_cat_sim_c: 41570744 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:10 wbr. rajesh_ch |
07-11-2014, 06:07 | #11898 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | Zte f102 h3g unlock done ZTE F102 H3G UNLOCK DONE Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 15 2009 23:23:00 RELEASE DATE : Jun 24 2009 19:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B03-S IMEI : 35674003170084-3 BLUETOOTH ADDR : 1E 3A CB ED 26 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Log file saved to: LOG_11_07_2014_10_03_05.txt Time needed - 00:00:05 |
07-11-2014, 07:31 | #11899 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | alcatel 3040g unlock done Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (USB Modem Driver) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F25 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 869120-01-249469-2 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:18 |
07-13-2014, 03:48 | #11900 (permalink) |
Junior Member Join Date: Aug 2008 Location: France
Member: 839142 Status: Offline Thanks Meter: 1 | Ot 4015 unlock done PACK 6 MTK CODE READER Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM18); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P2 Hw Version: JRDSZ72_WE_JB3_HSPA_HW Reading phone info; IMEI: 8---50-02-023062-6 Reading simlock info; Locked to: 208-01 code_cat_n: 5160397271 enabled: yes tries: 10 code_cat_ns: 0165593603 enabled: no tries: 10 code_cat_sp: 6030368946 enabled: no tries: 10 code_cat_c: 6635660320 enabled: no tries: 10 code_cat_sim: 0814592307 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 |
The Following User Says Thank You to zay01 For This Useful Post: |
07-14-2014, 08:08 | #11901 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | zong Z100 unlock done Software engine version: 1.0.0.6552 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040312001 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 27 09 21 05 90 06 01 0B 05 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040312001_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.05.56_14.07.2014_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
07-14-2014, 08:08 | #11902 (permalink) |
07-15-2014, 18:08 | #11904 (permalink) |
Freak Poster Join Date: Aug 2009 Location: DRC
Member: 1105110 Status: Offline Sonork: 02525 Thanks Meter: 13 | Lobster 575 unlocked by FG using correct pinout Lobster 575 unlocked by furious gold using this pinout: keyboard top 1.........24 13: Phone Tx (RJ45 pin-3) 14: Phone Rx (RJ45 pin-2) 24: Gnd Last edited by .:hack3r2k:.; 07-17-2014 at 13:39. |
07-15-2014, 18:22 | #11905 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Blackberry 8520 Curve Searching for usb device ... Reading info ... IMEI: 352773054964826 Calculating ... MEP LOCK: MEP-08589-001 MEP1 [SIM]: 5132475115198964 MEP2 [NETWORK]: 87962587 MEP3 [NETWORK SUBSET]: 1435964361268497 MEP4 [SERVICE PROVIDER]: 6555260992560713 MEP5 [CORPORATE]: 0053984771122563 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:40 |
07-16-2014, 21:55 | #11906 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Colombia
Member: 448639 Status: Offline Thanks Meter: 165 | toshiba t705t unlock done others fail th to FG team Quote:
07-17-2014, 02:35 | #11908 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 26 COMPILED DATE : May 25 2012 17:27:00 RELEASE DATE : Feb 2 2012 18:00:00 FIRMWARE INFO : ATT_AM_P671A90V1.0.0B17-S IMEI : 86183100308129-2 BLUETOOTH ADDR : 0A 55 B9 E2 6D F4 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 5EF8510C19F96000413C001DFDB7B60C.bin ERASING; WRITING; READING; AFTER BACKUP: 2E3297D6788657B97B7CC2155CCA759B.bin UNLOCKED; RESET ! Log file saved to: LOG_15_07_2014_18_49_28.txt Time needed - 00:00:15 |
07-17-2014, 08:54 | #11909 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | alcatel ot355 unlocked done Code: Product: OT-355 Provider ID: 355X-2[X=D,E,F,I]RGES1 IMEI: 3539230493xxxxx Start code calculate... NCK:2850756021 NSCK: SPCK: PCK: Code calculate finished successfully! |
07-17-2014, 09:05 | #11910 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Tadjikistan, Dushanbe Age: 35
Member: 1533366 Status: Offline Thanks Meter: 131 | ZTE G R255 BEELINE TJ unlocked Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem90.inf,%mtk6218%;USB Modem Driver) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6250 Sw version: TJ-BEE-9D-P150A20V1.0.0B02 Hw Version: DS-M255A V1.2 Reading phone info; IMEI: 866385-01-190821-5 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:14 |
