07-26-2006, 04:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | c139 log/fail to unlock Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... Set Baud Done Check Flash-1... SW Ver: 1.0.02.E. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 30 sec failed to ulock?? |
07-26-2006, 04:41 | #2 (permalink) |
Member: 78367 Status: Offline Thanks Meter: 11 | Action: Read code Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... Set Baud Done Check Flash-1... SW Ver: 1.0.02.E. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... Err: can't read codes Finished Remove/Install battery now ! Time used: 19 sec log of read codes also failed |
07-26-2006, 10:29 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 62154 Status: Offline Thanks Meter: 17 | Hello Master i have one Motorola C139can't unlock/read code COM12 selected Action: Read code Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 8.5.17 HW ver: MOTOROLA_E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_TP_T1H Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-7-26_17-0-49.31E.bin Err: can't read codes Finished Remove/Install battery now ! Time used: 15 sec COM12 selected Action: Unlock Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 8.5.17 HW ver: MOTOROLA_E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_TP_T1H Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-7-26_17-3-26.31E.bin Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 15 sec Please help |
07-26-2006, 12:12 | #6 (permalink) | |
It's TracFone C139. Try to write ordinary firmware in this phone. In case of problems after flashing you can write back TracFone firmware (available in support area). | |
Failed to Unlock 2323c Using Super DCT4 Activation [Solved Thanks to Alex] | tims | Cyclonebox | 7 | 07-31-2010 10:31 |
c139 TRACFONE impossible to unlock | bachatia | Infinity-Box | 13 | 10-08-2007 15:33 |
C139 fail to unlock | touch_111387 | Smart-Unlocker | 0 | 04-09-2006 12:02 |
