03-26-2014, 17:31 | #76 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : MT_DEV Project Info : 8851A_ht_1203 Compile Date : 20130710Wed1127 [BIN] Saved as : MT_DEV_8851A_ht_1203_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MT_DEV_8851A_ht_12 03_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\MT_DEV_8851A_ht_12 03_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:18:02 Reconnect Power/Cable! |
03-26-2014, 17:46 | #77 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Format ok report Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:09 Reconnect Power/Cable! |
03-26-2014, 21:09 | #79 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Welcome Back Infinity Team in Chines Phones ill ask my Shop boy he will provide u Reports Br Mohsin-* |
The Following 2 Users Say Thank You to Mohsin-* For This Useful Post: |
03-27-2014, 01:01 | #80 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | @Dzirt Here is test, RDA8851, USB Phone is Bocoin B205. Code: Chinese Miracle II [RDA module] v 0.04 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCCCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 Initial : 81C0024C Boot Done! Elapsed: 00:00:17 Done Reconnect Power/Cable! Code: Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCCCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00800000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read done, sorting EXTData Following items found : Item : CSW Item : VDS0 Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:17 Done Reconnect Power/Cable! |
The Following User Says Thank You to JorgeVla For This Useful Post: |
03-27-2014, 06:29 | #81 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Somtel s2 03 format done Card found: Chinese Miracle II [RDA module] v 0.04 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:08 Reconnect Power/Cable! |
The Following User Says Thank You to sultan_ For This Useful Post: |
03-27-2014, 07:50 | #84 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | RDA RDA8851 Blinking Problem done by Infinity box Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Use : 8809_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00E00000 , Len : 0x001FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:05:17 Reconnect Power/Cable! @ Dzirt Formatting speed is very Slow Best Regards |
The Following 2 Users Say Thank You to DUNIYA JAMAL For This Useful Post: |
03-27-2014, 09:12 | #86 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | If flash erased - possible make recovery in USB mode. Still work on that. If it dead by wrong flash, format and e.t.c. - need use COM. 16 MB chip - it is Ok. Of 4 MB it will be 40-45 seconds. |
The Following User Says Thank You to Dzirt For This Useful Post: |
03-28-2014, 04:36 | #87 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Version 0.05 is out. Code reading improved for RDA 8853 series RDA 8853 with ID 8808 should work well now. Firmware detection improved And much things fixed and improved. |
03-28-2014, 06:06 | #88 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | SAmsung 6010 ime write done Card found: Chinese Miracle II [RDA module] v 0.05 Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 1 Sim Slot(s) Current Phone IMEI : IMEI1 : 000000000000000 New Phone IMEI : IMEI1 : 35464132465413-9 IMEI2 : 35498413463146-1 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to sultan_ For This Useful Post: |
03-29-2014, 10:30 | #89 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | read code error Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 880A_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Can't read required data from phone! Seems as already erased NV Reconnect Power/Cable! |
03-29-2014, 10:40 | #90 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | G mobile m93 read flash done Card found: S/N Chinese Miracle II [RDA module] v 0.05 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 880A_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT1128 Target Flash : flsh_spi32m Project Name : C100C_DWS_M93_RDA8852D_ST3216_PCB20_QCIF_S_ENG_PER _URD_GMOBILE_V06 Compile Date : 20120816Thu1149 [BIN] Saved as : C100C_DWS_M93_RDA8852D_ST3216_PCB20_QCIF_S_ENG_PER _URD_GMOBILE_V06_CT1128_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C100C_DWS_M93_RDA8 852D_ST3216_PCB20_QCIF_S_ENG_PER_URD_GMOBILE_V06_C T1128_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C100C_DWS_M93_RDA8 852D_ST3216_PCB20_QCIF_S_ENG_PER_URD_GMOBILE_V06_C T1128_flsh_spi32m.ifc Build done Done Elapsed: 00:18:33 Reconnect Power/Cable! |
