04-05-2017, 23:06 | #13636 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01469900382648-7 PTH: 04 PTS: M5K PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 20:A9:0E:FF:54:5D SWIFIADDR: 20:A9:0E:FE:27:20 HS_PN: SAA1GY0WA10C SSN: 48KB08CIIKZ03DG Work id: 0754B6DF Done; SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01469900382648-7 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_5_04_2017_18_03_19.txt Time needed - 00:00:28 |
04-05-2017, 23:08 | #13637 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5056A UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01460800196308-5 PTH: 13 PTS: A4U PROV_ID: 5056A-2PC9JMD SBTADDR: 28:BE:03:68:0A:FB SWIFIADDR: 28:BE:03:4A:28:8F HS_PN: SAA1F51WA10C SSN: L3KC07CKNKZ0018 Work id: 05F736A7 Done; SECURITY: XHA0OP08BR10 Size: 0000031D Backup saved to: 01460800196308-5 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_5_04_2017_18_07_51.txt |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
04-06-2017, 09:01 | #13638 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Vodafone Smart Mini 7 Unlock Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM Port (COM7)) Preparing to start flash mode; Preparing to open COM7 Connecting; Downloading DA; Initializing; Rid: c8d135588ac2c764e41c64700ee7381f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem30.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM19; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x1CDD0030 0xA9730F0E [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: V300-2BVDAU1 USRDATA INFO: 0x47000000 SIZE: 0x60000000 Searching data; Locked to [SIM1]: 505-03 code_cat_n: 6461631307592227 enabled: yes tries: 99 code_cat_ns: 2316028309761284 enabled: no tries: 10 code_cat_sp: 9256402755249828 enabled: no tries: 10 code_cat_c: 2327674908451254 enabled: no tries: 10 code_cat_sim: 9409919598990412 enabled: no tries: 10 code_cat_ns_sp: 8391823918787605 enabled: no tries: 5 code_cat_sim_c: 8313251747747286 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:09 Log file saved to: LOG_6_04_2017_12_55_40.txt |
04-06-2017, 12:55 | #13639 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | OT 1010D unlocked Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W11.32.SP.V12.F4 Hw Version: JRDHZ50M_11B_HW Reading phone info; IMEI: 860056-02-272441-4 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:21 Log file saved to: LOG_6_04_2017_14_43_47.txt pack 6 cable ot 209 |
04-06-2017, 13:02 | #13640 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Pakistan
Member: 2206874 Status: Offline Sonork: 100.1584591 Thanks Meter: 36 | Ot-1016G done with Furious Gold was bricked with other software Phone detected (SPRD U2S Diag) Preparing to sync; Port opened [COM247]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1016G-3AE8GB1 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 358734-07-******-4 SW IMEI[1]: 352751-01-******-7 SW IMEI[2]: 358570-01-******-3 SW IMEI[3]: 910575-60-******-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_358734-07-******-4_65310001_5_04_2017_19_14_04.spd IMEI: 358734-07-******-4 UNLOCK CODE: 16113716 Code reading finished; Remove battery and cable; |
04-07-2017, 06:45 | #13641 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | alcatel 5010u frp remove done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (Lenovo PreLoader USB VCOM (Android) (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: e714c68b3cc258f772c1e9bae8bb6d81 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (Lenovo DA USB VCOM (Android)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323237 0x84420042 0x277317C4 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5010U-2GALAE1-1 USRDATA INFO: 0x89000000 SIZE: 0x49880000 Factory Reset Protection successfully removed ! Time needed - 00:00:02 Log file saved to: LOG_7_04_2017_10_41_51.txt thanks furious teem |
04-07-2017, 16:03 | #13642 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | ZTE F320 unlocked Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem45.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM6]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 00C8:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: VDF_NZ_QB18S_P701A24 BT ADDR: F9:C0:E2:6A:68:18 SW IMEI[0]: 867063-02-32xxxxxx SW IMEI[1]: 000000-00-000000-0 SW IMEI[2]: 000000-00-000000-0 SW IMEI[3]: 000000-00-000000-0 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_867063-02-3xxxxx-5_77020000_7_04_2017_20_29_01.spd IMEI: 867063-02-325325-5 UNLOCK CODE: 95044179 Code reading finished; Remove battery and cable; Log file saved to: LOG_7_04_2017_20_29_06.txt Time needed - 00:00:30 |
The Following 2 Users Say Thank You to deepakgarg For This Useful Post: |
04-08-2017, 16:51 | #13643 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Midicmobile
Member: 1728478 Status: Offline Thanks Meter: 22 | wiko lunny 2 from operateur O2 direct unlock with otsmart pack 6 log: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM32)) Preparing to start flash mode; Preparing to open COM32 Connecting; Downloading DA; Initializing; Rid: 723f2dd752347f132e028bf1fa3b7ada Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM18; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D37324A 0x5EB20242 0xB983AD6A [SIZE=0xE9880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x59800000 SIZE: 0x60000000 Searching data; Locked to [SIM1]: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Locked to [SIM2]: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:58 |
04-10-2017, 07:04 | #13644 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Samsung E1200i unlock done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem250.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM16]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530 FdlStat: C000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: GT2E1200ZKISUW PHONE SN: R21G60LKC4 MSL PASS: 37464F5D19114559300D025E350D473D BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 351952-07-486400-7 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 30390000 Reading NV; NV saved to : NV_000000-00-000000-0_351952-07-486400-7_6530C000_10_04_2017_08_55_53.spd Calculating ... Freeze code: 51859084 NET lock: 71403716 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_10_04_2017_09_00_46.txt Time needed - 00:05:04 |
04-10-2017, 09:56 | #13645 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 162 | 5054x unlock ok 1.connect switched off phone with pc usb 2.install drivers from support: VODAFONE_SMART_PRIME_6_TAB 6_OT-6038_OT-6045_A851L_IDOL_3_etc.rar 3.select pack 5 Qcom,firehorse mode, choose 5054, press "do job", connect power off phone via usb, and done!!! Preparing to enter download mode; Preparing to open COM89 Connecting; Init; Port opened; Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM45 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 35273007027954-8 PTH: 23 PTS: C8L PROV_ID: 5054X-2ATBAL3 SBTADDR: 18:E3:BC:3C:C2:85 SWIFIADDR: 18:E3:BC:3C:C2:86 HS_PN: SAA35H0AAS0C SSN: 4VKG11CCAPY009Z Work id: 033D415A Done; SECURITY: X8C0CA00BR10 Size: 000002B1 Backup saved to: 35273007027954-8 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_10_04_2017_10_46_13.txt Time needed - 00:00:36 |
04-11-2017, 13:14 | #13646 (permalink) |
Freak Poster Join Date: May 2015
Member: 2397754 Status: Offline Thanks Meter: 98 | unlock huawei y360-u72 Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM39)) Preparing to start flash mode; Preparing to open COM39 Connecting; Downloading DA; Initializing; Rid: bfa9d00062cc77ed9d549a3a5ea8247d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem95.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A324A 0xD6040242 0x2F733BA8 [SIZE=0xE9880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x7DD00000 Searching data; Locked to [SIM1]: FFF-FF code_cat_n: N/A enabled: no tries: 5 code_cat_ns: 8B6098F5CEA9BA18 enabled: yes tries: 3 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Phone unlocked; Remove battery and cable; Time needed - 00:00:12 Log file saved to: LOG_11_04_2017_13_11_13.txt |
04-12-2017, 08:37 | #13647 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | vodafone smart speed 6 flash done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM46)) Preparing to start flash mode; Preparing to open COM46 Connecting; Downloading DA; Initializing; Rid: f9e4e155e2bbe65e0827051637e0a4b7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem11.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM240; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x1EAF0042 0x35A2669B [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-193436-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2BVDGB2 USRDATA INFO: 0x99000000 SIZE: 0x39880000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:06:19 Log file saved to: LOG_12_04_2017_13_34_23.txt |
04-12-2017, 11:25 | #13648 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | OT-282 unlocked done Code: Product: OT-282 Provider ID: 282X-2[X=A,B,C]RGRO3 IMEI: 8619410037xxxxx Start code calculate... NCK:4198812063 NSCK: SPCK: PCK: Code calculate finished successfully! |
04-12-2017, 11:27 | #13649 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | vodafone 889n unlocked successfully Code: Searching phone ... MODEL : QCOM SERIES 41 COMPILED DATE : May 19 2014 17:05:00 RELEASE DATE : Apr 21 2014 06:00:00 FIRMWARE INFO : GWL_T3_1013901_01 IMEI : 3538530606xxxxxx BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 93A3D7262A58D355A23663E409F9B35B.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! |
04-12-2017, 11:33 | #13650 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | smart prime 6 unlocked done Code: Phone detected (Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM76 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 3569070674xxxx-1 PTH: 15 PTS: W7A PROV_ID: V895N-2HVDRO1 SBTADDR: 1C:CB:99:EC:67:51 SWIFIADDR: 1C:CB:99:EC:67:52 HS_PN: SAA6197AAC0C SSN: 3PKC35CBPOY0278 Work id: 0FF5A1AB Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X9W7FLN0BG00 Size: 00000430 Backup saved to: 3569070674xxxx-1 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! |
