Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 07-25-2006, 19:48   #1 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
Still cant unlock a Z500 with this NsPro box?
I'm trying to unlock a z500 with Nspro but all i can get is this
Searching for phone...
Reading locks info...
Checking serial communication...
Reading IMEI...
Operation failed!
Please dont tell me its drivers problem as i can read the codes from the Z500 useing NSPRO + CABLES using the multiunlocker code reader by Movilcom so the drivers must be install correctly unless i wouldn't be able to reads the codes from it right?
Old 07-25-2006, 19:56   #2 (permalink)
Member: 175297
Thanks Meter: 4
Reading IMEI...
Operation failed!
I did get the same but when i did push read again then it worked great, did also flashed Z500 with NSPro yesterday with 100% sucess....
Old 07-25-2006, 20:05   #3 (permalink)
Member: 193781
Thanks Meter: 18
@ simzmobiles
Yes, You are right. But check again contro panel/modems. If there are more than one modem installed then remove all samsung modems and install again.
I had also same situation and i was also very angry but ultimately , when i checked installed modems in control panel, there were more than one modems installed.
Best of Luck
Old 07-25-2006, 21:20   #4 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
hi, i just finished unlocking 60 pieces of samsung z500 brand new mate, dont know what problems you have.
Old 07-25-2006, 22:33   #5 (permalink)
Member: 307549
Thanks Meter: 188
Ive checked the installed modems and they is only one there, also i not use nspro now at all on my desktop PC, nspro starts up but when i press info or unlock the PC restarts. Ive lost count on the times Ive reinstall nspro now but it's still the same?
Old 07-26-2006, 06:30   #6 (permalink)
Temporary banned !!
Member: 69157
Sonork: 100.107865
Thanks Meter: 471
Yes, this situation comes on with some PC. I tested some NS Proes at different PCs, when running NSPro, it's OK, but when we choose any function, PC restart suddenly... . Maybe, Windows conflict
Old 07-26-2006, 12:25   #7 (permalink)
thcoms's Avatar
Member: 142512
Thanks Meter: 2
Reading IMEI...
Operation failed!
Drop the phone off m8 & i'll sort it for ya with my good old NS Box.
Old 07-26-2006, 12:51   #8 (permalink)
Member: 307549
Thanks Meter: 188
I can unlock this with other tools i have, but that is not the point here
Old 08-14-2006, 07:19   #9 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
what service pack you are using with ns pro?? im using sp3 (vista) and its restarting...but with my other computer uisng service pack2 its ok.
Old 08-14-2006, 18:16   #10 (permalink)
Member: 80683
Reading IMEI...
Operation failed!
hi mate have look and see if the bluetooth is turned on if so turn off you may have more luck as i have had that problem good luck
I cant unlocked lg gt365 with micro box[ANSWERED] godwin Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 01-27-2010 16:05
Still cant unlock and sonys with this new update. The Repair Shop FuriousGold 2 12-12-2007 17:29
3.11.7 still cant unlock R225... aarons6 NSPRO 1 02-22-2006 01:49
u8120i VER-U8180I_V101_041218 still cant unlock ??? TRABEL LG 2 06-25-2005 08:41
Twister still cant unlock z200 flisko Twisterflasher 2 12-30-2004 16:53
Page generated in 0.23420 seconds with 9 queries
