11-16-2012, 06:40 | #11146 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 4 2011 17:25:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86160300037308-3 BLUETOOTH ADDR : F0 36 B0 B2 1A 68 TAG_ID:QCNDef6 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:41 Software engine version: 1.0.0.6502 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DB 36 84 94 C4 09 08 08 Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:27 |
11-16-2012, 23:21 | #11147 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Zte z431 unlock done Software engine version: 1.0.0.8530 Searching phone ... MODEL : QCOM SERIES 26 COMPILED DATE : May 25 2012 17:27:00 RELEASE DATE : Feb 2 2012 18:00:00 FIRMWARE INFO : ATT_AM_P671A90V1.0.0B17-S IMEI : 8618310********* BLUETOOTH ADDR : 9B F4 D8 E2 6D F4 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 5EF8510C19F96000413C001DFDB7B60C.bin ERASING; WRITING; READING; AFTER BACKUP: 03538C0FFDD8406E9CFD6BB47D9C1831.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
11-17-2012, 08:51 | #11148 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zte 100 unlock Software engine version: 1.0.0.8460 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Nov 5 2009 18:24:00 RELEASE DATE : Sep 15 2009 20:00:00 FIRMWARE INFO : YOG_ES_P607C4V1.0.0B06-S IMEI : 35804703008872-7 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 214 MNC: 4) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:49 |
11-17-2012, 10:44 | #11150 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | VF527 unlock done Press power on shortly ... Starting communication ... MCU ID: 11A0000C44A246C1000000000000320A ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002910 Algo: 05 Firmware: EVN,PJ: 160908 1059 Imei: 359262021871648 Phone code: 0000 Prod. code: 254053893 Id calculation done; CODES: NET LO CODE: 0393925039 NET HI CODE: 1471860335 Done ! Time needed - 00:02:16 |
11-17-2012, 10:46 | #11151 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | voda fone 527 unlock ok Press power on shortly ... Starting communication ... MCU ID: 0CC0020394636BC1000000000000CE32 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000220E Algo: 05 Firmware: EVN,PI: 200808 0938 Imei: 359262021466225 Phone code: 0000 Prod. code: 254025878 Id calculation done; CODES: NET LO CODE: 2413675673 NET HI CODE: 3483223129 DIRECT UNLOCK: OK Done ! Time needed - 00:03:14 |
11-17-2012, 10:50 | #11152 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | VF527 unlock done Press power on shortly ... Starting communication ... MCU ID: 3AA00118304900C20000000000002C64 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002D30 Algo: 05 Firmware: EVN,PH: 240408 0931 Imei: 351959020169977 Phone code: 0000 Prod. code: 254023494 Id calculation done; CODES: NET LO CODE: 3933516745 NET HI CODE: 2863969161 Done ! Time needed - 00:01:50 |
11-17-2012, 10:51 | #11153 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | sagam my411V unlock done Press power on shortly ... Starting communication ... MCU ID: 31800116061A5FC10000000000009A26 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411V Hash: 00002508 Algo: 05 Firmware: LV5,RO: 180407 1444 Imei: 355150017451620 Phone code: 0000 Prod. code: 252901898 Id calculation done; CODES: NET LO CODE: 2082921946 NET HI CODE: 1013374362 DIRECT UNLOCK: ERROR Done ! Time needed - 00:02:58 |
11-18-2012, 06:20 | #11154 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Comm opened 9 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001rusc24b100sec test mode status: Off sim status: Off imei: 868919006939492 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:22 |
11-18-2012, 06:20 | #11155 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6502 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DE 39 C1 95 DB 01 0C 0B Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:35 |
11-18-2012, 11:03 | #11156 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6502 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 E7 C9 20 49 90 84 00 09 0A Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:27 |
11-18-2012, 11:13 | #11157 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Product: OT-602 Provider ID: 602X-2[X=F]N1RU3 IMEI: 356801042710997 Start code calculate... NCK:2857465562 NSCK: SPCK: PCK: Code calculate finished successfully! |
11-20-2012, 09:57 | #11158 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | Zte-u n721 ZTE U N721 succesfully unlocked. Thank you Furious Team. BR. Software engine version: 1.0.0.8530 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Sep 29 2011 09:36:00 RELEASE DATE : May 16 2011 03:00:00 FIRMWARE INFO : ZTE-U N721_10_Z28_S_TSECD215B_07 IMEI : 35684504059xxx-1 BLUETOOTH ADDR : 26 CC EF 50 4B 34 TAG_ID:re DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; WRITING SEC; SIMLOCK_REMOVED ! POWER OFF PHONE NOW TO COMPLETE THE UNLOCK ! RESET ! Time needed - 00:00:40 |
11-20-2012, 19:15 | #11159 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | zte Z431 unlocked Software engine version: 1.0.0.8530 Searching phone ... MODEL : QCOM SERIES 26 COMPILED DATE : May 25 2012 17:27:00 RELEASE DATE : Feb 2 2012 18:00:00 FIRMWARE INFO : ATT_AM_P671A90V1.0.0B17-S IMEI : 86183100024315-0 BLUETOOTH ADDR : AA 46 BF 2F 28 48 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 5EF8510C19F96000413C001DFDB7B60C.bin ERASING; WRITING; READING; AFTER BACKUP: 03538C0FFDD8406E9CFD6BB47D9C1831.bin UNLOCKED; RESET ! Time needed - 00:00:15 |
11-20-2012, 19:15 | #11160 (permalink) |
