04-04-2011, 16:17 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | china n8 i tried to read the full flash and then change the IMEI but i am not able to read the flash but in the ON mode i can change the imei .. any of the pinfinder does not work in this set except gpg dragon . then i try to find the RX TX on the board and soldered the wires directly but i am not able read , or format this set ... Code: Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235B, E0 Hardware version: SLD35_09A_HW Software version: SH8-CN3_SW_TOS_V005" Software date: 2000.00.00 Barcode: MT012345678901234567 10 http://forum.gsmhosting.com/vbb/f646...olved-1232303/ how can i read the full flash of this set and then format and change the imei ? |
04-08-2011, 10:12 | #6 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | done the set only with the latest module v3.29 chinese miracle version .. now i am checking the set if it is working ok for some time .. thanks infinity team .. Code: ==== [4/8/2011 12:12:58 PM] ==== COM9 [Serial2] selected module v3.29 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: SH8-CN3_SW_TOS_V005 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL can not read memory, errorcode: 0FAA it may be problem with current operation error: last error: 0FAA:S_FT_READBACK_FAIL Disconnect... done Finished, time used: 24 sec Remove/Install battery now ! ==== [4/8/2011 12:13:29 PM] ==== COM9 [Serial2] selected module v3.29 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: SH8-CN3_SW_TOS_V005 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: SLD35_09A_BOOTLOADER_V005_MT6235B_SH8-CN3_SW_TOS_V005.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN project-id: SH8-CN3_SW_TOS_V005, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.29, database date: 04.04.2011): SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== Disconnect... done Finished, time used: 1 min 4 sec Remove/Install battery now ! In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [4/8/2011 12:15:16 PM] ==== COM9 [Serial2] selected module v3.29 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: SH8-CN3_SW_TOS_V005 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: SLD35_09A_BOOTLOADER_V005_MT6235B_SH8-CN3_SW_TOS_V005.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN project-id: SH8-CN3_SW_TOS_V005, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.29, database date: 04.04.2011): SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\ChineseMiracle\SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005__firmware_20110408-122616.B4M.bin Disconnect... done Finished, time used: 11 min 49 sec Remove/Install battery now ! In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [4/8/2011 12:27:14 PM] ==== COM9 [Serial2] selected module v3.29 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: SH8-CN3_SW_TOS_V005 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: SLD35_09A_BOOTLOADER_V005_MT6235B_SH8-CN3_SW_TOS_V005.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN project-id: SH8-CN3_SW_TOS_V005, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.29, database date: 04.04.2011): SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\ChineseMiracle\SLD35_09A_PCB01_GPRS_MT6235B_S01.SH8-CN3_SW_TOS_V005__fullflash_20110408-130749.B4M.bin Disconnect... done Finished, time used: 47 min 15 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 353056755256968 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 352009026719356 verification Ok Finished, time used: 17 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6228-6268 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 353056416046568 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 353812001707299 verification Ok Finished, time used: 2 sec Remove/Install battery now ! |
04-08-2011, 11:27 | #7 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | If phone is working fine send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage Wr. |
06-20-2011, 10:14 | #8 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: E.A.P & E.A.S
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | Quote:
Would you upload somewhere your backup ? I want that firmware ... Thanks in advance | |
06-25-2011, 12:35 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
must be very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restoring? | |
Siemens 1118 fw 50 from China | usmanov | x1x to x45/x50 | 0 | 04-20-2002 20:16 |
China Emmi clip with "reset button" , help ! | kazak | Motorola Old Legacy (EMMI) | 0 | 03-25-2002 14:46 |
Is RHY in China a reliable manufacturer to get cables? | Chaku | Main Sales Section | 8 | 12-27-2001 15:13 |
Dejan's 1.05 Flasher for Sell and Demonstration in Hong Kong and China.. | Mike Ho | Main Sales Section | 2 | 12-23-2001 16:03 |
which manufacturer in China produce good quality with good price? | Chaku | Main Sales Section | 4 | 11-28-2001 11:32 |
